Question about RIM BlackBerry Curve 8310 Smartphone
"Cannot connect to server" Why?
When I try to log into Yahoo/Aol Messenger it tells me it cannot connect to the server. How do I fix it?
  • 541 Answers
Sir you are typing wrong user id and password.
Posted on Jul 16, 2009
Problems with log in to Yahoo Messenger
Hello. You can probably fix this condition by following these steps:
  1. Click on the gear icon in the upper-right of the IE window
  2. Click on Internet Options
  3. Click on the Advanced tab
  4. In the Settings window, scroll all the way down to "Use TLS 1.0" and make sure that is checked.
  5. Click Apply, then OK.
That should fix it for you. This is due to a recent change in how Yahoo handles login requests.
I hope this is helpful.
Jan 25, 2015 | Yahoo Messenger
Connecting to HTTP Virtual IP server 98.139.61.47... [FAILED] How can I fix this? Having problems logging in. Gettin Connection problems.
It seems that your connection to Yahoo Messenger sever is disrupted, maybe being blocked.
Anyway, try to use KarooLark web messenger http://karoolark.com/ if you find you are having connection problem.
Sep 22, 2011 | Yahoo Messenger
I keep getting logged out of yahoo and aol everytime i try to send a message to someone... i have the latest verison of both messengers
Click the "Messenger" menu in Yahoo! Messenger and select "Connection Preferences."
2. Enable the "No network detection" option and then click the "OK" button at the bottom of the window.
3. Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the "OK" button.
4. Enter your Yahoo! ID and password and click the "Sign In" button.
you may have a registry problem download reginout to fix the issue
Apr 27, 2011 | Yahoo Messenger
Help me to solve my problem
Test your account with web messenger by logging in here:
http://webmessenger.yahoo.com/
If this fails, it means that there is a problem with your userid, password or account. Contact Yahoo for assistance.
If this works, then proceed to the next step.
Ensure you have a good stable internet connection.
Uninstall Yahoo Messenger and everything associated with your messenger.
Download the latest version from messenger.yahoo.com.
Try to log in again.
This should work and fix your problem.
Let me know how it works out and don't forget to give me a good rating as well as your vote.
Mar 25, 2010 | Yahoo Messenger
81003004 issue logging into messenger
as far as wat i did to my YM.
i simply checked the connection preferences and turned
"Connect via a proxy server."
then select
"HTTP proxy"
after that take a look at your internet connection dropdown list..
some mistakes are seen here.. instead of having the "broadband" connection selected the "dial-up" connection was chosen by YM itself..
hope that helps ya ^^
Oct 12, 2009 | Yahoo Messenger
Please help me with the proxy settings for yahoo messenger
open messenger
click Messenger on top toolbar
go to preferences
select connection
Make proxy settings
click Apply
click OK
_______________+++++++++___________
If you need a software to hide your ip and do Anonymous surfing here's a free proxy software
Oct 03, 2009 | Yahoo Messenger
Messenger error 81003005
here are some causes: Firstly; this error occurs when your connection preferences are not properly set. I'm not talking about your Yahoo! ID and Password here, but you may need to adjust certain features depending on what network you're on. Let's says for example, if a firewall protects your network, it may block yahoo messenger when it tries to connect to the server. You need to change your connection settings, click the Messenger menu in yahoo messenger and select Connection Preferences. Select Firewall With No Proxies. Select your Internet Connection type from the pull-down menu at the bottom and enter your Home Country if the adoptions aren?t grayed out. Click OK and login again using the new settings. If this option doesn?t work, click Connection Preferences in Yahoo! Messenger again and select No Network Detection. Try to login again using the new settings. In some instances, you may need to provide yahoo messenger with the IP address of your firewall or proxy server (you can get this information from your network administrator or from your Internet service provider). Click Messenger and select Connection Preferences again. Select Use Proxies. Enable either the HTTP Proxy or the SOCKS Proxy as needed and provide the proper address. Click OK and login again using the new settings.Secondly; if you are using IM9 there are sign in problems. This is what yahoo has to say. Try an updated version of Yahoo! Messenger 9.0(9.0.0.2128). This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code?81003005? when trying to sign in, this latest version may fix that problem. Even if you were experiencing a different kind of sign-in issue, I recommend installing this latest version. Hope it was helpful!
Thanks.
Jun 16, 2009 | Yahoo Messenger
Yahoo Problem
try reinstalling the yahoo messenger again,
i too had the same problem ,
and i checked by signing in yahoomail.com to check whether it was a password problem or not, but it was not,
ultimately it was some kind of problem in messenger,
got it fixed bye reinstaling it.
maybe work for you too
Dec 21, 2008 | Yahoo Messenger
Login error 81003004 from Yahoo Messenger
then select
"HTTP proxy"
Dec 16, 2008 | Yahoo Messenger
Webcam not connecting to yahoo messenger
!st, let me explain the problem more clearer, then I'll explain the solution.
Problem) My camera worked fine. Even when logging on to Yahoo messenger, i could still veiw myself when chatting. But when I clicked on the "broadcast" button, the "idle" status would change to "connecting" for a few seconds. Then the the following message would pop up, " The server is busy, Please close this window & try again in a few minutes".
Solution) In Yahoo messenger, click on "Messenger", scroll down & click on "preferences". In Category:, click on "connection". Make sure that "no proxies" is selected.
Jul 01, 2008 | Labtec 961307-0914 Webcam
RIM BlackBerry Curve 8310 Smartphone Logo
231 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
Trisha
Trisha
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
