There is no sound from any input with different things, (playstation xbox cable etc)just picture small child was playing with remote.
  • 304 Answers
Check the MUTE button on the remote.
Posted on Jul 16, 2009
My green light comes on but no picture
Sounds like tv is on wrong input. Be sure HDMI wire or cable input is connected to tv. Look at which input it is on. ( like HDMI 1. Or cable etc. take tv remote (with cable box on ) press input / video button and arrow down to different inputs ( slowly ) until the right input is detected or simply go to the right input you noticed the cable was connected to. Different inputs are there for different sources of connections like DVD. Games. Etc. each work like its own tv channel. Good luck.most times this happens when you are watching tv and press the TV. channel button which will take you to a different tv mode
Aug 10, 2014 | Sanyo DP42746 42 in. Plasma Television
Sanyo 50in HDTV turns on fine, no picture or sound
How is your xbox connected to the tv? If its connected with hdmi cable. Unhook it from xbox and plug it into the back of the cable box. If nothing happens then try switching the tv input with the tv remote. Should have several different inputs. Hdmi,video,component,etc...
Feb 25, 2013 | Sanyo Televison & Video
How do I hook up my surround sound system thru my stereo and tv
connecting your surround sound system is not complicated.things you may need:OLDER STEREO SURROUND SOUND:analog red, white, and yellow cable connectorsHDMIaudio fiber opticsif you bought your stuff new from electronics store,then it would be easier.all you need is HDMI cables (mostly)depending where your inputs and outputs go, you must know the rule. OUT-TO-IN. that means if you are using a cable box, dvd, bluray, playstation, or xbox. everything in these electronic devices are OUT. then connect them to the IN ports of your surround sound. at the back of your surround sound there will be connections saying IN-dvd, IN-dvr etc. connect your OUT DEVICES.
NOTE: YOU MUST KNOW WHAT ARE YOUR CONNECTIONS, LIKE DVD-IN OR DVR-IN CU'Z YOU WILL USE YOUR REMOTE TO CHOSE WHICH CONNECTIONS YOU WANT TO USE.
now from your surround sound to your tv.the same ruleout to in of your tv. You should look for HDMI port that is saying OUT. you will connect your HDMI cable from there connecting to your IN of your tv. remember which port you plugged the HDMI cable as you will switch to that particular input. it will say at the back of your tv in-1, in-2, in-3 or as much as the manufacturer want to have in there product.
connecting your speakers.you must remember the color code.if you chose red as positive, all the red wire must be positive.colour may be different but same idea. if you have sub-woofer it will be an analog cable you will only use single cable. At the back of your surround sound there's a connection saying sub-woofer out.
now selecting your inputs.turn on your tv and stereo.newer tvs and stereos are smart they can configure there system which is turned on.
anyways if you will do it manually, you must select from the remote what is the connected input. (input 1, input 2 etc.) if you found the right input, do the players (dvr, cable box, dvd, bluray, playstation, xbox etc) turn them all on and select from your stereo remote control.note all the inputs you selected.
Dec 31, 2012 | Televison & Video
No picture on the screen. Sound is working
This problem is hard to pinpoint as there are so many variables.
If I could ask you a few questions first: -What is the model of the display?-What other components are hooked up to it?-What cables are connecting these components to the TV (e.g.. HDMI, Component, Composite etc.)?-Are you using an external sound source (stereo) or the TV speakers for audio?-Do you see and indicators or the screen when you turn up/down the volume or change inputs? This is of course using the Samsung TV's remote.
I would try these things though:
1. Turn the TV off, unplug it from the power source for 30 seconds.2. Check the cables are all plugged in firmly and correctly.
3. Plug it back in and turn on the TV. Still no picture?
4. Try changing to another input (e.g. DVD, VCR, XBOX etc if you have one)3. Check on the Tv's remote to see if there is a "picture mute", "blanking" or similar button they may have been accidentally pressed. When you press it again, you will get picture back. If there is no button and still experiencing the same problem after checking all these things then you may have a fault.
Oct 27, 2012 | Televison & Video
What are the different conections for.... at the back of the TV. (There are two plug with multipal pins)
TV's have many connections these days.
The majority of connections are inputs, which mean you can connect a external device into the back or side of the TV. For eg. you can connect a DVD player, Xbox, play station, camcorder, etc.
Most are labeled AV1, AV2, AV3 and so on. Which refers to Audio Video inputs.These connections will vary in style and are,
  • RCA style, Yellow is Video or picture connection. Red and White are sound, Right and Left........see attached photo.
  • S Video is a Video or picture connection, like the RCA but better picture quality...see photo.
  • H D M I is a rectangular shape connection and is for both picture and sound in the one cable and stands for High Definition Multimedia Interface, which is higher quality again....see photo.
So for example if you connect a device into HDMI 1 on the back of your TV, then you select HDMI 1 via the AV function on your remote.
So I believe the one your talking about with the multiple pins is the HDMI.
Hope this was helpful to you.
MobileJB
Jul 13, 2011 | Televison & Video
Pyramat 450 wireless sound rocker. Comes with white/yellow/red rca jacks, how would I install that to a xbox 360? The xbox will play through chair if I connect xbox input jacks to chair! But you then get...
You need to go buy another cable, get a good length red and white rca cable one that suits the distance between the chair and the xbox.
Then you need to get a female to female rca adapter. Connect the adapter to the ends of the red and white audio cables on xbox, connect your new rca cable to the adapters, connect the cable to your pyramat seat. Connect xbox tv cable to tv as normal.
Jul 11, 2009 | Pyramat PM450WR for PlayStation 2,...
Troubleshooting vcr
Usually one connects a RF [cable tv, Dish tv, antenna ] cable to the INPUT of VCR & a RF cable output to tv (antenna )INPUT .The reason is that if you are watching TV reception (Cable, Dish, etc) and you want to watch VCR tape, just push the tape in and it should start playing picture.
From what I understand that you are trying to say:: [ YOUR NEW TV ! ] you MUST connect to the RCA jacks, CABLE S with RCA plugs that come out of the VCR to the new TV [ INPUT & OUTPUT] jacks .When you ["" use input botton on VCR remote"" ] you are using a DIFFERENT input signal. You are not letting the TV know that you are changing the signal from RF(antenna, Cable, Dish,etc)to the RCA signal ["" I use my input botton on my vcr remote""]
Aug 14, 2008 | Televison & Video
No Picture from Component Input #1 or #2 but do have audio via Surrond Sound
Simplest thing would be that your component cables are not HU'd correctly. Having them reversed would do this.
Mr Bob
Feb 10, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Hooking up a sony playstation 3 with digital optical cable
Here's one solution, if you have an audio output from your tv, you can go from the audio output on your tv to the audio input on your receiver that way anything that is playing on your tv for example, playstation 3, dvd player etc. Anything playing on your tv will have audio on your onkyo home theater system. The other thing I would try if you want to hook ps3 directly to receiver is go to your connection settings on your ps3 menu and change your connection method to digital optical cable.
Dec 27, 2007 | Onkyo HT-S790S System
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
