Samsung HLN617W 61 in. Rear Projection HDTV Television
Problem for Samsung HLN617W 61 in. Rear Projection HDTV Television
The television started making a high pitched
By jnussbaum on Jul 14, 2009
the television started making a high pitched whining sound when on and then for about 5-10 seconds after the tv shuts off. any ideas what it could be?
Solution #1
posted on Jul 16, 2009
Somewhat Helpful)
cary369
Rank: Guru  Samsung Expert
Rating: 87%, 100 votes
The color wheel is bad and must be replaced by a trained tech. Do not attempt yourself. Too tricky. Part# BP96-00250A
Was this helpful?
Yes
No
Solution #2
posted on Sep 13, 2009
Not Rated)
GnomeCat
Rank: Apprentice
Rating: 0%, 0 votes
Actually, changing the color wheel does not need to be done by a trained tech. Google "How to replace color wheel on Samsung DLP" and the post by Jangro.com is very helpful. It should take about 2 hours the first time you do it and the part costs ~$90 delivered to your door.
Was this helpful?
Yes
No
Popular Solutions for Samsung HLN617W 61 in. Rear
Questions and Unsolved Problems for Samsung HLN617W 61 in. Rear
Do you recommend Samsung HLN617W 61 in. Rear Projection HDTV Television?
Answer
Answer
Samsung HLN617W 61 in. Rear Projection HDTV. Left side of screen has 4 inch section from top to... (More)
Answer
It is powering itself off.. It will turn back on ,but turns off again in a few minutes
Answer
have a 63" dlp model HLN617W and its making a grinding noise it turns on then shuts itself off... (More)
Answer
samsung flat screen keeps turning off...sound stays on...what is the problem
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
