Question about Kodak EasyShare C875 Digital Camera
MY BATTERIES GO DOWN VERY QUICK. HOW COME ?? - Kodak EasyShare C875 Digital Camera
  • Larz May 11, 2010
    How quick is very quick?
    What kind of batteries are you using?
    IS the display screen on all the time?
    Sniper:
  • 71 Answers
My guess here is that you're using standard "AA" batteries. If you're doing this, a digital camera will **** the life out of them very quickly. Look into purchasing rechargable "AA" size Lithium-Ion batteries. They will last MUCH longer and save you a ton of cash on the alkaline batteries.
Posted on Jul 15, 2009
24volt system draining fully charged batteries within 30 minutes down to 2 volts each and ignition doesnt turn bus off have to stall it have to remove battery to turn dash lights of has new alternator
to drain the batteries down that quick the battery cables would be very hot to the touch
if they are not then the problem may be an internal fault in the batteries so have them load tested first to eliminate them from the equation
Unless you are running a heavy vehicle then 24 volts will be very unusual as most light vehicles run 12 volts
If that is the case and you have 2 X 12 batteries make sure that they are connect correctly ( in parallel not in series) or they will discharge each other very quickly
Jun 14, 2015 | Cars & Trucks
MY BATTERIES IN MY FUJIFILM S5000 RUN DOWN FAST?
Digital cameras for the most part should only be used with rechargeable NiMH batteries. These days many retailers sell these for around $7 for a package of four AA (about $15-19 for the batteries with charger). Keep in mind they'll save you big bucks in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many, many more). You'll be very pleased with their performance, and may slap yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Nov 10, 2011 | Fuji FinePix S5000 Digital Camera
Put new batteries in my wildview cam works for a second than stops
Rechargeable or one use type batteries?
Could be it was a faulty pack.
If recharge type did you give them their first charge for around 24 hours?
Always use Alkaline or Lithium Ion single use batteries.
If rechargeables always use a high number mah rating; 3.2s will go down quick, 8. (whatever it is) will sustain.
If none of these help try Technical Support on the website of your camera's manufacturer.
Sep 26, 2011 | Cameras
My intec remote is showing the hand upside down and it is also backwards. If I point it right it goes left, point it down it goes up. Any solution other than to take it back and get a new one. Have tried...
After doing a quick search online seeing if other users have had this problem, it looks like a quick fix suggested straight from Nintendo is to turn your controller upside down and whack it a few times. Supposedly, this fixes the problem, as strange as the solution sounds. You can read what I read by clicking here if you're curious (which I'm sure you are). I know you've mentioned you removed the batteries, but I'm not sure if you meant you swapped the batteries or just reinserted the ones you already had. If you haven't, I'd suggest completely swapping the current batteries for new ones before you try this "fix."
Mar 13, 2011 | Nintendo Wii Remote Controller
Batteries run down in a little over half a day in my new uniden BC72XLT scanner, is it batteries, charger or scanner?
its most likely the scanner. i had one that used up batteries pretty quick. my advice would be to get rechargeables, and get 2 sets of batteries so when one set runs down you can put the fresh set in the scanner
Jan 13, 2010 | Uniden BC72XLT Handheld Scanner
Digimax s500 cutting off
BAtteries draws down too quick...
Use 2500 mAh or better for longer life the higher the number...
eveready bunny is sometimes not in all their work
Jul 27, 2009 | Samsung Digimax S500 Digital Camera
How 2 charge a kodak with rechargable batteries!!!
get a charger for the rechargable batteries. Charge the batteries and then put them into the camera. You cant really chare the camera..
May 02, 2009 | Kodak EasyShare C613 Digital Camera
Runs through batteries
Most mp3 players that use batteries that you insert, will run them down very quick. Internal Ion batteries will last from 5-15hours when playing music. If you are using the video feature, 1-5 hours.
Dec 18, 2008 | TruTech SMP-1 GBL MP3 Player
Flat batteries
a well known problem , this camera eats batteries there are high power (2950MaH) accus , those should be used with this camera even with 2700 MaH it is empty real quick
Mar 04, 2008 | Fuji FinePix S7000 Digital Camera
Kodak EasyShare C875 Digital Camera Logo
97 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
