Question about Ryobi Cultivator
Fuel line routing. Never clear enough Explaination.
Gas tank has 2 Lines 1thick 1thin. Carb has 2 connections (Walbro)
1 Straight 1 Bent at 90 Degrees. Primer Bulp has 2 connects 1 in and 1 out. Now when all 3 lines disentegrate, The hit and miss connection method is UNCERTAIN at best. Especially when compounded by a dirty or partially clogged port. Runs, stalls PLEASE (My local repair shop couldn't help) Walbro says "To many models to list so here is a generic guide) And Poulan is NO HELP AT ALL> Please provide a diagram or a very specific explaination for EACH HOSE. I can't believe I can not get this info simply.\
I Sincerly THANK anyone, and I mean ANYONE who can relate to the frustration of such a simple yet, if incorrect...Frustrating because you are uncertain if further problems or just connected wrong.
  • 2 more comments
  • Ed Gore Jul 24, 2009
    incomplete help! Useless
  • Ed Gore May 10, 2010
    Do you still need help? I can upload a picture of the SAME EXACT TILLER hose configuration! But...only if you still need it. (LOL Been there done that!only...I simply forgot which was which Haha! I used to be mentally sharp. But at 52 yrs old it now seems to be just "mental") So I know of the "hit and miss" method. And you are right Poulan and walbro are no help, but guess what? The information you need is with them someplace. I happened to find it eventually! Let me know.
    http://www.ereplacementparts.com/images/...
    Here. Try this. Someone here posted it for another similar issue.
  • 112 Answers
Need brand name of your unit, but reading what you have I will say that the thick one from tank goes to carb and the thin one goes from primer bulb to tank as a return, for fuel. need more info!!
Posted on Jul 15, 2009
Need diagram of fuel lines from tank to primer bulb and carburator on a Poland chainsaw model 1950 wood shark
There are 7 different types of the 1950 model (types 1 - 7) and it came with one of these 2 carbs Walbro or Zama. The carbs are different as are the fuel line connections for each one.
Although this video is for the promer bulb you can see the routing of the fuel lines.
http://www.ereplacementparts.com/article/4262/How_to_Replace_a_Primer_Bulb.html
You will have one line from the fuel tank connecting to primer bulb the 2nd line going to the carb. If you connect it backward it does not pump fuel into the carb.
Kelly
(FYI Types 1 - 5 all have the same fuel line routing.)
Apr 12, 2011 | Poulan Pro 14" Gas Chainsaw 33CC P3314
Which fuel line "port/inlet" on the Walbro wt-380 goes to the fuel tank? It's on a Craftsman 25cc Gas "Weed Wacker" Line Trimmer purchased in 2002. It has Walbro WT-380 carburetor with external primer...
Usually the line with the filter on it that comes from the tank goes to carb. inlet first which is most likely close to the bottom side of the carb.nearest to the engine,then the outlet or return line on the carb.goes to the inlet side of the primer and the outlet side of the primer goes back to the tank. The primer draws fuel through the carb to the primer to the tank if its not? then correct the line connections until it does
Jun 25, 2010 | Craftsman 25cc Gas Line Trimmer
Craftsman Brush Wacker routing of fuel lines Model 358-795200 Was laying in bottom of top mount gas tank
Use new fuel line. There should be two things (besides fuel line) in the fuel tank. The small line has a (1) fuel filter attached and is routed to the lower outlet on the carb. This is the fuel supply line. Make sure there are a few inches of it inside the tank. (say enough to reach other side of tank). The larger line should have a (2) nylon connector inside the tank holding it. The connector stays right at the tank hole. That larger line goes to the closest outlet on the purge bulb. The other fitting on the purge bulb should have a larger line that connects to the upper fitting on the carb.
Feed enough length of fuel line thru tank holes to pull them out where cap is to put on the filter and nylon connector...then pull them back thru. WD-40 will aid in this procedure or any light oil.
Jun 10, 2010 | Craftsman Garden
String trimmer, fuel lines disintegrated, I need routing.
The Walbro has two connections on it for the fuel line. My Walbro has one connection on the side of the idle screw and main fuel adjusting screw. This connection hooks up to the suction side of the primer bulb. Usually the shorter stem. (You actually **** fuel through the carb instead of pushing it through.) On the other side of the carb is the other hook up. It draws fuel from the tank. This line will connect to the side of the tank that has the filter. The other side of the tank is your return and it hooks to the other connection on the primer bulb. Usually the longer stem.
Apr 17, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
McCulloch 3216 fuel primer and gas tubes routing?
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, the output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs will help with reassembly. HTH
Lou
Nov 01, 2009 | McCulloch Garden
Poulan chainsaw gas line routing?
There ARE two holes in the tank. One samll and another larger. One is on the left side and the other is on the right. Look carefully and you'll find them. As far as connections of the fuel lines:
The line from the fuel filter in the tank goes directly through the small hole in the tank to the top nipple on the carb thus giving the carb a constant supply of fuel when running. The primer bulb is used only for "priming" and does not play a part in the fuel flow after that function. The bottom nipple on then carb then goes back to the nipple on the primer bulb which is clearly marked "Carb". The above connections are made with the smaller diameter tubing. From the primer bulb, marked "Tank", the larger diameter tubing is routed to the large hole in the tank. The tubing goes into the tank only 1/2 to 3/4 inch. As far as getting the tubing through the holes in the tank, cutting the tubing at a slant. But no matter what you do it is still a witch. Be patient, use some Vaseline and avoid the temptation to get out the drill and **** the hole to a larger size.
Aug 30, 2009 | Garden
Walbro WA219b carb
Go to www.searspartsdirect.com and with your model number you should be able to find explode parts views of that trimmer. Filtered line to primer, primer to straight inlet on carb, angled outlet on carb back to tank. That might work. Not sure without part number.
Aug 02, 2009 | Craftsman 25cc Gas Line Trimmer
Where do I connect the fuel lines on my ryobi weedeater?
I have Ryobi775r string trimmer with walbro WT526 carb. The fuel lines connect 3 parts eg. gas tank, bulb (mine is a separate bulb not part of carb.) and the carb. The bulb has 2 fittings- a short and a long one. The carb also has 2 fittings- one on top (vertcle) and one on the bottom (L shape). The gas tank has two holes in the bottom one for over flow line and the other for fuel inlet to the carb. This has a filter in the gas tank. Now the connections- connect the long fitting on bulb to the tank. this is the overflow. Connect the short fittin on bulb to the carb top (verticle) fitting. Connect the fuel line (with filter - it is in the tank) streight to the L fitting on the bottom of the carb. Make sure the fuel lines are of right diameter. Too big-and you will have leaks. You are done connecting the fuel lines. just for info. the bulb is there just to pull a vavcume in carb so that the fuel is sucked into the carb and is present there when you start the engine. Hope it helps. Good luck.
Jul 07, 2009 | Ryobi Garden
Replacing fuel tank on craftsman edger and other fuel lines.......do not understand where to hook fuel lines back up?  any diagrams?
ok If you have a Walbro WT series carb "without" a built on primer bulb here it is. First off if the fuel lines disintegrated you MUST disassemble it and clean it out. The MOST infintesimle speck of gas line trapped, can allow good prime and bad operation. OK? Don't be lazy on this. Just be delicate removing the flaps gasket and diaphram. ZAMA GND-12 Is the replacement Gasket and diaphram kit fot that carb. Use a cleaner, compressed air or blow good thru it. OK Now...Primer bulb, Carb, and Fuel tank, re connects: Smaller Diameter line comes from Gas tank (Connect filter screen to this in tank) to the short Straight brass carb connector. Primer bulb suction goes to the bent carb brass connector. If small line brings fuel "in" this other line sucks it back "Thru the primer bulb" and the blow side of the primer bulb sends it back to the fuel tank! So...Small Line brings fuel "TO/IN" carb thru short brass connect on carb. Other carb connect goes to bulb suction "IN", Then primer bulb "Pressure OUT" goes thru the larger tube "back to fuel tank". Trust me I know how frustrating a simple diagram is to find online fo this set up. And if you have a carb problem on top of the hook up uncertainty you got frustration. Not only was online help hard to find (Mfg...etc NFG at all!) My local repairshop in BBrook NJ could not tell me how!!! and thats no lie! Walbro has a "generic" carb diagram but no "hook up info" specifically. Poulan don't list it either. And these things routinly fall to pcs. all 3 of mine crumpled together on yr. 3 of use.
Jun 15, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Ryobi Cultivator 410r
The linefrom the tank with the filter goes to the mixture inlet on carb. The fuel return goes to the suction side of bulb. The bulb outlet line goes to the tank. Hopes this helps
Mar 19, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Ryobi Cultivator Logo
1,093 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
