Question about Kyocera Copystar CS-1820 Black and White Copier
Code 2202 when i try to scan a document to email it give me code 2202
  • 523 Answers
This means the Smtp server settings is wrong.
Posted on Aug 02, 2009
Hello possible to obtain the device reset canon 2202
canon ir 2202 - The Copier Network
www.thecopiernetwork.com > ... > Canon - Black and White
Jul 31, 2014 - 2 posts - ‎2 authors
am facing E0001-000 on new canon ir 2202 ; can any one know how to reset error from this model?
Canon imageRUNNER 2202 - Canon Europe
www.canon-europe.com > For Business > imageRUNNER 2202
The imageRUNNER 2202 is a basic solution to your A3 black and white ... Requestinformation ... Canon's toner and long life drum technology allow users to run theirdevices for longer without the need to often replace consumables. .... We use cookies to provide you with the best possible experience on our website.
Canon iR 2002 2002N 2202N - YouTube
? 1:36
https://www.youtube.com/watch?v=I5ywBlOfwPA
Sep 28, 2014 - Uploaded by Shageesh A
Canon iR 2002 A3 Print, Copy, Scan Canon iR 2002N A3 Print, Copy, Scan, ... How to reset ID and PASSWORD ...
Dec 21, 2015 | Canon Office Equipment & Supplies
Pls help with scanning a document then emailing it. When I place the paper on the scanner, press scan to pc, it scans then displays the message "Scan error. Try scan from computer or see...
you can scan from the computer using hp solution center.look for it's icon on the desktop or on the laptop.double-click on that and it will give you scan options.you scan photos or documents using that program.
if you installed the software cd that came with the printer then you should be able to use solution center
May 26, 2011 | HP PhotoSmart C4480 All-in-One Printer ...
Kyocera 5050 error code 2202
This is an error is indicating a connection error when using the send feature.
Below I have provided some information or for more information download the users guide from the manufatcures website using this link. http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=16088&rid=16313
2101, 2102, 2103, 2201, 2202, 2203, 3101:
The network cable is disconnected or the hub that it is connected to is not operating properly. Check the cable and the hub. Otherwise, the server name or the host name of the SMTP server is
not set correctly. Use COMMAND CENTER and register the SMTP server name and the host name
correctly.
2204: The E-mail size exceeds the acceptable send data capacity. Decrease the size or resolution of the scanned data to be transmitted and resend the E-mail. 5101, 5102, 5103, 5104, 7102, 720f:
Turn the main power switch off and back on. If this error occurs several times, make a note of the displayed error code and contact your service representative.(Refer to the corrective action for the error message " An error has occurred.")
9181: The scanned original exceeds the acceptable number of pages of 999. Send the ecess pages separately.
Hope this is helpful,
Shawn
Mar 11, 2011 | Kyocera Mita KM-5035 Printer
When i email scanned docs from my HP officejet 8500 Plus printer to my email, the pdf's are too large. how do i set them to be emailed at a smaller size.
No problem, you can solve this problem very easily :
Whenever you scan a document directly to your e-mail in a PDF format then printer scans it using its own property and only scans the document without any editing in the font or characters.
But the output i.e. the scanned document in pdf shows the same text using its own properties. That font is selected by pdf and not by the hp software.You can open the scanned pdf file and manually change the font size.
Or else
The best way that I will suggest you :
- First scan the documetn in a pdf file or any format on your computer instead of directly on e-mail.
Because when you scan it to your computer printer will scan the document directly to computer and in this way after scanning you can open and see the document. You can make sure if it is scanned properly or not, however when you scan it to e-mail there are chances when we dont verify if the document is scanned properly or not. If there is any hardware issue or any other error then it will scan half page or a blank page....we wont be able to verify it.
- Also if it is an official document which is half scanned or has some problem in it will give a bad impact on the receiver which is not good for professionals.
- By scanning on computer you can verify the document, can make required changes and will be able to send the document in a proper way. It is going to take few seconds but results will be fruitful....try it..!!! I do the same way and there is not much difference
Feb 26, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
I have a KM 4050 and when we scan it is giving a "send error 2101" Everything else is fine. We are able to print from our computers etc. so I know our connections are ok. Any suggestions?
The following errors are simalir;
2101, 2102, 2201, 2202, 2203, 3101:
The network cable is disconnected or the hub that it is connected to is not operating properly. Check the cable and the hub. Otherwise, the server name or the host name of the SMTP server is not set correctly. Use COMMAND CENTER and register the SMTP server name and the host name correctly.
The link below takes you to Kyocera's Scan to SMB setup guide on GFBM's website (they are a Kyocera dealer). The guide setup guide is good and gives pictures and examples.
http://gfbm.net/Documents/self_help/SCAN%20TO%20SMB%20PC%20setup%20R3.pdf
I hope this is helpful,
Shawn
Feb 11, 2011 | Kyocera Copystar CS-1820 Black and White...
HOW DO YOU SCAN A DOCUMENT INTO YOUR E MAIL?
boberin3, can you please expand your question and give us the full information as there are too many variables for us to give a definitive answer to this question.
please advise what email program for a start and what you are trying to do.
If my thinking about what you're trying to do is correct then I'll have to say you cannot actually scan a document into an email but scan it to your computer and attach it to the email.
If you want the text of a document to be the email then you need to scan it to a word processor, then copy it and paste it into the email or email direct from the word processor if it has that facility and you use an email program such as Outlook.
Apr 28, 2010 | Lexmark C533DN InkJet Printer
I am trying to scan a document to email
In most cases, you want to scan to file and save the file in a folder of your choice. I have a 7310 xi all in one and I have a folder on my desktop named scans. When I scan a pic or document I save it as a jpg (pic) file or a PDF (document) file to that folder. Then when I email someone, I attach the file using the attach button on the email page.
Aug 31, 2009 | Epson Stylus CX3200 All-In-One InkJet...
How do you scan and email a document on the HP Deskjet F4200?
Just open an email & address it as usuall, now, at the top of the email you will see an icon that looks like a peperclip, click on that, a box opens & you just navigate to the file using the browse button. When you click on the file it will show up in your email uner 'subject'. If you don't see a paperclip then look for the word 'insert', this will do the same thing. Good luck. If this helps you plz rate this 'fixya'. If you need further help leave a comment & I'll be happy to walk you through it. Thank you kindly.
Feb 14, 2009 | Office Equipment & Supplies
I want to scan and email a document from my new HP DESKJET F4280 printer. I can scan it, and then I try to share it, but when I hit the send button it says there is no internet connection. Am I right in...
When you scan a document it must be scanned with OCR software. The default scanning method will scan a document as a picture, not a document with letters and words. The OCR software will recognize the letters and put the scanned document in the proper format to open it with MS Word. The software that you scan with should have a setting for OCR, read your instructions or help files to get the details if you can not find them very easy in the software you use for scanning. .
The problem with using Outlook may be that you have not set it up properly to get your emails from your email server. You do not need to use Outlook or Outlook express to send any documents, you can use your web based email server if you like, but you can use Outlook Express as well. You just need to add the document to send as an attachment to the email.
To set up Outlook Express to get your email, you must first find out what the POP3 and SMTP setting you must use. You can get that information from your email provider, it is different for every email provider. Then you go to the "File" menu at the top left of Outlook Express and select "Identities" and select "Add New Identity" and from there you will go thru a wizard to guide you thru the process of setting up your email client. Just make sure you have the POP3 and SMTP settings available for you to put into Outlook Express when prompted to in the wizard.
Dave
Nov 13, 2008 | HP Computers & Internet
Faxing/scanning from AIO 964
throw it in the dumpster and buy a new one
Mar 03, 2008 | Dell Photo 964 All-In-One InkJet Printer
Kyocera Copystar CS-1820 Black and White Copier Logo
687 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
