Question about Car Audio & Video
No sound from radio since replacing battery - Car Audio & Video
  • bikingben Jul 14, 2009
    yes-Had an ideal that it was a theft deterrant issue but was trying to get around having the dealer scan the entertainment system.
  • 583 Answers
This is the common problem faced by many users.the only solution is to enter the reset code.many buyers get this code while buying the radio as they are aware of this problem in future.this does not occurs everytime you replace the battery but sometimes when this occurs the code needs to be reentered.the dealer only has this reset code. You need to get the code from the dealer. Actually, in your case you might have to go into the dealership for them to re-set it. If you have the 6 digits on your stereo you can enter it yourself. The dealer should be able to find your code based on the VIN. They might charge a modest admin fee, but most large dealership will do it for free. Oh... you might also have to show proof of ownership D/L and car registration/insurance (with VIN) usually works. many frustrarted users buy new radio instead of this reset code headace.but the dealer provides the code if you provide the required details of car registration. thanks.please do rate the solution.thank you for using fixya.keep updated.
Posted on Jul 14, 2009
No volume from factory radio after replacing a dying battery.
Is their any other problems that showed up after the battery change ?
Feb 10, 2014 | Cars & Trucks
Replaced battery and now radio does't work and sounds don't work
the radio will need a code before it will work again. the rest may be fixed with a reset using a code reader.;
Jan 09, 2014 | 2009 Chevrolet Malibu
My walkie talkie motorola em1000 have buzzing sound when another walkie is talking. and have buzzing sound when pressing the button.
Just a few thoughts: It is possible you have a bad (blown) speaker on the buzzing radio or the radio has another problem.
A few things you might try include: 1) Cleaning your battery contacts, 2) trade batteries with the known good unit and see if the problem is solved, if so replace the battery, 3) check the mic and speaker holes on both units to be certain they are free of debris and/or stickers covering the holes. 4) if none of these solve the problem, then your radio likely needs retired/replaced.
Best regards.
Dec 30, 2013 | Motorola Walkie Talkie 2-Way Radio
HEllo, I have a Motorola Radius CP200. When I
If the sound is continuous, like a long tone humming, it is possible you are on a channel which is not programmed. Try changing your channel knob to a different channel and see if the sound changes.
If the sound is not continous, and only happens upon pressing a button, we are not certain what you are experiencing without seeing the radio first hand.
If it were the battery you would get a low battery beep and then the radio would shut itself down. This can happen from a bad battery or a low battery. If this were the situation, you should check your charger and be certain the light comes on and stays on when the radio is placed on the charger. (Note: your radio should always be turned off when on the charger.) A quick test would be to swap the battery with a known good radio and see if you have the same problem. If so, you know it is not a battery or charging problem.
If none of these items help, send or bring the radio to a Motorola repair shop for a quick analysis.
Best regards.
Aug 21, 2013 | Motorola CP200 Two Way Radio
Car radio has no sound
When you have no sound on the radio the first thing to checkl is the speakers. Using the smallest voltage battery you can get hold of and handle easily (AA or AAA) conect +(ve) and -(ve) terminals of the battery to the 2 speaker connections. If the spreaker is OK it will produce a cacling sound. If non, replace.
If speakers are OK the trace connection from radio/amp to speakers. If OK then radio needs attention.
Aug 29, 2012 | Mercedes-Benz Cars & Trucks
Replaced factory radio one week ago with
sounds like its wired up wrong, remove the radio unplug the connector and remove the radio, then check all your fuses must have blown one when radio was installed, after that charge battery and with radio removed see if battery goes dead, if not recheck wiring to radio, common problem with vw aftermarket radio,they are installed wrong,good luck,
Nov 16, 2009 | 2003 Volkswagen New Beetle Convertible
Schelg
You either have a radio problem or a battery problem. Try switching the battery out of another radio into this one to see if the problem goes away. If not, you have a radio problem. (The Motorola Spirit GT is a non-repairable unit.) If the battery solves the problem, you can purchase a replacement battery online or through your local Motorola dealer. Part number HNN9720 or 53720A. Squelching is a normal sign of a failing battery.
Jun 22, 2009 | Motorola GT Radio Battery
Radio does not work after replacing battery
replace radio ,sounds like you flashed the battery the wrong way around and you have killed it
Feb 02, 2009 | 2006 Kia Rio
Car Audio & Video Logo
29 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
