Question about Pentax PocketJet 3 Plus Printer
Printer is not feeding paper. - Pentax PocketJet 3 Plus Printer
A sheet of paper had remain in the cylinder
  1. Remove the rear cleanout from the printer.
  2. Gently remove any jammed paper or bits of paper.
  3. Close the HP Paper Feed Cleaning Kit software on the computer.
  4. Load plain paper in the printer paper tray.
  5. Press the Power button to turn the printer off.
  6. Press the Power button to turn the printer on.
  7. Try printing again. If the printer still does not pick up paper or if a paper jam occurs again, service the printer.
Other solutions customers found helpful » HP Paper Feed Cleaning Kit -- Clean the Paper Feed Rollers with the HP Paper Feed Cleaning Kit in Windows XP and 2000 » HP Deskjet, Photosmart, and PSC All-in-Ones -- 'Out of Paper' Error Message and the Printer Does Not Pick Up or Feed Paper » HP PSC 1600 and 2350 All-in-One Series Printers -- 'Paper jam: Press OK to continue' Message Displays on the All-in-One
Dec 15, 2010 | HP PSC 1610 All-In-One InkJet Printer
PRINTER SAYS 'PAPER EMPTY/ LOAD PAPER' -- BUT SHELF IS FULL. WILL NOT PRINT/ FEED PAPER
IP4700 series has 2-way paper feeding. Please check you paper feeding from bottom cassette or rear auto feed!
Before perform the printing job, you may notice on your printer right side can select paper feed from rear or bottom.
Enjoy printing.
May 29, 2010 | Canon iP4700 InkJet Photo Printer
My printer won't feed paper. All of a sudden my printer quit feeding the paper - the error light comes on and states that there is no paper in the feeder - but there is paper in the feeder
Check the paper feed switch, you have a choice to feed paper from the back or the cassette under the paper exit. Either put paper in both or select the proper source by pressing the feed switch.
Dec 30, 2009 | Canon Pixma MP500 All-In-One InkJet...
Hp laserjet p3005dn tray1 manual feed problem
you can choose mp first in "paper handing" printer menu or print tray1 is A4 default in properties of printer software.
Jul 25, 2009 | HP LaserJet P3005n Printer
SAME PROBLEM LEXMARK X2350 STARTS FEED PAPER AND PRINTER HEAD MOVES AS PRINTING BUT WILL NOT FEED PAPER WHILE PRINTING? ARE THERE 2 FEEDERS IN THIS PRINTER? HOW TO FIX?
transfer roller that starts the paper and feed that feed the paper. have you had a paper jam and torn a piece of paper off inside the feed mech? i dont remember if this one feeds off the motor or a belt. either way you would have to disasemble the printer to determine where the problem lies. might be more econimical to replace the printer.
Jul 13, 2009 | Lexmark X2350 All-In-One InkJet Printer
Paper feed not working properly
1. first check to see if there is any bits and pieces of paper in any place in the paper carriage -- look very carefully in front access and rear access
2. if this is not the problem, then disconnect printer from computer -- turn off printer, unplug power cord, unplug printer cable from printer
3. gain access to paper roller assembly, usually in rear
4. using lint free cloth, dampened with distilled water clean rollers -- read manual to determine direction of rotation (usually clockwise)
5. keep rotating rollers until all is wiped clean of paper dust
6. reassumble and try a test print as your printer manual directs
Apr 22, 2009 | Office Equipment & Supplies
Paper feed rolls is rolling over the paper...how to get access to those rolls
  1. Feed the paper manually into the printer:
    1. Place a sheet of plain A4 paper in the paper feed tray.
    2. Move the paper support on the left-hand side to the left end of the paper.
    3. Press the paper feed button.
    4. If the paper does not feed, continue with step 2.
  2. Check for any obstructions in the paper feed path:
    1. Disconnect the cables from the back of the printer.
    2. Open the front of the printer and check for anything that may be blocking the paper path.
    3. Close the front lid and remove any paper from the paper feed tray.
    4. Holding the printer in both hands, turn it upside down to see if anything falls out of the paper feed area. (Sometimes objects such as pens, paper clips and so on can fall into the paper feed area and cause blockages.)
You can clean with special cleaning paper which ca be used clean the rollers............
Dec 08, 2007 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x3350
Nov 20, 2007 | Lexmark P4350 All-In-One InkJet Printer
Pentax PocketJet 3 Plus Printer Logo
21 people viewed this question
Top Pentax Office Equipment & Supplies Experts
Johnny Massengill
Johnny Massengill
Abdul Mannan
Abdul Mannan
Are you a Pentax Office Equipment and Supply Expert? Answer questions, earn points and help others
