Question about Metra 95 96 Chevy Truck
How to loosen the serpentine belt in a 1996 chevy k1500
It's making a god awful squeaking sound. The same sound my car made when the serpentine belt was too tight. It's just not the same way to loosen it, I don't think. On my car I loosened it by moving the alternator up and down. But it doesn't look like there's a way to move the alternator in my `96 Chevy K1500 and I don't want to loosen anything too much because I'd rather nothing fall off accidentally! Lol. So I just need to know how to loosen it up just a tiny bit. Thanks.
  • xcyranox Jul 16, 2009
    If there isn't a way to loosen the belt, then how could anyone get it off to replace it or the alternator?
    Honestly, I do believe you are dead wrong.
    Problem Solver:
  • 5 Answers
There is no way to loosen the belt in that chevy. it is a serpentine belt system with a belt tensioner that keeps the correct tension on the belt. check the belt and all the pulleys for wear. if the belt and pulley are in good shape i would suggest changing the belt tensioner.
Posted on Jul 15, 2009
Gm serpentine belt routing
There's a routing diagram sticker under the hood. Look for it on the radiator support , the front shock tower or on the hood itself.
type this on google and see what you get...gmc k1500 serpentine belt routing diagram
Jul 24, 2014 | GMC K1500 Cars & Trucks
Squeaking serpentine belt
Sounds like a bad water pump. Loosen that belt and see if it has any back and forth movement.
Feb 18, 2013 | Cars & Trucks
1996 Blazer: How do install a 1996 chevy blazer serpentine belt...
It will have a diagram right above the fan blades to show you how it needs to be ran. Just need to release some pressure off the belt tensioner to make it all fit
May 16, 2010 | 1996 Chevrolet Blazer
Loose belt
If it is the belt, you need to buy a special tool made to relieve the pressure from the belt tensioner, As you do that the belt will slip off. Don't let anybody tell you that you can use a ratchet and socket to loosen the tension. If your tensioner is not designed to work like that, it will strip the bolt out. While you have the belt off, turn all of the pulleys and make sure that they are not the cause of the squeaking sound. Make sure to memorize where your belt goes, a serpentine belt can be very confusing to put back on if you don't remember how it came off.
Jan 23, 2010 | 2007 Toyota Corolla
Change a serpentine belt on a 1996 chevy cavalier
Diagram should be under the hood
The auto tensioneris down low and dificult to get to.
If it has not been changed in a while you will need a long thin push stick and a serpentine tool.
Push on the belt hard at the auto adjuster and pop the belt off the smooth pully (located top).
hook up the serpentine belt tool and then mount the new belt
Jan 17, 2010 | 1996 Chevrolet Cavalier
High pitched noise coming from pulley system has persisted after
Sounds like the Power Sterring Pump might be starting to go out.
Dec 22, 2009 | 1996 GMC Jimmy
Removal of serpentine belt on a 1996 Buick automobile?
check if it has a tensioner, it look like a useless pully and put a breaker bar on it and pull it and the belt should loosen up, if theres no tensioner the alternator should have bolts to loosen up the belts.
Jun 27, 2009 | 1996 Buick Skylark
Serpentine belt replacement
try using a 3/8 drive ratchet & a cheater pipe over ratchet handle for leverage.make sure its on good if it slips your in for a knuckle buster. good luck
Apr 26, 2009 | 1996 Chevrolet S-10 Pickup
Metra 95 96 Chevy Truck Logo
477 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
