Question about Britax Eclipse Si - Paris Convertible Car Seat
My 15 month granddaughter keeps removing her shoulder straps what can I do?
  • 3 Answers
Chop off her fingers
Posted on Jul 14, 2009
My stroller has three levels to attach shoulder straps- where should straps be for a 6 month old?
Hi Marcia
We would think the harness setting should probably be on the lowest for a 6 month old baby / the most appropriate height for the baby depending on their height.
Please contact Maclaren for further assistance.
Sites maclaren US Site
Sep 08, 2013 | Maclaren Quest Stroller Standard
What is a sternum strap?
The sternum strap only purpose provides stability and keeps the shoulder straps in place.
Sep 06, 2012 | Burton Camping, Backpacking & Hiking
My 2 year old can get out of bugaboo even though she is strapped in? Is there extra straps or a harness for bugaboo
The Bugaboo's like 99% of all strollers have a 5 point harness. Two shoulder straps Two Lap straps and a center strap with the main body of the buckles. 2 year olds become little Houdini's pulling the shoulder straps off in both strollers and car seats. There are small buckle units you can buy that lock the two shoulder straps at chest height these are excellent at keeping kids in their place. Ask any nursery supply shop they should have them.
Oct 10, 2011 | Bugaboo Baby Gear
Need to remove the cover from a britax eclipse si..how
Press and hold down the harness release button. With your other hand below the chest pads, pull the shoulder straps forward as far as possible. With the Eclipse Si fully reclined, open the seat-belt guard at the back of the shell. Pull the yoke out from behind the seat and unhook both shoulder straps. Pull the cover from the top of the seat so that you can see the slots in the seat shell. Pull each shoulder strap and chest pad strap forward and towards the centre of the shell, easing the metal tab and straps through the slot. Then thread them through to the front of the cover. Unfasten the buckle and remove the comfort pad. Gently pull the cover off the seat, easing the shoulder straps, chest pads, harness buckle and adjuster strap through the slots in the cover.
By Geraldine Thorne
Feb 24, 2011 | Britax Eclipse Si - Chantilly
The seatbelt seems to rub badly on either side of my child's head
Hi you can get harness extensions from Dorel free a lot of peole have the same problem, I take it you bought it in 2007. If so you can also get the xl seat cover for 18mth + free from dorel
May 10, 2010 | Quinny Buzz Three Wheel Stroller
I have a turn a tot car seat and the straps that hold her into the seat are to long and i can't work out how to shorten them and i can't find instructions anywhere
I guess you have pulled the harness adjuster strap tight (between the legs on the front edge of the seat) and are still left with slack shoulder harness straps. It may mean you need to remove the seat and check the harness straps are going thru the shoulder slots in the seat, then they need to go up and over the the metal shoulder rod before going down to connect onto the metal spreader plate
Dec 13, 2009 | Baby Gear
How can pull adjustment belt
The shoulder straps feedthrough a loop in the adjustment belt so when you pull on the belt it tightens the straps. When you say it came out, if it has come out completely then you will need to remove the car seat and locate where it connects to the shoulder straps before feeding it back through the hole again
Aug 15, 2009 | Maxi-Cosi Baby Gear
Bugaboo Strap too loose
Well the best solucion is to cross shoulder straps and buckle it like that because soon they will learn how to take them of if you don´t do these: The straps have to be criss crossed on there chest  Hope these helps
Apr 17, 2009 | Bugaboo Cameleon Jogger
Adjusting the shoulder straps on the Maclaren volo stroller
What year is your Volo. Different years adjust differently. The newer ones have 3 height adjustment slots and a slider that adjusts the strap itself. They do not adjust way down though and even with teh straps as tight as they will go, they are still a little loose on my 15 month old granddaughter. I have found that buy tightening the waist straps it does keep her a little more secure.
Mar 15, 2009 | Maclaren Volo Umbrella Stroller
HARNESS FOR FRONT FACING EVENFLO TITAN CHILD RESTRAINT
there is another thread on this.
Basically, locate the ends of the straps on either side of the seat. You can remove the plastic end thingy and take the strap out. Then re-thread the strap. Remember to thread it through the thin grey strap (which adjusts the tension of the main shoulder straps) as well as the little metal guide at the back of the chair.
Your problem may also be that the length-adjuster (thinner grey strap) is too tight. You can loosen it by pressing on the button located just in front of the main buckle and pulling on the shoulder straps. This is also how you tighten the shoulder straps - by pulling on the thinner grey strap.
Generally, the shoulder straps should come out around the childs shoulder level. Higher is ok. Lower is bad because it doesn't secure him in.
Oct 29, 2008 | Baby Gear
Britax Eclipse Si - Paris Convertible Car Seat Logo
143 people viewed this question
Top Britax Baby Gear Experts
Jennifer Rock
Jennifer Rock
ray gallant
Tom Chichester
Are you a Britax Baby Gear Expert? Answer questions, earn points and help others
