The LCD displays an error code with problem with Printhead. To fix Brother Printer Error Code 4f go through eh 2-3minutes read of blog either or connect o right experts for assistance. The causes to this error is connection failure of the carriage-head flat cable or head flat, Print head defective, Power supply PCB defective, Main PCB defective. Looks of the causes and move ahead with the issues. Brother to help you settle on your printer obtaining choice, read the Brother Printer Error Code 4f surveys and evaluations. Impart following Model Brother Printer such as:
·Brother multifunction printers
Brother Printer Technical Support Blog News 1 800 213 8289
·Shading laser printers
·inkjet Printers When you are searching a Brother Printer answer for a home used or home office, little or medium business, or substantial business or workgroup, the impartial Brother Printer tech experts direct you towards the right printer solution. Connect to Brother Printer Support Number for proper and one to one assistance with experts.
SOURCE: Error message ''Unable to Print 4F''
How to repair error "print unable 4F" in the Brother dcp-135c .
thank alot.
SOURCE: Problem with my printer Brother MFC-240C "Print unable 4F"
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart,
try this step by step.without missing any thing.
thanks
SOURCE: troubleshooting : unable 4f cant print
Error 4f mean the head drive voltage has dropped from the high to low level in an abnormally short period.This mean your printer need new print head.This will cost you just as a new printer, then think about new printer.
SOURCE: brother mfc5860cn has error message print unable - 4F
Hi there
Please try this.
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
SOURCE: Brother MFC-3360C error message ''PRINT UNABLE 4F .....''
Hi there
Brother 4F is this have a go it could work for you.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All files on my website are only there for a limited time
