Question about Toshiba Televison & Video
Vertical Foldover on screen and intermittent power issues
I work at Q13 FOX in Seattle and we have about 12 of the Toshiba 27DF46 tv. Almost every single one of them had the same problem with a vertical foldover. After testing almost all of the electrolytic capacitors I found that the capacitor C407 was the culprit. It is a 35v 100uF capacitor located to the left of the vertical circuit chip (LA7847). I also had the capacitor C432 (160v 47uF) fail on a few of them. It is part of the power circuit. Last but not least, I was having a thermal power up problem on one machine. It seems as though it is coming from the power area but it is so intermittant that I couldn't track it down. I also found that once it is plugged in to power that it would work fine after being plugged in for about 20 seconds or so. If someone else has experienced this issue and has a fix let me know as I still have 9 more of these bad boys to take down from their wall mounts and fix the vertical foldover issue... Thanks and I hope this may help others on the solution I found.
  • 139 Answers
SOURCE: Sanyo DS25390 Vertical problem
Jack,Did the Vert Ic have Broken conns around the legs?
Posted on Jul 19, 2007
  • 3130 Answers
SOURCE: 27MT5005D vertical foldover
You have bad capacitor(s) in the vertical circuit.
Posted on Dec 06, 2007
  • 1694 Answers
SOURCE: Philips 27p6441/37 has a foldover
Bad capacitor / IC in vertical circuit...usually a shop repair...
If not corrected,could get worse in short period of time,.....T.
This model also requires an upgrade kit for future reliability...
Philips part number 483531057673 senior tech only.......
Posted on Jan 27, 2008
  • 230 Answers
SOURCE: Toshiba 36A50 Horizontal Line
Ok, The vertical Ic is IC301 Ta8427K And Capacitors around IC chroma 2.2 uf 50 volts. You will see small red capacitor ( with C302....4 or 5 ) reference. Replaced others capacitors on vertical section 220 uf 35 V or 100uf 35V. I hope this can help you. Or if do you have any picture chasis, send to me and I will show you where are the problem., Thank you
Posted on May 11, 2008
  • 375 Answers
SOURCE: Phillips TV 20PT6341/37
unit requires possible caps in the vertical section to be replaced.
Posted on Oct 23, 2008
Has anyone heard of a woman called joyce Tim she's using photos of aria giovanni
I have heard of Tim Joyce an American meteorologist and newscaster on Seattle, Washington's Q13 TV station, an affiliate of the Fox television network, and also presents weather and traffic for the Portland.
Dec 24, 2016 | Washing Machines
How to repair Vertical Foldover on Toshiba 20AF43 old crt TV
Check and replace all the electrolytic capacitors [about 5 or 6 of it] at its vertical scan output section circuit..
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Aug 30, 2014 | Toshiba Televison & Video
Vertical foldover on bottom of 32 inch samsung lcd tv about 3 inches across bottom of screen
usually on all image related problem on all LCD comes from faulty t-con board..but for sure try to play dvd movie to test if the problem is on tv/t-con...
Jul 18, 2012 | Televison & Video
My Toshiba mw24h63 has a vertical foldover about 6 inches high at the top of the screen. What is the cause and can it be easily repaired?
caps in vertical circuit. 100uf or 220uf . the ic is in the middle back long ic with about 10 to 12 pins on a heat sink. caps are bad and utube has pictures.
Nov 04, 2010 | Toshiba MW24H63 TV
Toshiba 27df46
i have the exact same problem. i used to be able to turn it on and off but that does not work any more. hope someone has an answer for this.
Aug 18, 2008 | Toshiba 27DF46 27" TV
Toshiba 27" 27DF46
Since your problem is coming and going your vertical output Ic is prob still good at this time, It needs to be resoldered and this should fix your problem the repair tech may want to replace the Ic and this is ok too. Location of IC on board is Q301 Part number 23319832 and costs about 10-15 dollars plus labor.
Feb 05, 2008 | Toshiba 36A40 36" TV
Televison & Video Logo
98 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
