Question about Sharp AL-1642CS Copier
TABLE SLIDE ON A AL-1642CS DOES'NT SLIDE
WHEN THE START BUTTON IS PUSHED THE SLIDE DOES NOT MOVE ANY I HAV 2 OF THESE WITH THE SAME PROBLEM.ANY IMPUT OR SOLUTIONS WOULD BE APPRECIATED.
  • JOHNWSC Nov 17, 2007
    ALSO CHECKED THE HEAD LOCK SWITCH AND IT IS UNLOCKED
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sharp Master
  • 1,362 Answers
Can you hear anything moving or turning ? The motor or clutch may have gone bad
Posted on Nov 19, 2007
I have the sharp al-1642CS and need to print ups full sheet labels for shipping. Tray 1 will not pick up the labels and jams. I can not get the sharp to print via the multi-tray when I send a job from my...
Will the tray not pick them up at all, or do they feed out about 2 inches? If they feed out of the tray and will not get past the curved area you need to open that door where the jam is and make the spring pressure on those springs on each side tighter. I kind of loop the bottom hook of the spring up into the rest of the spring to create more spring pressure on the rolls and then it should work.
May 19, 2010 | Sharp AL-1642CS Copier
I have a sharp al-1642cs that will not work it just keep flashing L1 can you help
www.cyberscholar.com/sharp/resources/cop_man_soho_AL1642CS.pdf
http://www.service-docs.com/store/catalogue.php?cat=281&exp=0&resultpage=10 L1 00 Feeding is not completed L1 00 Feeding is not completed
within the specified time
after starting feeding.
(The scan head locking
switch is locked)
1.unlock Scanner unit
2. chang connecter
Scanner unit
May 09, 2010 | Sharp AL-1642CS Copier
On line button on copier
it must be shared for all to access. The online button can be pressed to stop the print process when adding paper or toner.
Feb 17, 2010 | Sharp AL-1642CS Copier
Error code h4 on sharp al-1642cs
I have a solution for this posted in the tips section. Just search for Sharp AL H4
Jan 16, 2010 | Sharp AL-1642CS Copier
I have a Sharp AL- 1642CS - broken transfer wire
so does that mean that you were getting blank copies and the transfer wire is broken?
Jun 25, 2009 | Sharp AL-1642CS Copier
Sharp AL-1642CS Copier, the scanner is jammed
Not familiar with that model but what I would try is to turn off the copier remove the glass and try moving it by hand, then turn it on and see what happens it may have a bad motor
Oct 29, 2008 | Sharp AL-1642CS Copier
Reset the drum on a sharp al 1661
Press c interrupt c interrupt within 15sec display goes off enter 24 press start button enter 7 press start button 000 blinks press ca to exit from the program or restart the machine.
Oct 21, 2008 | Sharp AL-1642CS Copier
Tray 1 is full on my Sharp AL-1642CS but when it ties to print to tray 1 the 'P' keeps flashing!
pull both trays out.....have a look in tray 2, is there a switch sensor actuator hanging down yes........is there a similar one in tray one?
No? They get knocked off and lost very easily
Jun 11, 2008 | Sharp AL-1642CS Copier
Sharp al-1642cs
if scanner is not going all the way back you need to ck the home posinson senser it may be dirty.
Feb 05, 2008 | Sharp AL-1642CS Copier
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
