This has just started in the past week, and I'm hoping I can catch it early enough to save some money on any repairs. Please help me. The TV flashes quickly then either comes back or cuts off.
SOURCE: power light flashes 3 times
U CAN THRO THE ******* THING BACK AT THE ******* PEOPLE WHO MADE IT!!!!!!!!!1 I GOT THE SAME ******* PROUBLEM AS THE OTHER GUYZ!!!! BUYING A **** N SONY NEVER AGIAN A RCA ********!!!
SOURCE: RCA D52W20 52 in. Rear projection hdtv problems
can you tell me if the light blinks when you press power? If so let me know and I can help you diagnose the problem.
the circuit board behind the power on and off button needs to be replaced very easy fix.. good luck everyone
SOURCE: i own a 52 inch rca projection tv and last week
Most likely the Horizontal output transistor has shorted. When it shorts it causes the power supply to chirp. This is a common problem with this series of TV. Have a shop check it out. It should not be real expensive.
SOURCE: I have a RCA R56wh78 projection power button flashing green.
Thats the classisc sign that the CP150, CP114 and CP120 capacitors need replacement. You can get the repair kit called CP150, CP120 and CP114 at www.tvrepairworld.com which contains the capacitors and the CD with step by step instructions on how to do the repair.
Testimonial: "Thank you. I will try this. I just dont understand why it worked with all of the button pushing on the front of the tv. Is this going to be a hard job"
