Question about HP LaserJet 1320NW Printer
My printer won't print anything from my computer
My test page will work and when I go 2 Control Panel then Printers it shows its ready but when I attempt I get "document failed to print" message. This setup was working before I just don't understand why it doesn't now. Thanks
  • aorvik Jul 15, 2009
    Hi I tried what you suggested and no dice I also installed the software on my laptop and couldn't get that to print either. It seems like my HP is not recieving data from computer now. All help is appreciated Thanks
  • aorvik Jul 16, 2009
    Hi I tried this and nothing happened I also tried another computer and no dice either. When I plug in the USB I hear a connection noise so not sure if that helps but still no data prints when sent from computer. Thanx
    Brigadier General:
  • 4,088 Answers
Is this a USB communication? Try deleting the printer, pull the USB connector, and go through the entire install procedure again.
Posted on Jul 14, 2009
Epson TM T88iii printer not printing
Since you are using the USB-to-serial converter, you need to select the serial interface in the printer driver installation.
  1. Uninstall the driver in Control Panel > Add or remove programs
  2. Restart the computer
  3. Install the printer driver again, this time select serial in the interface list
  4. Set the properties for the serial port to 9600 for the data rate
  5. Print a test page!
Sep 07, 2017 | Epson TM-T88III Thermal Printer
My printer won't print. my computer is hooked up to it, and it doesn't give any error messages. it just doesn't do anything.
Go to Control Panel/Printers. Right click on your printer's name, and hit Print Test Page. If printer prints a page out, then the problem is likely with the software you're using to print - make sure you have selected the right printer in the dropdown. If the printer's name doesn't show in the Printers folder of Control Panel, the driver for it has not been installed. Do so and try again.
Jun 18, 2011 | Lexmark X2670 All-In-One Printer
My Dell V505 printer won't print documents from the computer, when I press print the printer prints a page of dash's and ticks. there is ink in the cartridges. i've disconnected the power....
Turn the printer off.
Disconnect the AC power.
On your computer, click Start
Click Control Panel
Click Printers
Select the Dell Printer
Uninstall it
Restart your computer
Turn the printer on
Allow the computer to reinstall the device-device for the printer.
Print a test page.
May 09, 2011 | Dell AllinOne Multifunctional (v515w)...
Myy Brother MFC5460 will not print at all. Printer status says it is ready, but the printer never receives the print material. The information remains in the print queue. Work Offline is not checked, so I...
How is it connected?
If its connected via usb cable just follow the steps below:
1. Make sure that Mfc5460cn lcd shows date & time. 2. Disconnect the usb cable from the computer and printer. 3. Turn off the printer and unplug it from the power outlet. 4. On the computer, cancel the document on queu. Go to printers folder and right click on the Mfc5460cn icon and left click on cancel all documents. 5. Reconnect the usb cable from the printer then to your computer. Make sure that it is connected securely. 6. Plugged the printer back to the power outlet and then wait for the lcd to show date & time. 7. Open the printers folder again. Make sure that the status is ready document 0 8. Right click on MFC5460cn then left click on properties. ON the lower left side of the window click on print test page.
The printer should print a test page. And it should work,
Hope this helps. Rate if it works. Thanks
Apr 09, 2011 | Brother MFC-5460CN InkJet Printer
I bought new ink for my Easy Share 5500 and show that they are both full but i am unable to print
Check to see if see any amber light on printer. Go to control panel and printers and faxes to make sure the printer is set to ready. Printer the test page to see if it works.
Apr 06, 2011 | Office Equipment & Supplies
It will not print. It passes the paper through without printing anything on it. The ink cartridges are new. It prints a test page. but it will not copy. The computer says its ready to print. The...
A test page prints with the proper ink/text showing up?Have you tried restarting the computer? Have you powered off the printer and turned it back on? You could try reinstalling the printer software and see if that helps.
Mar 21, 2011 | Dell 948 All-In-One InkJet Printer
How do i get printer working
Are you able to print test page from Printer ?
This will help us diagnose and isolate the issue further
To print self test page ( Demo page ), do these steps below
Press the right arrow button simultaneously. It should start printing the demo page.
If this works fine, this could possibly be an issue related to print jobs stuck in queue.
To clear print job stuck in Queue
Click on Start button
Click on Control panel
Click on Printers and Faxes
Check for HP Laserjet Printer icon
Right click on the printer icon and Click Cancel all documents
Once you have done the above step, disconnect the printer from PC ( if using usb ) or turn printer off
Restart your PC/laptop
Check under printers and faxes folder if the Printer status shows Ready and 0
You are ready to print
Nov 02, 2010 | HP Color LaserJet 2600n Printer
I can not connect to my pc for print
try to add your printer, just click start then click printer and faxs, then add printer,
Jul 01, 2009 | Brother HL-2040 Laser Printer
PRINTER W0NT PRINT FROM COMPUTER.
If your printer is using a USB cable to connect to the computer, please try the instuctions below:
1. Go to the Control Panel > Printers
2. Right-click the printer icon > Properties
3. Ports tab > select USB001 > click on Apply so that the printer name would appear right next to the port.
4. If USB001 is already selected, try to select another USB Virtual Printer Port.
5. Save the configuration
6. Make sure to set the printer to online.
7. Try printing a test page
Apr 08, 2009 | Computers & Internet
Wont print anything even atest page
what operating system and how do you connect printer to computer?
check under device manager if usb if you have usb printing support from universal serial bus controller if using usb and check status of printer from printers and faxes if using windows based platform
Apr 02, 2008 | Epson Stylus Photo R2400 InkJet Printer
HP LaserJet 1320NW Printer Logo
55 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
