Question about Magellan Maestro 4040 GPS Receiver
It turns on, can put in address but nothing happens after that< stuck on last directions.
    President:
  • 1,111 Answers
The latest update will fix that problem. bo to the link below and select your model and download the update. you need to register the gps on the magellan site before they will let you download anything. bill
Posted on Aug 22, 2009
Targa Visionary LT 3220 television is stuck on mute. tried pressing mute button on remote but nothing happens.
Unplug the TV for 5 minutes and see if it clears. Is there a mute message icon on the TV screen (picture of a tiny speaker with a line through it)? It turns off anytime the volume control is touched automatically, so if that doesn't happen you have a problem with the TV itself.
Aug 18, 2016 | Televison & Video
Dell inspiron one touch screen stuck in diagnostic mode
HI,
You were correct in pressing ctrl+f11 but perhaps you did not press at the correct time. If in following these first two steps you do not get the recovery console, it may not have been installed on your computer.
1 Turn on the computer.
2 When the Dell splash screen appears during the computer startup process, press and hold <Ctrl> and then press <F11>. Then, release both keys at the same time.
3 In the Dell PC Restore by Symantec window, clickRestore. Alternatively, press <Tab> to highlightRestore, and then press <Enter>.
4 When a warning message appears stating that all data will be lost, click Confirm, or press <Tab> to highlight Confirm and then press <Enter>.
The Progress window will appear. Once the restore process starts, Dell PC Restore by Symantec usually takes about 8 to 10 minutes to finish.
When the restore process is complete, the following message will appear:
The system recovery process was successful.
5 Click Finish or press <Tab> to highlight Finish and then press <Enter> to restart the computer.
The software is now installed as it was when the computer was first received.
Thanks.
Computer Support
Feb 19, 2014 | Dell Inspiron Computers & Internet
White lt-13 cruisematic won't start
use jumper cables direct to the starter that will test the starter next jump power to the small wire on the solenoid that will test the solenoid next jumper the safety switches with a paper clip
May 20, 2012 | Garden
My Tomtom is stuck on the last address I put in.
Press and hold the power button down until the unit turns off. it will eventually turn off and this will clear the last address on the display.
if I were you, I would connect it to my pc and update the maps when it comes back on.
Apr 20, 2011 | Tomtom ONE GPS Receiver
Proline Piano Keyboard Stand Assembly Hi, I just bought a Proline piano stand for an electronic keyboard, and the first step on the assembly directions is to move the clutch to the middle position....
Normally on my stand like this you PULL the knob outward (not turn it) to disengage the pin from the plate with the holes in it... Works quite well and the stand is moree stable than many.
Nov 28, 2010 | Pro Line Proline Pl 400 Double X Braced...
I don?t understand the use of pointers in C++
Pointers are variables which store memory address of other variables.
It is denoted by an astrix *
Pointers and normal variables must have same data types.
Need of Pointers:
As said pointers variables store memory addresses of other variables, this can be used when we want to perform some calculations on a variable, we pass the address of this variable to the function from using pointers, thus any changes made to the variable will directly affect the variable as it is pointed to the same memory location.
It can also be for pointing various memory locations e.g. video memory. In the days of Dos we could actually read and write directly on to the video memory using address 0xB8000000 hexa decimal address.
Declaring a pointer:
int a = 10;
int *p = &a;
Here are passing address of a to p. Make sure that the data types should be same.
When we use pointers as arrays, it is much faster then the usual array iterators.
int num[] = {43,52,54,53};
int i=0, *j;
j=&num[0];
while(i<=3) { cout<<"num ["<<i<<"] = "<<*j<<endl; j++; } // This peice of code is faster than following method
for (int i=0;i<=3;++) { cout<<"num ["<<i<<"] = "<<num[i]<<endl; }
As we are directly working on memory.
Pointers are most commonly used to allocate memory dynamically, using new operator.
int *p = new [10];
This code allocates for 10 integer type array dynamically.
Dont forget to release the reserved memory using new operator by delete operator.
delete []p; // Frees the reserved memory.
This is an overview of pointers, as it requires study and practice.
Please rate. Thanks :)
May 09, 2010 | Computers & Internet
How do I switch from mtp to msc?
http://www.fixya.com/support/r3774047-solve_mp3_player_connection_problem <--
copy this address into a new window or tab.
To force your player try this. Sansa e2**v2 1. Turn device OFF. 2. Slide the hold switch to the direction of the headphone jack so an orange color would show putting the device on Hold. 3. Press and hold the ( |<< ) button while connecting the device to the PC.
Feb 24, 2010 | SanDisk Sansa E280 MP3 Player
Power light on, nothing happens
Try holding down the power button for several seconds. This will shut down the PC. You should then be able to reboot the system.
Sep 10, 2009 | Toshiba Satellite A135-S4527 Notebook
Magellan Maestro 4040 GPS Receiver Logo
47 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
