Question about Toshiba 65HX81 65" Rear Projection Television
Shakey Picture When I turn the TV on, initally the picture is shakey. After two or three minutes the shakeyess goes away. Why
  • mmorris60 Aug 17, 2008
    when I turn the tv on the picture shakes a little bit and is blurry. after a few minutes this will go away. Is there an easier fix? recently had convergence fixed. Picture looks great after it clears up. Toshiba 50h81
  • Anonymous Apr 03, 2009
    Toshiba 60" rear projection tv.
    Shakey picture for first 20 minutes then works perfect
  • 4,402 Answers
Bad cap, spray some freeze on it till it comes back and you will find the bad part.
Posted on Dec 05, 2007
Posted on Aug 22, 2009
Picture goes in and out
Looks like a problem with mother board. Call LG and they will replace the mother board in around Rs 7000/-
Jun 21, 2014 | LG 55LE5500 55 in. HDTV LED
P52939 color tubes
Projection tubes have a life span of about 3000 Hrs. After that they must be replaced.
Jan 28, 2014 | Televison & Video
Intermittant On/Off problem
What kind of TV you have? model?
Oct 05, 2012 | Televison & Video
I have a Soniq 50inch plasma, the picture has turned very red. It has happened in the past, normaly I just turn it off for a few minutes and it goes away, but it has been 2 days now and it hasn't
plama tvs do this often after you have it for a while. there is no salution but to buy a new tv. this happened to my dad's friend and he said you cant fix it you just have to buy a new one. he akso said his next tv wont be a plasma of ant type!
Jun 05, 2012 | Televison & Video
Picture is shakey when plying dvds blue ray plays perfect ???
Doesn't sound like the tv. Do you have it hooked up to a cable box? It could be whatever you have it hooked to for your normal tv viewing. The cable box could be going bad.
Feb 28, 2011 | Sony BDPS370 BluRay Player
Tv picture and sound goes away for about one minute and then comes back. After another two - three minutes, the process starts over again, and again. Please help if possible, Thanks!!!
When the bulb goes off with the sound. The lamp is starting to fail andyou need to replace it. Wear gloves when replacing the lamp. UseXL-2400(part # F93087500) replacement lamp. For informationvisit for US residents and for Canada residents.
  1. Remove the outside lamp cover.
  2. Turn the knob counterclockwise to OPEN and pull out the cover.
  3. Hook a finger through the loop of the lamp handle and pull the handle upwards then pull the lamp straight out.
  4. Put the new lamp in its place. Mount it securely and take extra care not to touch glass portion of the lamp.
  5. Turn the knob back to CLOSE and secure the cover.
  6. Put the outside lamp cover back in its place.
  7. Turn on the TV
  8. Browse MENU>SETTINGS>SET-UP>Lamp Replacement then follow the on-screen procedure.
NOTE:Disposethe used lamp properly. It contains mercury and disposalis regulated..Contact your local authorities for proper disposal.
Sep 25, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
go in audio section and select mono instead of stereo or sap
Sep 18, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Toshiba 50H13 blurry picture with white line on right side
replace all the surface mounted electrolytic capacitors on the hyper module. also called the scan converter module. this is a common trouble. what a nasty job. good luck.
Jun 23, 2009 | Toshiba 50H13 50" Rear Projection...
Toshiba 65HX81 65" Rear Projection Television Logo
218 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
