Question about Pyramid XPA200 Amplifier
Humming noise thers a humming noise in the out put channels after it plays for awhile how can i fix this?
  • 54 Answers
Make shure your wall socket is grounded.Pull cover and look for black and wite and green wires on the back of the plug.Also may have leaking capacitors in final output stage may need a repair man look at the directory on this site.
Posted on Dec 01, 2007
Td 307 hum
Generally hum is associated with Capacitors, though in this case it might a semiconductor (transistor or IC) that is getting hot and when it does causes the noise. If this is the case you can feel around with your finger to see if any of these is getting very hot to touch. If the noise is in both channels then you could looking at something that is common to both channels. Not much help though if it's an IC as they tend to work both channels these days. One way of finding out is to use Servisol Freezer spray on a suspect part. You wait while the noise appears then blast the parts (one at a time) with the spray. If the noise goes away on one part, but not on others, you will have found your part that is faulty.
Nov 08, 2013 | JVC Audio Players & Recorders
2004 pontiac grand prix gt. humming noise while driving. Louder at 25 mph or higher. Changed front passenger side hub bearings due to when turning slightly left humming quiets. I stol have humming....
I change both wheel hub bearings when one goes
Doesn't matter what stabilizer does--- the bushings need
to be done-- so you say
Maybe you replaced the wrong drive axle
Put the front tires on the back to see what happens
Nov 30, 2012 | Cars & Trucks
I have a pair of JM lab Electra 905 speakers, running through a DNM amp and power amps. When powered up, the left speaker makes a very loud humming noise. This has happened recently. I haven't changed...
Hello
Switch on your amp, keep its volue down to extreme low, and listen if there is still hum through the left channel or not. If still there is hum, the left side power amplifier section inside the amp;ifier is faulty. If htere is no hum at this state, hum enters thorugh the audio input terminal, and the input wires must be checked for open sheild connection. OK.
Apr 10, 2011 | Jmlab Electra 905 Speaker
Amplifiers has a hum
The hum therefore is a generated before it reaches the volume control. Check that all the connects are good, a bad earth will cause a hum. If the hum is in both channels it will be something that is common to both. Electrolytic Capacitors are there to take out hum, so suspect them first!
Jun 06, 2009 | JVC Audio Players & Recorders
Humming noise when Dvd plays
the motor that's spinning the dvd is bad. sorry you have to buy a new one if you don't want to hear the noise. hope this help
Dec 17, 2008 | Coby DVD-937 5.1 Channel DVD...
My onkyo tx-sr705 produces a humming noise out off all the speakers when no audio is played
I found the source of my hum. I have Direct TV HD. I found that going into the menu settings (Direct tv HD Receiver) /Audio/Sound Effects and turning that option off, I was able to rid myself of the annoying hum. The option has something to do with keeping the audio settings from channel to channel, while it is changing you hear dead air except for the hum. Nice and quit now. Love this receiver!
Mar 06, 2008 | Onkyo Audio Players & Recorders
Maytag Netune Mah4000AWW
Makes a loud humming noise. Does the machine go thru its cycles ? Is the humm ther all the time ?
Jan 06, 2008 | Maytag MAH6500 Neptune Front Loading...
Hum and left channel doesnt work
Are these new speakers? My sub hummed when I had it in plugged in to the wall outlet with a light switch connected. As for the speker not working maybe a wire is loose inside the speaker cabinet. If it was dropped or something.
Sep 25, 2007 | Boka 2000 Computer Speakers
Washer keeps stopping during any cycle
the humming noise could be from two sources and it is worth while doing a few simple checks first the drain pump is jammed with a foreign object. check nothing caught in the impellor second water not available - check taps turned on. also turn water off, undo fill hoses, put in a bucket and turn water back on try on drain or spin programs to check water drainage as well
Jun 19, 2007 | Tecnik TKL9260 Front Load Washer
Pyramid XPA200 Amplifier Logo
67 people viewed this question
Top Pyramid Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Pyramid Audio Player and Recorder Expert? Answer questions, earn points and help others
