Duo-Therm model #57915.531,compressor keeps running after condensor fan shuts off.Relay? circuit board?
  • Mike Butler
    Mike Butler May 11, 2010
    Sometimes a rap with handle of a screwdriver on relay will make your decision easier.
  • 146 Answers
Yes i would say it is a relay or it been wired incorrectly. you can check it manually by pushing it down and see what happens unless there are two relays.
Posted on Jul 15, 2009
Duo Therm A/C (2009 Sabre RV) won't shut off
bad compressor relay on control board. The relay is not opening the circuit, allowing the compressor to stay running when unit is turned off. This overheats the compressor and opens a thermal disk shutting the compressor off. When thermal disk cools down, the compressor restarts under load and trips breaker.
Jun 06, 2013 | Dometic Rooftop RV Air Conditioner
Duo therm fan or compressor do not run
check circuit breaker or bad relay module.
Aug 28, 2012 | Dometic Rooftop RV Air Conditioner
My GE GSL 25JFPABS Refrigerator failed yesterday. No Comressor no evap or condensor fan
Fan motor starts with the compressor. Sounds like you need a main board and condenser fan motor. Call GE. It might be covered under warranty. A known issue with certain models. You will also need serial # if you call.
Mar 23, 2017 | GE Refrigerators
I have a Duo-Therm roof top. The compressor wont shut off. When the stat is satisfied the fan stops but not the compressor. I pulled the metal control box but didnt see a real set of contacts. Where are...
Trace the wires from the compressor back to where they come from. They should be coming from a contactor or from the circuit board. It's possible the relay is built into the circuit board (it will look like a little black box on the board. Let me know what you find.
Jun 08, 2010 | Dometic Rooftop RV Air Conditioner
Duo therm air conditioner that the compressor will not start
Hello,The freezestat should be closed.Try jumping that out .
Apr 18, 2010 | Dometic Rooftop RV Air Conditioner
I have a duo-therm roof top unit. The fan or a/c will not come on. I opened the connection box and ckecked the fuse on the printed circuit board. Fuse good. reinstalled fuse and unit came on. Turned of...
Hi; You still have a loose connection somewhere. I have found just recently a problem with a customer with the same problem He had burnt wiring at the compressor terminals. Also check to see if the fan on top of R.V. is running when the inside fan is running they are connected together on the same motor up top. Also check for a dirty condensor coil this can cause the compressor to fail out on thermal overload...alpharome416
Feb 19, 2010 | Dometic Rooftop RV Air Conditioner
Duo Therm Fan Blows, No cool air. Worked yesterday, not today?
most likely compressor running could be capacitor, breaker,relay,or compressor it self start by checking power to unit
Aug 22, 2009 | Heating & Cooling
Heating & Cooling Logo
196 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
