Question about Kenmore Grilling
Uneven cooking surface
I have a 5 burner grill and the far 2 left burners burn my food, while the far 2 right burners dont even cook at all. What do I do to fix this? Right side reads around 600 degrees, left side reads around 400 degrees.
  • 7 Answers
SOURCE: grill
http://www.fiestagasgrills.com/customer.support/content/manuals.html
Posted on May 12, 2009
  • 9 Answers
SOURCE: gas burners heat unevenly
I had a similar problem. I took off the burner heat deflectors and seen gaping holes in the burner tubes. Get your model number and serial number and call Weber. Most Ducane grills have a 5 year warranty on the burner tubes. They will ship them free if under warranty!
Posted on Jun 26, 2009
cadesertmax
  • 274 Answers
SOURCE: How do I take my Weber Genesis grill apart to
Turn on just one burner, once it is lit, turn on a second burner, if the flame gets lower or goes out, you probably need a new regulator.
Posted on Jan 10, 2010
  • 9 Answers
SOURCE: I now have a 3 burner weber gas grill and am
Well, I personally, wouldn't want to go from a 3-burner to a 2-burner because I think Weber designed the 3-burner grill to perfection, and as you know, all you have to do is turn off the middle burner.
At any rate, indirect is harder with the two-burner because of the placement of the burners. You can try to put some 1" thick ceramic bricks directly on the flavorizer bars in the middle, or if you are using a rotisserie, put a pan under your meat.
Posted on Aug 12, 2010
  • 8 Answers
SOURCE: I have a 3 burner spirit grill. I can light the
Charcoal and grease build up can restrict even the best gas burners , my suggestion is to clean your gas burners with a burner tip tool . You can purchase these at Lowes or Menards . Here is a website for you to visit to get the ideal . http://www.metaltech.com.sa/victor/tips.htm
Goodluck
Electrician by Trade
Posted on Feb 20, 2011
How do I cook ribeye steak
on the grill! get yourself nice dryrub at your local food store and throw it the grill. i dont let my temp get higher then 300 i cook them low and slow!
Dec 08, 2014 | Grilling
How do we fix a gas grill that doesn't cook evenly
Usually if you're have hot and cold spots, it's the burners that need to be removed and thoroughly cleaned. In addition, cleaning the venturi valves while the burners are out, is equally important. The Venturi valves are part of each burner. You will see them near the open end of the burner (looks like 2 slots cut into each side of the burner) where it fits over the burner orifice. While the burners are out, closely inspect each one for corrosion or rust thru. If you find severe corrosion or rust thru, the burner(s) should be replaced.
Hope this helped you troubleshoot and solve the problem. Happy Grilling!!
Jul 04, 2011 | Weber 3820301 Gas Grill
I have a 3 burner spirit grill. I can light the grill, but only burner 3 gives me a nice even line of blue flame. Burner 2 seems to be the worst with oranges flames on the right and left end. Burner 1...
Goodluck
Feb 18, 2011 | Weber Spirit? E-310 Propane Grill
I now have a 3 burner weber gas grill and am thinking of buying a 2 burner weber gas grill - how do you use indirect cooking on the 2 burner grill - will there be one burner that is turned off under the...
Aug 06, 2010 | Weber Genesis Silver B Grill
My Kenmore grill that was purchased maybe 6 weeks ago, burns all of our food in min. even on lowest setting. Sometimes the food is burnt outside but not quite dont inside.
you have a multi burner grill start out grilling direct then move to indirect to finish food turn off burners that are directly under food
Aug 03, 2009 | Kenmore 700 sq. in. Cooking Area Gas Grill...
All 4 burners stopped working - circuit breaker ok
How old is this cook top stove? Does it require replacement?
Jun 11, 2017 | GE 30 in. JP385 Electric Cooktop
Sputtering grill
I have a TEC Pattio II. I have owned the grill for almost 10 years and TEC grills have a ten year warranty on many of the parts including the burners. The burners on my grill have a ceramic inserts. The pop and loud whooshing noises indicate the ceramic insert or the seal on the burner is "cracked". I have replaced both of the inserts and burners on my grill once about 5 years ago under warranty. I have one burner now that will not stay burning and I contacted TEC today regarding the problem, and I will replace the ceramic insert only under warranty. .
The newest TEC grills like yours have the TEC Radiant Glass Infra-red Cooking System with stainless steel burners with glass surfaces. I assumed this burner system had eliminated the problem of the burners going out with a loud boom or sputtering.
YOUR ONLY OPTION IS TO CONTACT THE CUSTOMER SERVICE GROUP AT TEC. THE TELEPHONE NUMBER IS 1-800-331-0097. TEC IS LOCATED IN COLUMBIA SC. TEC HAS A USEFUL WEBSITE.
May 01, 2008 | Tec RadiantWave Grill
Burner on range will not turn off
Look at the back of your range there should be schemetic for your power control board. look for defective burner wire going into relay. There should be 5 relays in rows. Realy is the problem. I had the same problem with my front left burner stuck on high.
After replacing everything works okay.
Apr 07, 2008 | LG LRE30755 Electric Kitchen Range
Grilling Logo
37 people viewed this question
Top Kenmore Grilling Experts
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Paul Carew
Are you a Kenmore Grilling Expert? Answer questions, earn points and help others
