The CD doesn't always come out after I play it. Right now I can't remove it at all.
  • 68 Answers
The rubber belt gets lose over time and slips ! they used to sell a belt dressing spray ! best bet is to have it changed
Posted on Jul 14, 2009
My cd/dvd player doesn;t play nor will it eject but evrything elsel on radio works
you can always have the serviced / repaired in order to restore functionality to the cd player.
A breakers yard/scrap yard may have a good/working replacement original....make sure you get a code if it requires one.
Jul 18, 2015 | Cadillac 2007 Escalade AWD
Tip
How to Fix a Scratched CD
Clean the disc. Even if a CD isn’t actually scratched or scuffed, dust, oil, and other surface contaminants can prevent it from playing properly. Thus cleaning the disc should always be your first move. Ads by Google
'; for(i = 0; i '+ '' + google_ads[i].line1 + ' ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
' + '' + google_ads[i].visible_url + ''; } s += ""; document.write(s); return; } google_ad_channel = '+7733764704+1640266093+9503394424+5009222491+3607312525+8962074949+1162261192+0674921071+7122150828' + xchannels + gchans; google_ad_client = "pub-9543332082073187"; google_ad_output = 'js'; google_ad_type = 'text'; google_feedback = 'on'; google_ad_region = "test"; google_ad_format = '250x250_as'; //--> google_protectAndRun("render_ads.js::google_render_ad", google_handleError, google_render_ad); Ads by Google
Fix It Scratch RemoverRepairs Scratches Like Magic! As Seen on TV. Guaranteed.
www.AsSeenOnTvAdvisor.com/FixIt
  • Run warm water over the damaged disc to remove dust.
  • If there is stubborn dirt or grease on the disc, gently rub it with your finger while you are washing it, and use a gentle detergent or liquid soap (with the water) or rubbing alcohol (in place of water). Any time you rub or wipe a CD, you should do so by starting at or near the center of the disc and rubbing straight outward toward the edge to prevent further scratching.
  • Shake the water off and let the disc air-dry (do not dry it with a towel or cloth, and don't sun-dry it either).
  • 2Try to play the disc. Many times a good cleaning is all that is needed. If, however, problems persist after cleaning, try to play the disc in a different CD player. Some players handle scratches better than others; computer CD drives and car stereos tend to be the best.
  • 3Burn a new disc. If you can get the CD to work in one CD player - especially your computer’s - but not in others, try burning a new disc. The CD burner on your computer may be able to read the CD well enough to produce a perfect copy. You may wish to try this even if the CD doesn’t play correctly on the computer.
  • 4Locate the scratch. Actually repairing the disc will be easier if you can figure out where the offending scratch is. Visually inspect the CD’s playing surface for scratches or scuffs. Scratches that run perpendicular to the CD’s spiral - that is, those that run generally from the center to the rim - may
  • on Mar 23, 2010 | Computers & Internet
    Tip
    How to Restore a Scratched DVD or CD
    You can save a Lot of money when you restore a scratched DVD or CD.
    • Pour rubbing alcohol on to a clean dry cloth. Try to use a cloth like the ones used for cleaning eye glasses. You can also use a pretreated paper cloth like the ones used to clean glasses.
    • Lay the CD or DVD on a clean flat surface label side down. Use the cloth to gently buff the exposed side of the CD or DVD until all smudges and fingerprints are removed.
    • Test the CD or DVD by playing it in a player. If it still doesn’t play correctly, try repeating step 2. If it does play correctly, continue enjoying your music and movies.
      Cheers. :)
    on Dec 14, 2009 | Audio Players & Recorders
    Static sound from one channel after playing for a while--time it starts varies.
    You don't say what a 1055 is and it is hard to know what you are asking with a lack of ID on the equipment at fault. Sounds like a source selection problem maybe a switch or if electronics a CD4066 IC.
    Mar 25, 2013 | Audio Players & Recorders
    Cd player dont work
    Is it a CD player? Are you trying to play DVDs? Does the CD player show up in device manager? (Right click "My Computer", click Properties, Hardware Tab, Device Manager. If it doesn't show up at all then the drive probably needs to be replaced.
    Nov 30, 2011 | Computers & Internet
    Tip
    Enjoy :)
    on Dec 12, 2009 | Computers & Internet
    Hi, I have a pioneer DEH-P5500MP which always worked just fine but now when there is no cd in the radio it won't play so i try the source button but that doesn't work so i put a cd in and it starts...
    It sounds like you may have a bad switch. If you have a multimeter you can check the switches for resistance. If the reading on any of the switches is less than a few megaohms it is probably bad.
    Oct 30, 2011 | Pioneer DEH-P5500MP CD Player
    2002 cadillac deville will not play cd's burned from my computer, always say cd error. it will play store bought cd's
    The cds aren't formatted the right way on the computer and thus won't play on the cd player...common problem with MAC computers.
    Jul 27, 2009 | 2007 Chevrolet Impala LS Sedan New Cars
    Doesn t reading the cd
    hey,
    also mention how old are ur CDJ and does it play original cds. Did you get any error code.
    thx
    djajay
    Jan 23, 2009 | Pioneer CDJ-1000 CD Player
    Audio cd
    You can always choose to play via WMP though. You can open My Computer and right click on the cd and select Play With or Open With and select WMP. The thing is, does it play on other cd players besides the comptuer's?
    Lolita
    Jul 22, 2008 | Computers & Internet
    76 people viewed this question
     Grubhead
    Grubhead
