Question about Yard Machines Garden
Missing part that goes on hanhle to hold in place when lifting ser no1L204k40246 model 21A395a729 goes on a yard machine tiller with honda 5.10 engine
  • 112 Answers
Customer Service Team at 1-800-269-6215 for further assistance
Posted on Jul 15, 2009
I have a Yard Machrines by MTD Yard & Garden Cultivator 31cc: Model No.21A-121R900 Ser.No.1A246DG1150 and I need to replace the primer bulb. How do I do that?
hello l, how to change primmer bulb,,remove the two fuel lines making note which line came off where,use needle nose pliers to push the two ears down and pull bulb out,make note on where the long and short stem was at,go to the mower shop and get a new bulb and install,put lines back on, done start engine,,hope this helps,,
Jan 27, 2012 | Yard Machines Cultivator
I have an MTD Snow Thrower Model 2M1 with a broken starter rope. I replaced the rope but cannot get it to rewind the rope after I pull it. What am I missing when I reinstall the rope and spool?
When you have the starter top removed, you must wind the spring BEFORE installing the rope. Wind the pulley until it is at maximum tension, then unwind it until the hole in the pulley lines up with the eyelet on the starter top. Now, put the rope thru the eyelet and into the pulley hole. It is helpful to have somebody holding the tension on the pulley, or you can insert a small tool thru the vent holes to hold the pulley in place. Use a figure 8 knot on the rope. Go ahead and tie the handle onto the other end of the rope, and release the pulley tension. It should now recoil into the starter housing. Test pull the rope several times to make sure it is moving freely. Reinstall the starter housing onto the engine and retest.
Dec 01, 2010 | Mtd Products Yard Machines 158CC Tiller
How do u change the oil in honda fg110 tiller
The simple way is to take a oil pan and lift the tiller with the plug removed and drain it out while holding over the pan. Dispose of oil properly. I have an older model that does not have an oil drain plug.
Aug 29, 2010 | Honda 25cc 4-cycle Mini Tiller
Thee is no serial or model no. plate on my mtd yard machine tiller. I need a diagram of the gear mechanism, when I split it apart all the gears a nd chain fell out.
Had the same problem with my MTD Yard Machines 5 horse tiller. I called MTD at 800-800-7310 and with the model and serial and such off the engine - which are stamped into it - a nice lady was able to narrow down my tiller year. From there with horsepower details she narrowed further to one of two models that I could look up on the MTD corporate home page and get a schematic.
Hope that helps.
Jun 17, 2010 | Mtd Products Yard Machines 158CC Tiller
Need to obtain a new belt and pull rope for my Tiller
you can get a pull rope at wal-mart.measure the belt and any parts store or place that sells lawnmower belts should have one.if the rope broke close to the end knot just pull the end knot with some needle nose pliers.once you have all the old rope out lay the old rope pieces on the ground and cut the new rope to match it as far as length.turn the pulley that the pull rope goes in six turns counerclockwise.then turn the slot the knot was in to the hole the pullrope goes thru and fish it thru then pull it up and out with apaiar of needlnose have someone hold the pulley until you tie a small knot in the end of the pullrope the hold the pullrope and let it pull it in.you might have to cut some off at the handle if its still too long.to do this pull some rope out and tie a quick knot so the rope can't slip back if you let it go.
May 27, 2010 | Mtd Products Yard Machines 158CC Tiller
I have a MTD yard machine rear tine tiller. Goes forward and reverse but tines wont rotate. How do I fix?
You will have to get into the gearbox. It isn't too hard but is time consuming. Sounds like the drive for the tiller has broken. Could just be the chain in the gearbox for the tiller drive.
Apr 30, 2010 | Mtd Products Yard Machines 158CC Tiller
The deck will not raise even , the riding lawnmower is a MTD Yard Machines, and when you raise the deck the left side does as it should, but the right side stays lowered to the ground and will not raise....
There is a pin that has come out of it's holf from the right side of the deck. Have someone raise the deck up and down and you should see a bracket or rod moving up and down. This attaches to the deck with a clevis pin to hold it in place.
HTH
Good Day.
Oct 27, 2009 | Mtd Products Yard Machines 158CC Tiller
Hydrostatic drive problem shooting
My problem. My riding MTD yard machine had a "gross" amount of grass, dirt, and sticks all around all belts, and when I cleared them away, the machine's performance were greatly improved.
Jun 20, 2009 | Mtd Products Yard Machines 158CC Tiller
Garden Logo
93 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
