Question about Acer Aspire 5720-6661 Notebook PC
Web page is to large.
I WAS REMOVING A PROGRAM FROM MY COMPUTER AND,WHEN I REBOOTED IT AND THE COMPUTER CAME BACK ON,EVRYTHING WAS ENLARGED.HOW CAN I GET MY WEB PAGE BACK TO NORMAL SIZE AGAIN? CAN YOU HELP ME? THANK YOU. davidstraschewski@ymail.com
  • 126 Answers
Assuming you are not in Safe Mode, you can go to Start-->Control panel-->Display
Then click the Settings tab at the top and drag the slider to the far right under the section "Resolution" then click Apply and OK
Posted on Jul 14, 2009
MOUSE AND KEYBOARD FROZE UP
I'm assuming that your keyboard and mouse are wireless versions. You should therefore have a wireless controller plugged into one of the USB ports, probably at the back of the PC. Try removing the wireless controller and install it in a different USB port. The Windows operating system should detect it as a new device and attempt to install the drivers automatically.
Dec 23, 2012 | Gateway GT5692 Desktop Computer
How can i return my emails down to the normal size as at this moment it has been enlarged
Select your email screen, hold Ctrl key and roll your mouse wheel in either direction, it will reduce or enlarge your web pages.
Jan 14, 2012 | Sony VAIO J Series White All-In-One Touch...
I have a dell gx260 all my web video sound like chipmunks , media player works fine and i did all the troubleshoot test and it works just fine . The main problem is the web content all sound like chipmunks...
Hi.
This is usually caused by a missing codec, so the computer tries to compensate, and the results aren't always acceptable.
I would download a codec package called K-Lite codec pack, it has every codec needed.
Here is a link for it.
http://www.codecguide.com/download_k-lite_codec_pack_mega.htm
Click on the direct download selection there on the page, and it will download an installer with all the codecs.
Run the program after it is done downloading, and then after running it, reboot your computer.
There is a selection for 64 bit on the page as well, in case you are running 64 bit operating system.
Once rebooted, your chipmunk audio problem should be resolved.
I hope this helps you out, and have a good day.
May 27, 2011 | Dell OptiPlex GX260 PC Desktop
The bobbin jammed with cotton. cotton wound around outside casing of bobbin...I twisted the black latch to release the cotton and 2 large disc components came out ...how do I put them back in...nothing...
If you go to www.singerco.com and download a free copy of your manual, you can enlarge a great diagram on page 77 of your bobbin area and how to put it back together. I enlarged it to 200% and I think that it will help you immensely. Good luck
Jan 31, 2011 | Singer 2250 Tradition
The resolution on my monitor is messed up. Its as if every item (Whether it be shortcut or taskbar)has been enlarged by atleast 2x what it was origianlly. Now its as if the computer is aware of the problem...
In windows xp -
1. Right click on the desktop
2. Click on properties.
3. Select Windows XP Theme. (this is the default theme)
On Vista --
2. Select personalize.
3. Select Themes
4. Select Windows Vista from the drop down box.
This should set everything back to the default settings as far as the appearance goes.
Nov 03, 2009 | Gateway 4525GZ Notebook
Hp w1907 - web pages too large for monitor. I
You need to increase the resolution of your desktop.
Goto Display Properties->Settings
Jul 18, 2009 | HP w1907 LCD Monitor
Monitor is enlarged, wont return to normal size
You may have hit the "F11" key which takes the open window to fullscreen. "F11" toggles large, small... If not that, beboot. If that doesn't clear it up, then the display settings have gotten altered. Right click on the desktop, select "settings" and increase the resolution. Windows should prompt you to keep or reject the change. Select yes or no when prompted.
Jan 24, 2009 | Computers & Internet
Computer monitor screen is blue
Can you access the bios set up.
If the bios setup is running evrything is ok except the hard disk.
To find out if there is any problem with monitor just put off the monitor and disconnect it from the cpu. Then turn it back on. If the no signal message is coming, then monitor is ok.
Your hard disk is the main suspect
If the same blue screen comes then monitor need repairs.
You may also try with another monitor on your computer to see the results. If the sane happens it is the hard disk
Dec 18, 2008 | Acer 22" X223w LCD Monitor
Browser Enlarged
If part of the web page is not visible on the screen, you may have accidentally dragged it off to the side. Click the green button at the top-left corner of the web page to resize the window to fit on the screen.
If your screen resolution is set to 800 x 600 or less, most web pages won't fit on the screen. If possible, increase resolution to at least 1024 x 768 in System Preferences > Displays.
You may have accidentally hit Command (Apple key) and the plus sign (+) key -- this makes the text bigger. To reduce text size, hit Command and hyphen (-) key.
Finally, if Zoom is turned on in the Universal Access setting, you be looking at only part of the screen -- zoomed in like using a magnifying glass. Hold down Command (Apple key) and ALT key and hyphen (-) to see if this is on -- it will unzoom (zoom out) by one step. Turn this off or on in System Preferences > Universal Access.
I hope that helps.
Nov 18, 2008 | Apple iBook G3 Mac Notebook
Acer Aspire 5720-6661 Notebook PC Logo
22 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
