Question about NetGear FS605 (FS605SE) Networking Switch
Wont Switch on
Bought the FS605 recently and its been working fine. Just tried to turn it on this morning and will not power up. I know its not a problem with the electrics. Any idea?
Test power in its adapter up to the plug in end of the switch adapter. The power adapters are usually the culprit. If there's power in the wall plug, that leaves you with the switch itself. It's either bad inside or should come on.
Posted on Feb 18, 2008
No display after installing Biostar motherboard
THE DRIVERS MAYBE ? .
THE MONITOR ? .
YOU HAVE TO EXCLUDE ONE THING AFTER ONE OTHER.
Jun 13, 2013 | Biostar Computers & Internet
This morning my iphone was working fine was recording my baby talking. then i went to us it and it was off it wont turn back on?
Try a hard reset:
  • Switch the mute switch 4 times (up, down, up down)
  • Now press home and power together for 6-10 seconds
Then try to power on with the power switch.
Apr 05, 2011 | Apple iPhone Smartphone
My Netgear FS605 stopped working. All lights flashing about 1x/sec. No change in cabling or configuration in past year. Upstream Linksys N wireless router working fine. Tried disconnectring ethernet...
Are you able to ping between systems connected to the same Netgear FS605 switch and in same VLAN.
I suspect either switch port or Uplink cable issue.
Please try changing a new cable and if no improvement then please try with a different switch port.
Jan 08, 2011 | NetGear FS605 (FS605SE) Networking Switch
Car wont start in the morning
a toggle switch will work as long as you put the right fuse in it..Good Luck
Mar 23, 2009 | 1987 Chevrolet S-10 Pickup
I bought a netgear FS605 swtich and it doesn't work on the ps3.
Yes you must by a router my friend.
The problem is your ISP will not give out extra Ip addresses for additional clients. The router will have a dhcp server built in and that will fix the problems at hand.
Feb 20, 2009 | NetGear FS605 - 5-Port 10/100 Network...
Router failed numerous times so i bought a netgear fs605 5 port switch to hard wire in a ps3 and my dell lap top. can only run one or the other. not both at the same time. what is wrong?
The FS605 is a switch, not a router. You can only run one device at at time because you only have one ip address. You need a router between the internet and your switch if you want to use more than one device at a time.
Dec 08, 2008 | NetGear GS605 5x1000 Mbps Networking...
1994 C280 wont start
You left the key too long in the ignition switch. This sent an alert as if it were being stolen. Remove the key from ignition. Lock all doors. Wait about an hour or so. When you open the doors, put your foot down on the gas pedal and release. Put the key into the ignition and turn the car on.  Make sure you have the shift in "Park" position.
Aug 31, 2008 | 1994 Mercedes-Benz C-Class
Wont connect and software cd
To connect a router or a dsl modem to a switch you either have to use port 4 or use a utp crossover cable. As you can see on the Netgear FS605 the modem/router has to be connected to port 4.
The correct way to connect these devices is:
Modem > Router > Switch > Computers
Jan 14, 2008 | NetGear FS605 (FS605SE) Networking Switch
Is my FS605 broken
The FS06 switch is probably defective and needs to be replaced...especially if the status of the lights does not change after you cycle the power on and off with no network cables plugged in. These switches are sensitive to overheating and can easily be damaged if used next to other warm network equipment or with air vents blocked by papers, etc.
Turn-on order is not critical in this scenario, but ideally you should plug in all network cables, turn on the switch first, then turn on the computer.
Jan 10, 2008 | NetGear FS605 (FS605SE) Networking Switch
Only 1 computer getting internet with FS605
Sorry to say, you have the wrong part. Whoever told you you could hook it up to both your PCs and your cable modem didn't know what they were talking about.
Your FS605 is just a switch; hooked up directly to a cable modem, you will only see one IP address as that's all the cable modem will allocate.
What you need is a router, to allocate multiple local IP addresses and share the connection up to the cable modem.
Linksys BEFSR41 routers are ridiculously cheap these days and highly reliable, or if you like Netgear, you'll need the RP614.
Nov 07, 2007 | NetGear FS605 (FS605SE) Networking Switch
NetGear FS605 (FS605SE) Networking Switch Logo
175 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
