Question about Whirlpool LGB6300 Gas Dryer
I have a whirlpool LGR7646JQ0 gas dryer..the burner shuts off?
The burner ignites just fine but after 3-4 minutes the burner shuts off and it will not reignite until I turn the dryer off and on again?
  • 52 Answers
Sounds like you have a bad warp switch. Also could have a gas valve going bad.
Posted on Jul 15, 2009
Igniter starts to glow for 3-5 sec while making noise every minute or so
Check the thermocouple it is going bad or already has and that is why the gas valve is not staying open.
Jul 08, 2017 | Whirlpool GGW9200L Gas Dryer
I have a Whirlpool LGR7646JQ0 Gas dryer. It wasn't heating. I took it apart and used a meter to check the list of things in a video linked to me here. Turned out to be the coils. Replaced those and the...
Lack of airflow can cause the unit to overheat and shutdown. Check all the vent pipes for obstruction. IT could also be the high limit or the thermostat that is bad.
Apr 03, 2017 | Whirlpool Dryers
Whirlpool Gas Dryer Model # LGR7646JQ0. Bought it used, warranty useless since the shop I got it from went out of business. Everything works fine. The drum turns, the timer works but the thing doesn't heat...
Hi and welcome to FixYa. I am Kelly.
Your power for the burner assy goes on a series circuit from the timer to the high-limit thermostat to the operating thermostat to the thermal fuse to the gas burner assy, thru the motor centrifugal switch to the door switch. EACH of these must be functioning for the burner to light.
This manual will help with some of the how to do it as far as component access, removal and replacement of parts.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/4829abde74a34d7f85256ab000620794
Also this link has loads of information on what to check.
http://fixitnow.com/wp/2006/09/19/how-to-check-the-burner-components-in-a-gas-dryer/
The 3 most common failures are
Igniter:
Gas Valve
High Limit Thermostat
Compnents : http://fixitnow.com/appliantology/gasdryer.htm
Note the LINKS!
Here is a 9 min video that pretty much covers everything you need to check: http://www.howcast.com/videos/371390-How-To-Troubleshoot-a-Gas-Dryer-That-Wont-Heat
Thanks fo choosing FixYa.
Kelly
The
Aug 20, 2010 | Whirlpool LGB6300 Gas Dryer
When I turn on the dryer, it takes a few minutes before the burner ignites, and will only heat for about 5 minutes then the burner shuts down.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 02, 2010 | Whirlpool Dryers
Whirlpool gas dryer model#LG5791XM- the burner is working off&on
first check to make sure the venting isn't blocked by lint. second, check the igniter, if it is orange in color you need to replace it, it should glow white.
Nov 14, 2009 | Whirlpool Dryers
After starting my GE gas dryer , the burner fires and everything seems fine . The burner stays on for a few minutes and shuts off like it's supposed to . After a few minutes , the glow element turns on to...
Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Aug 01, 2009 | Dryers
Dryer does not release any heat
Is yours the gas model? If so I need you to look for some things. Open back door panel and see if while trying to light the igniter is glowing orange. Sea Breeze
May 22, 2009 | Whirlpool LGB6300 Gas Dryer
Gas dryer burner cuts off after a few minutes of use
Your gas solenoid coils are bad. Replacing them will solve your problem.
May 17, 2009 | Whirlpool Dryers
Whirlpool dryer LGR7646EQ3. Burner lights before pushing start.
The heat is regulated with a Klixon mounted next to the blower housing near the vent pipe so it can judge the temperature of the air coming out of the drum.Right next to it is a melting type fuse. If the dryer runs and gets too hot the fuse will melt.But the dryer will still run. So if the fuse is good(continuity) and the dryer control(cycle) thermostat is also good then you should have power going to the gas valve assembly when the machine is running unless the timer is in the no heat or wrinkle free/cool down mode. When the gas valve assembly is energized the flame sensor mounted outside the burner chamber detects the heat from the ignitor. When the heat is very intense then the sensor shuts down the ignitor and that frees up the power so that the coils can be fully energised and open the gas gates. The gas comes out and hits the red hot ignitor and you have ignition. It stays on for maybe 2 or 3 minutes or until the control thermostat is satisfied and shuts down power to the gas valve assembly.
more here
Dec 15, 2008 | Whirlpool LGR7646E Dryer
Whirlpool LGB6300 Gas Dryer Logo
554 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
