Question about Freezers
Can I switch on a freezer immediately after moving it ?
Can I switch on a freezer immediately after moving it?
  • 614 Answers
Yes you can switch on your freezer after moving it. Just make sure you give it time to get down to temp. before you stock it. Rus
Posted on Jul 14, 2009
Why is the temperature alarm light on, on my freezer Model# FFU21M8CW?
Good Afternoon Friend,
I understand that the temperature alarm light is on for your Frigidaire freezer, model# FFU21M8CW. This feature is designed to provide a warning of a possible malfunction. If the temperature of the food rises to a level unsafe for long-term storage, the buzzer will sound. The red light, if equipped, will also glow. The Temp Alarm feature operates on household electricity. If power fails, the alarm will not function. An ON/OFF switch allows you to deactivate the Temp Alarm when not wanted. Your freezer is shipped with the Temp Alarm in the OFF position. After your freezer has run approximately 4 hours, the red light, if equipped, will go off. Then you may activate the Temp Alarm without the alarm sounding. Press the ON switch to activate the Temp Alarm. To deactivate, press the OFF switch. If the alarm sounds, be sure freezer is properly leveled, and the door closes freely, and seals properly. If you suspect a technical malfunction, call an authorized servicer immediately. Hope this is helpful.
-Best Regards-
WP
Jun 24, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
J2GF-40S ColdTech display freezer merchandiser no lights come on
Sounds like a loose wire since the move. Check you have power at the switch (in and out). If you have, check the starters and ballasts
Apr 14, 2012 | Coldtech 40 cu. ft. / 1133 liter...
My freezer has power, but the fans are not going on when the door shuts and the temperature is rising.
The defrost termination/ fan delay control is a temperature-activated, single pole-double throw switch. ).
The control is wired into the refrigeration circuit. The control is located high on the evaporator where the frost is likely to clear last. The function of this temperature-activated switch is to terminate defrost when the evaporator coil has been defrosted, and to delay the evaporator fans from coming on immediately after defrost.
The coil must reach a temperature of 25* F. for the fan delay to close allowing the fans to operate.bobicehouse_38.jpg
Jul 22, 2011 | True 49 cu. ft. / 1388 liter Commercial...
We sold a freezer, it was working at the time. The person got it home and plugged it in immediately and left it running for 8 hrs, before contacting us to say that it wasn't cooling. We suggested they...
if they moved it on it's side they damaged the compressor,the machine shouldn't be laid on it's side.if they let it sit for a few days it might have recovered.if it wasn't laid on it's side a wire could have been knocked off somewhere,hard to say without being there to look at it.
Apr 09, 2011 | Amana 19.7 cu. ft. / 558 liter Upright...
There is a switch on the bottom under the door by the floor vent thing, and a light on both sides of it, what does this switch do?
That switch allows a temprature alarm to work or not to work depending on which way it is switched. That way you have time to move your contents when the temprature gets above freezing in the freezer. Please make coment and rate me and my knowledge if this answers your question. Thanks
Sep 05, 2010 | Kenmore 17.1 cu. ft. / 484 liter Upright...
I have a small Holiday upright freezer and I am moving and packed the instructions to defrost...Any help on best way to defrost for move?
switch off,with door open let it defrost naturally...if you have time dry out as best you can and using bicarb wipeout interior(dries and deoderises.then tape up door to stop it opening in transit.
Feb 22, 2010 | Freezers
Kelvinator fridge freezer is a geiger counter
something could have fallen into the fan between the two compartments
Nov 10, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
Whirlpool sidexside m-gd25dq does not cool properly
Sounds like bad cold control. Replace it. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 15, 2008 | Whirlpool 19.6 cu. ft. Upright Freezer...
We recently moved it and it stopped working
check the start switch that is on the side of the compressor, it may have been jarred loose.
Jun 28, 2008 | Kenmore 20.6 cu. ft. Upright Freezer 24092
ARISTON FRIDGE FREEZER MBA 3842C PROBLEM
It should work the same as before. Does the compressor get really hot after running a while? If so it could be low on charge, or there could be a restriction inside the refrigeration system. Either way a professional would have to look at it.
Jan 07, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Freezers Logo
69 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
