Question about Oxygen Portable Oxygen System
How do I use a portable oxygen tank? How do I hook up the gauge? How do I know if it is full?
How to prevent the oxygen tank from faflling from the wheelchair?
Posted on Mar 17, 2011
Fuel gauge problems
Hi , your best way to go now is to hook up a variable resistor to the fuel sender wire and go by the manufactures specifications on different resistance values , full , half and empty. This will tell you if it is a gauge issue or maybe a swirl pot inside the tank has come loose impeading the float to rise fully. Also earth out the old sensor and hook up the fuel sender wire to it and manually lift and lower the float to see if it works. Sorry I do not have the manufacturer specs on resistance. Cheers.
Jan 06, 2014 | Hyundai Elantra Cars & Trucks
Fuel gauge reads past full all the time
when the tank is full the resistance is low so the power through the gage make is read full
as the tank empties , the resistance increases so the less current means the gauge reads less until empty there is little or no power , the gauge reads empty
simple check , turn the ignition off, no power , no gauge reading
Sep 09, 2017 | Chevrolet S 10 Cars & Trucks
float may be stuck up;Take tank unit out and check it with power on and observe the travel and relative gauge position.
How to prevent a portable oxygen tank falling from a wheelchair?
if you pick up 3in wide Velcro straps 2 will do it that tank (will) stay in place
Mar 17, 2011 | Oxygen Portable Oxygen System
My 1969 chevelle's gas gauge is stuck pass full.bad gauge or sending unit? how to tell?
According to what I read, test the gauge first. Hook power to where the white wire attaches. Hook a ground to the black wire connector. The gauge should rise to full. (May take a while). When on full, the tan wire connector to same ground. It should go to empty. If both work, gauge is good. To test sender, in the empty position, your ohm meter should read 0-2. 1/2 tank should read about 40, and full should read 84-88 ohms.
May 17, 2010 | Cars & Trucks
1990 chevy van G20 gas gauge shows full at all
The float inside the tank needs to be replaced. or one of the wires has a small short in it.
Dec 21, 2009 | 1993 Chevrolet G20
Gas guage-oxygen sensor?
The oxygen sensor has nothing to do with the fuel gauge. There are two possibilities for the gas gauge error, first it could be the in-tank gas level sensor or it could be a defective stepper motor which drives the gauge. A professional scan tool can determine the fuel level being sent by the in-tank sensor, if that disagrees with the gauge, then the stepper motor needs replacing.
Sep 04, 2009 | 2005 GMC Envoy Xl
Fuel warning light stays on despite full tank and correct gauge
sounds like a bad gas meter unit in the gas tank if not working. I dont know toyota the tanks but my jeep the thing that read the level is hooked to the pump. Looks like metal arms with plastic arm that floats to tell the level in the gas tank
Jul 26, 2009 | 1998 Toyota 4Runner
I recently changed my fuel tank sending unit in my 96 ford ranger but my gas gauge seems very sticky and will jump to the empty level periodically. I don't smell any gas leaking and I know I have gas in my...
the buffer plates in the tank seem to be loosely held! so sometimes they fall on the sender unit,causing the gauge to drop!!!!! when the vehicle is shaken!!!! remove that tank and have the plates checked!!!!
Jun 16, 2009 | 1996 Ford Ranger SuperCab
Oxygen Portable Oxygen System Logo
1,539 people viewed this question
Top Oxygen Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an Oxygen Health and Beauty Expert? Answer questions, earn points and help others
