Dell A960 All-In-One InkJet Printer Logo
AbdelRhman Hashem Posted on Dec 28, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I use automatic feeder? Is the auto feeder the way to make a single pdf from several page document
  • Official Brand Answer 560 Answers
  • Posted on Dec 29, 2015
DellCares
Level 0:
Answers
560
Questions
0
Helped
102080
Points
1292
AbdelRhman Hashem,
You can click the link below to download the online users manual for information on the automatic feeder. For information on creating a PDF you may need to refer to the PDF program help file or user manual.
http://dell.to/1PuLpFK
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Multiple pages feed when printing on hp 7410
  • If the automatic document feeder (ADF) does not pick up any pages at all, the rollers inside the automatic document feeder need to be cleaned.
  • If the automatic document feeder picks up multiple pages instead of single sheets, the separator pad inside the automatic document feeder needs to be cleaned.
SolutionLoad one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.note.pngNOTE:If the automatic document feeder does not pick up the plain paper, try cleaning the front roller. Wipe the roller with a soft lint-free cloth dampened with distilled water. If the problem persists, or the automatic document feeder does not pick up the plain paper, clean the rollers and separator pad manually. Follow the procedures below to remove the face plate from the front of the automatic document feeder, access the pick assembly inside the automatic document feeder, clean the rollers or separator pad, and then reattach the face plate.
Please Click on this link to know more in detail.
Thanks
2answers
How do i scan multiple pages and sav it to my documents. It seems like i am only able to scan and save one page at a time
Hi
If you have a Top feeder on the scanner, you can scan mutiple pages. Change the setting of the scanned file to pdf file (not JPEG) by going to the scanner icon and change the type of file you want to scan. Scan it as PDF FILE and then it will scan multiple pages. Regards
3helpful
2answers
How do I scan more than one page at a time so I have a complete document of 6 pages instead of having 6 different document
you either select add a page, or use the document feeder. The document feeder will try to scan all pages into one file.
1helpful
How to fax
Load an original in the automatic document feeder (ADF)
You can copy, scan, or fax a single or multiple-page A4, letter, or legal-size document by
placing it in the document feeder tray.
The document feeder tray holds a maximum of 20 sheets of letter or A4-size paper or 15
sheets of legal-size paper.
To send a basic fax from the control panel
1.
Load your originals. For additional information, see Load originals.
2. Enter the fax number by using the keypad, press Speed Dial or a one-touch speed
dial button to select a speed dial, or press Redial/Pause to redial the last number
dialed.
TIP: To add a pause in the fax number you are entering, press Redial/Pause,
or press the Symbols (*) button repeatedly, until a dash (-) appears on the display.
3. Press START FAX Black.
If the device detects an original loaded in the automatic document feeder, it
sends the document to the number you entered.
TIP: If the recipient reports issues with the quality of the fax you sent, you can
try changing the resolution or contrast of your fax.
for further refernce check out the online manual
http://h10032.www1.hp.com/ctg/Manual/c01181836.pdf
2helpful
Using automatic feeder to scan a multiple page doc into 1 PDF
Yes you can scan up to 30 files in one pdf , and you have to put documents in auto feeder (face up) and from the pc, scan menu, scan to files, select destination and extension.
That's all
Automatic document feeder
U need to check whether the flap-exit is working or not.
http://img.photobucket.com/albums/v390/anthonydidi/flap_exit.jpg
1helpful
Brother MFC420cn Document Scanning
Yes, you save it to a pdf file. Configure scan to file to save as pdf, and it will create a single file
Brother MFC-465CN How can we scan multiple documents?
Make a stack of the documents you want to scan and load them in the automatic feeder: The page to scan facing upward, and the top of the page inside. Press the Scan button and start (color or black).
If you choose the pdf format, you will have them in a single file.
Hopr it helps.
MFC-9440 CN--Lines in my auto feed scanned/faxed copies
clean the thin strip of glass located under the document feeder with something non abrasive
My Canon MF3240 picks up too much paper and causes a paper jam every time I print.
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
