Question about RCA 25201RE1 Corded Phone
When wall mounted- the hand set will not stay on the phone
  • 33 Answers
Look in the packaging, or contact the manufacturer.. there is an adapter for solving this issue.
The adapter attaches to the phone and tilts the phone so the handset does not fall.
Posted on Jul 14, 2009
2 Suggested Answers
SOURCE: wall mounted ge phone
Problem solved. The little black square was supposed to be put back upside down...This allowed the hand held piece to hang on.
thanks
Posted on Aug 06, 2008
Can the base be mounted on the wall? I saw a "yes" answer on a forum, but it did not give info on how to install it to the wall. Set did not include a mount for the wall.
if the base does not have a "modern mount" set of holes in it's back then getting it go on wall is gonna be a chore , one simple trick idea that I did with one in my shop . was to obtain a simple small shelf bracket at the hardware store and mount that to wall and set phone base on that ! they cost about 75 cents a piece and if you mount them upside down (tabs up) the phone base blocks them from view .you cant even see them , a few dots of silicone caulk on them before you set phone base down there and when it dries , im sure your never gonna have a problem with it falling off , now what to do with the wires running down the wall ?????
Jul 29, 2015 | Uniden D1680-4 Dect 6.0 W / Caller Id /...
How do I mount your SN6147 telephone on the wall
On the base unit where the ear part of the handset sits, there should be a movable tab, you should be able to slide this up/forward to hold the phone more securely when wall mounted.
Nov 15, 2014 | Lands Phones
There is usually a small clip that needs to be pulled out and then reinserted the opposite way. Most Unidens either have a built-in wall mount, however or require one from their website to be ordered. This model doesn't show up as valid, however, are there any other identifying marks?
May 26, 2014 | Uniden Cordless Phone
Lifestyle 1910 cannot hear the ringing tone
I Think may problem in your Phone....You can please Call the service provider........
Jan 23, 2011 | Cell Phones
We just purchased new Uniden phones, Model no. DECT1480-4. I was told at the store that I could wall mount it. There was no plate for wall mounting. Can I get one and if so how much is it and where can...
Did you find your solution? You need Uniden wall mount adapter GBCT2B5319Z, but their site lists it as "back-ordered." (I am looking to buy this phone set but, like you, want it wall-mounted, and have not found this mounting adapter in stock on the Web yet.)
Sep 23, 2010 | Uniden Cell Phones
Uniden XDECT 7055 hand set problem
Hope this is solved for you. If not, I found the connection for the battery a little temperamental and had to play with it a bit before the connection worked properly
Jul 01, 2010 | Uniden Cordless Phone
Remove a whirlpool over the range microwave oven
Jim here. In cabinet above microwave, locate 2 mounting bolts.
Place a box on the stove top to support the microwave once the mounting bolts are removed (you may wish to cover the box with a thick towel or small throw rug).
Procedure:
1. Unplug microwave.
2. Remove both mounting bolts from top of microwave (they secure it to the overhead cabinet).
3. With microwave front angled down onto box, pull some of power cord out of hole (to provide some moving space).
4. With microwave hand supported, remove box from stove top (a second set of hands would be helpful here).
5. HARD PART- detach top of microwave back from wall mounting plate by placing a hand under the bottom rear of the microwave and pushing up. (Wall mounting plate is screwed into the wall behind the microwave and provides both top and bottom support to the back of the microwave.)
6. Lower front of microwave until you can see about a 1-inch clearance between the top-rear of the microwave and the cabinet above it.
7. Firmly lift the microwave straight up and then bring forward. It should be free of the wall mounting plate.
Sep 30, 2009 | Maytag MMV4205 Microwave Oven
Screen goes black tv stays on. Turn off and on and TV's fine.
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Mar 20, 2009 | Philips 42PFL3603D/27 42 in. LCD TV
Wall mounted ge phone
thanks
Aug 05, 2008 | GE 29263GE2 Corded Phone
RCA 25201RE1 Corded Phone Logo
114 people viewed this question
Top RCA Lands Phones Experts
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
