Gurgles when turned off
That indicates that the engine is on the point of overheating
when the engine is turned off the water is no longer circulating around the cylinder walls and head and the heat from those items makes it boil off hence the gurgle
how do you fix that?
find the reason for the overheating
if it has electric fans check that they are running
if it has viscous fan hub (fan clutch) replace it
have a compression test done to check for head gasket/cracked head
have the radiator flow tested
check the condition of the fins of the radiator
check coolant level
