Question about Samsung HPT5054 50 in. HD-Ready Plasma Television
46" Samsung LCD, no sound output whatsoever
46" Samsung LCD. Was working fine for 6 months. Just had PC connected for e few hours (have in past) working fine, suddenly the TV has no sound output at all. Not to the internal speakers, not thru the external RCA's to the surround sound, nothing.
Not muted, speakers are on, checked all and reset sound settings, unplugged tv, did a little dance...
As I post this, I await my ex-g/f to get home to tell her her newish TV is screwy. It'll make a nice 46" PC monitor I suppose... lol
  • 304 Answers
First try hooking up a different source such as a DVD player or Cable box and see if you have audio. If you do then check the audio output from the computer. If you do not have audio then make sure the tv audio is up half way and turn off the set. When you do this you should hear the down chime provided you have the chime turned "on". If you do not hear the down or up chime then the sudio circuits on the Main bd are bad and the Main bd will have to be replaced. A quick way to check to see if the audio circuits are working is to listen for the up or down chime when turning on of off the set coming from the tv speakers speakers.
Posted on Jul 16, 2009
  • Zach Lyons Nov 06, 2013
    This didn't solve it for me. Still no sound at all. I've reset the tv 3 times too
Westinghouse ltv-46w1 has picture but no sound
check to see if same with a DVD etc connected to the rear inputs, if no sound the main board creates, controls and outputs audio.
check also with the maker to see if this is a known issue in this model.
Sep 02, 2012 | Westinghouse LTV-46w1 HD 46 in. LCD...
I have a Samsung Series 6-650 LCD TV (Model # LN46A650A1F). I am trying to connect my Laptop to use the TV as a monitor and have done everything to make it work, using a VGA/HDMI cable, but the TV refuses...
Why do you use VGA-HDMI cable? This TV works fine with VGA cable - it has VGA plug.
Or if your notebook has DVI output, then you can use DVI/HDMI cable and connect it to the TV to plug named DVI/HDMI (only one HDMI input is marked as DVI on TV).
I suppose that over HDMI the TV supports only some standard resolutions, but over VGA it supports almost every resolution laptops use. You can find supported resolutions for each input in the TV manual. Try setting the same resolution on the laptop.
Feb 28, 2010 | Samsung LN46A650 46 in. LCD HDTV
My TV clicks on an off very rapidly when I first
if its a samsung lcd  tv  then goto
www.earthinfo.org/samsung-tv-makes-a-strange-clicking-sound
shows you how to fix it yourself for 'peanuts'
Jul 18, 2009 | Samsung LN-T4665F 46 in. LCD Television
Same exact problem- music player works fine with headphones
If you had a bluetooth device connected and it did not disconnect properly then the phone may be trying to play the sounds to the bluetooth and not the speaker, Turn the phone's bluetooth off and then on and it should work. Also, if you look at a sound file or video file it will show the bluetooth symbol next to it, which means that it is playing to bluetooth and not the phones other outputs.
Jun 09, 2009 | Samsung Eternity Cell Phone
We just got 46" Samsung about 6 months ago. For the past week when ever I try to turn the TV on- it will automatically turn off and on (constantly until we unplug the TV). Sound is still working. ...
Sounds like an issue with the power and or main board. Contact samsung and describe your problem to them. A lot of samsung parts have lifetime warranties and the service call is free. so definitely check with samsung and see if you can get a comp repair. hope this helps, j
Apr 09, 2009 | Samsung LN-T4665F 46 in. LCD Television
Samsung LN46B550 no picture only sound 3 days old
hey Adam i have a samsung that has been doing that.it would come on then after a few minutes the picture would go ou but the sound still worked.i found that one of the connectors that plugs into the LCD board had a broken solder joint were it connects to the back lighting .just unplug your lcd connections if its bad you'll know it because it will come out.
Apr 05, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Sound but no picture
it's the T-con board attached to the lcd panel
Jul 29, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
RCA Home Theater (Model #P46924) No Picture, just sound
Sounds like a possible solder issue with the vertical output IC. Try resoldering the Vertical output IC connections
May 17, 2008 | RCA P46924 46" Rear Projection Television
I just had the same problem with my samsung 46". We were watching a movie and the picture went out. It is still out.l we turned it off and on and still no picture. I'ts been out all day. Any suggestions?????
Oct 17, 2007 | Samsung LN-S4692D 46 in. LCD HDTV
No display
Under menu, option make sure that you haven't selected audion only and that input select is on the first or second options,(not the third one). If you can't even see the menu, then your connections are probably bad. Hope this helps, Mark
Sep 09, 2007 | Samsung LN-S4692D 46 in. LCD HDTV
Samsung HPT5054 50 in. HD-Ready Plasma Television Logo
965 people viewed this question
Jerry Greenberg
Jerry Greenberg
