posted by AugustSun on Nov 17, 2007
Our Ge Zoneline Unit AZ55H15DAB is two years old. This fall, it had started making loud popping sounds and rattling noises when the compressor clicks on. The popping sounds are louder as the temperature becomes colder. The AC part of this unit worked fine this summer. The manual says that the popping sound is water hitteng the fan blades however it never happened for two winters. Anyone have an answer?
Best Solution
posted on Nov 18, 2007
If this is a heat pump system it is possible that your fan blade is hitting ice on your condenser coil.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for GE Zoneline AZ55H07D Air Conditioner
Email this problem
Email this problem
Can you Help with these Air Conditioners problems?
Repair Service
Find Air Conditioner Repairman Near You:
Find Parts
