Question about Hansol Computers & Internet
I got a hansol h711 monitor as a present but it was mising it's power cord , could you tell me were can i find it,please!
  • 1,684 Answers
We carry the adapter you need, they run $16.95 plus $4.50 shipping.
Let me know at tech@ccl-la.com if you are interested.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jul 15, 2009
What is my power
can you tell clearly power supply of moniter or ???
Mar 20, 2011 | Hansol 720 E (White) 17" CRT Monitor
Monitor wattage
Spec:
http://www.hansol.nl/eng/730e.html
Since the company will nor even list the power consumption, You can make an estimate by reading the voltage and the current consumtion on the label, multiply voltage by current will give you wattage, but since the monitor is not linear load but reactive load, the power factor will not be 1 but usually about 0.6.
IE, 100V X 1AMP = 100VA. 100VA X PF OF 0.6 = 60WATTS.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 14, 2010 | Hansol 730E 17" CRT Monitor
Hansol 730e , power led on , no display
check the cable connected on your monitor, see if this is fix and secure, on the other end of the cable, see also if this is properly connected to the video card.
If there is still no display, then my suggestion is you bring the monitor to a credible technician, and see if warranty is still available.
May 26, 2010 | Hansol 730E 17" CRT Monitor
Brightness
open the monitor you will look big black part called EHT you will see the movable shaft on it rotate it by screw driver in active supply monitor see on screen suficient brightness and stop you will be satisfied
Nov 21, 2008 | Hansol 500 A Monitor
No sound from monitor speakers. Worked fine for 5 years. Can hear sounds when using headphones plugged into CPU. Hope you can help even if only to tell me I need a new monitor. Sincerely Dizzyme.
Hi...there,
First of all, check if your audio cable are still plugged into the monitor and pc output (light green) audio jack. If not just plugged it back in... Still still got no sound... Then turned off the monitor and pc. Unplugged all the cables from the monitor and pc, wait for 10 second till all the surged built up are cleared out. Then you can plugged all the cables back Monitor should have 3 cables, a audio cable, a VGA or DVI cables, and a power cord... OK! now you got all the cables plugged back in...
Turned on the monitor and PC....and a few seconds....you should hear window started. Still... had a problems....just get a external speakers. Have nice day!
Oct 08, 2008 | Hansol H550 15" LCD Monitor
Hansol H950
The backlight power supply in the H950 series suffers from a manufacturing defect. Hansol might replace the unit even if it's not covered by warranty anymore. Contact them.
Otherwise (and if you have electronics skills), replace the electrolytic caps in the monitor's power supply. Take proper high voltage precautions!
  • Disconnect mains
  • Wait at least one day for caps to discharge a bit
  • Remove monitor stand (four screws)
  • Put the monitor face-down on the table, plugs facing to you
  • Remove back cover (snap-in, difficult to open without minor damage) - be cautious: front buttons are connected using a rather short cable, do NOT try to remove front cover
  • Remove EMV casing screws (four screws) and ground wire
  • Disconnect CCFL tubes (four connectors), noting connector orientation
  • Disconnect front buttons pcb
  • Lift EMV casing side facing to you
  • Disconnect power supply board (left) from signal board
  • Unscrew/remove power supply board - caution: C12 is likely to store mains voltage even after days!
  • Replace caps (C34 and C66 are likely failure candidates for IPHS19-S rev1.2 boards; you might also replace C31, C32, and C35 while you are at it) - higher voltage and temperature rating are okay, capacity has to match
  • Assemble everything again
Jun 26, 2008 | Hansol H950 19" LCD Monitor
Resolution hansol 730E
interesting, have you tried perhaps a monitor screen?
Feb 11, 2008 | Hansol 730E 17" CRT Monitor
List of hansol computers or monitors support centers in iran
Hansol itself does not support products in Iran directly - your geographically closest service centre is in Turkey, but others may be more convenient; http://www.hansollcd.com/eng/support/as.asp Hope this helps :) من امیداین کمک می کند
Aug 22, 2007 | Hansol 710 D Monitor
Hansol 730E CRT monitor
REPLACE THE BOOSTER C 5,6nF-1600V
Oct 18, 2006 | Hansol 730E 17" CRT Monitor
Computers & Internet Logo
141 people viewed this question
Top Hansol Computers & Internet Experts
Matthew Spark
Matthew Spark
Cleverer2
k24674
Are you a Hansol Computer and Internet Expert? Answer questions, earn points and help others
