Question about Samsung HL-S5679W 56" HDTV
My problem is that I can only see half the screen.
I've had this tv fixed 3 times already for the clicking, no picture problem (out of warranty). This tv is less than 2 years old, very disappointed with Samsung service. My problem now, is that I can only see half the screen. The other side has a pattern design. Is there a reset on the unit that may solve this issue? I'm tired of spending so much money to fix this tv. Samsung should own up to the issues on this blog and help out their customers. Never had this problem in 7 yrs with my 46 inch Sony. Samsung, do the right thing!
  • 304 Answers
Three possible issues. First, the Main bd may be bad. Second, the DMD bd is bad. Third,the DMD chip is bad.
Posted on Jul 16, 2009
How to fix my sony tv?
When a TV is defect, there is no such thing as a magic word over the internet that can heal it. For defects, you really must visit a repair store, or contact Sony, when it still is under warranty.
Feb 16, 2015 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Samsung 40" LCD Right Half of Screen Distorted / Pixelated
I think you are screwed. When the price to repair exceeds 25% of the unit cost I get new up-graded items. New warranty for better items
May 09, 2013 | Samsung LN46A550 LCD TV
46in Vizio LCD HDTV distorted black picture when tv is turned on
Hi There are three things that can cause this problem. Your lcd screen, t-con board or the signal board. Most likelly in your case since you say it's only half the screen it's going to be your t-con board. You can try removing it and cleaning all the contacts and replacing it see if that helps. If that doesn't help then replace it. If that does not solve it then it's going to be your screen.
You can get parts at www.interliquidparts.com
Nov 28, 2011 | Vizio VW46LFHDTV10A 46 in. LCD TV
The screen only shows the bottom half of the picture. I have a RCA TruFlat 27" TV and it has a horizontal line in the middle & only shows the lower half of the picture. I've smacked it a...
The problem of your tv is only a loosed solder.Remove the back cover of your tv but be sure to unplug it then try to look the solder part of your tv look for some loosed solder then try to resolder it using a soldering iron but be sure not to connect separated pin in the pcb.
Jul 05, 2011 | RCA TruFlat 27F520T 27" TV
Hi I have a rca hd52w59. the top half of the
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 24, 2010 | RCA HD52W59 HDTV Projection Television
2002 27" SONY Trinitron. Half-screen picture with bright line.
Ur video board have burn capacitor,check the board connect to the CRT board connected to the tv tube.
Aug 02, 2009 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Half my screen is soild white the other half is perfect
one of the ribbon cables connecting lcd control board an lcd panel is not sitting properly or connector is not locked.
May 09, 2009 | Sharp LC52D65U 52 in. LCD TV
Picture Problems On 50 Inch Philips Plasma
You plasma still under manufacturers warranty. Most electronic devices have one year warranty.
The failure in your TV can only be corrected by repairing it.
I would suggest to call philips and ask them to find you an authorized repair center near you to get your TV fix under their warranty.
Jul 24, 2008 | Philips 50PFP5332D 50 in. Plasma...
TV Problem
No. Are the lines white or black? Does the picture look distorted at the top? Is there a chance it is still under warranty? It sounds like a problem in the vertical retrace circuit. Probably a capacitor near an IC that's used for timing. You shouldn't be having this issue already. A tech should be able to see a distorted waveform in the vertical section. Hope this helps.
Nov 11, 2006 | Philips 32PT5441/37 32" TV
Samsung HL-S5679W 56" HDTV Logo
432 people viewed this question
Jerry Greenberg
Jerry Greenberg
