Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Worked great the past 2 years. Now, garage door
Worked great the past 2 years. Now, garage door will only go up 1 foot then stops. I hit the remote and it goes back down. I hit the remote again, and it only goes up 1 foot and stops. Any suggestions?
    President:
  • 3,197 Answers
Remove the cover and take a look at the drive gear. It is white nylon and is just in front of the motor. Most likely stripped.
Posted on Jul 14, 2009
  • Don Maggard Jul 14, 2009
    Should have added to also look closely at the door springs. Could have a broken spring.
How do you stop the door leaving a foot open at the bottom?
To stop the door in a partially open position, the button on the wall switch or remote should be pulsed when the door is opening from the fully closed position.
Jul 12, 2014 | liftmaster Garage Door 1/2 Hp
Garage door opener Chamberlain - programming problems
I bought a new keypad and 2 VISOR remote (30498). As to programming garage door opener, I did like here:
- it tooks me 20 minutes and works great
Feb 07, 2013 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster Professional 1/2 horse model # 41A5483 installed in 02 Learn light flashes 4 times. When openers are hit in cars (2 Chrysler vans use built in Homelink Systems built into sun visors, one car...
check the settings on the unit itself sometimes if you have it set up to come down too rapidly it will cause it stop and go back up because it thinks its hit something.
Apr 10, 2011 | liftmaster Garage Door 1/2 Hp
Garage door only raises about two inches then stops.
Check the door springs and also remove the cover from the motor unit and check the drive gear. The door spring could be broken or the drive gear may be stripped.
The sensors only work when the door is closing.
Jun 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
My Sears Craftman garage door opener closes about 1/3,stops,and reverses.When I activate the remote again it stops rising,starts down again, comes down another foot or so,stops,reverses etc.,etc,etc It...
If the main light is flashing 10 times when the door reverses it is a door sensor problem. One may have been bumped so that they no longer point at one another. Make sure the small light on each sensor is lit and not flickering. If this isn't the case you might need to increase the down force a little. The control is on the back panel near where all those white wires go. Increase it about 1/4 turn and try.
Dec 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
GARAGE DOOR OPENER WORKS INTERMITTENLY
& to 10n years on a door opener is good. Did you set the pressure up high there are two dials on the back and they are numbered 1 2 3 to 10 set them to 8 or 9 and see if this solves your problem. What is happening is the sensors are tell your door its hitting something dose the light blink after it stops I need to know more. I would just buy a new one don't get this one fixed not worth it.
Jun 07, 2009 | liftmaster Chamberlain Garage Door Opener...
Chamberlain 1/2 hp Model # 82000 remotes not working
get a referral to a garage door guy! First off, make sure you have not activated "Lock" on console. If not, recode remote by hitting LEARN button on motor for 1 second and pusjing a button on remote. Light bulb on motor should blink 2x. Repeat for each remote you are having problem with. Should do it.
Jan 14, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Clicker garage door keypad works inconsistently
no relation. did you plug rpm sensor and logic board connectors on well.
Dec 11, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage door does not open with either the door switch or the remote control. I have confirmed that there is power to the unit however the lights do not come on either. It is a craftsman 1/2 HP Model #...
why does it go up or down a foot then stops, we have push remote or button at least 6 times before we can finally get it to go up. It is a craftsman 1/2 also
Jul 26, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
236 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
