Question about Whirlpool ED2FHSS Side by Side Refrigerator
Fridge doesnt work but the freezer working as last week i switched of & its working good after but again the same problem fridge cool & temp 5
  • 39 Answers
1. make sure frzr fan motor is running.
2.if so, the check air flow coming out of vent in freshfood side.
3.check for heavy frost built up on frzr rear wall panel.
4.make sure compressor and fan motor are both running.
also remove toe grill and clean condenser coil under refrig.
Posted on Jul 15, 2009
LG Fridge not cooling refrigerator (freezer is fine, fan is running)
those sensors do fail but if the freezer is not as cold as it should be .then the refrigerator part will also not get proper cooling . TEST the freezer temp .
Sep 25, 2015 | LG Refrigerators
Refrigerator stopped working - working on repair #4
I hope all that was covered under warranty, otherwise they are playing you and your wallet for fools. Sure sounds like a refrigerant leak to me.
Oct 14, 2014 | Refrigerators
I bought hisense HR6TFF222 a month ago, and then week later there's a problem occurs on the fridge part (the lower section), it's not working very well, it's warm as in room temperature while...
Ive just had the same issue as the op with the same model fridge. The warranty center said to adjust the front level feet to elivate the front of the unit open both doors , defrost for 8-12 hours at least. This seems to be a problem in the colder months of the year. Once a full defrost has occurred level the feet again , and turn your fridge back on. Problem solved
Dec 10, 2012 | Hisense Refrigerators
Fridge section not cooling enough but freezer OK
Is the fan blowing in the freezer section? Also, check to see if you have airflow thru the damper (vent) in the frig section.
Mar 31, 2012 | GE GSL25JFPBS Side by Side Refrigerator
Freezer frosts up, frzer & frig loose temp. Need to defrost freq
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
May 31, 2010 | Refrigerators
Fridge freezer side by side running constantly but not cooling.
Make it a habit to defrost it every week. You see, when ice forms around the evaporator tubes (which runs around the walls of fridge and freezer), heat exchange reduces (that means heat is no longer absorbed from the things inside the refrigerator) and cooling stops. See whether freezer walls or fridge walls are damaged. Do not use knives or any other sharp tools to remove ice. Do not forcefully remove items that are difficult to take out from the freezer. Defrost and remove them.
Aug 12, 2009 | Freezers
Fridge not staying cool, freezer still freezing
The defrost thermostat on the defrost heater is probably bad, it's a good place too start.
Mar 18, 2009 | Maytag MBB1956GES Bottom Freezer...
Fridge is warm, freezer works.
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 16, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Whirlpool ED2FHSS Side by Side Refrigerator Logo
274 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
