Question about Sceptre X 7 Komodo II 17 in. Flat Panel LCD Monitor
My sceptre X7 monitor does not work. it blinks from blue to red when it off and when it on it blinks blue and it does not display anything on the screen i don't know what to do
5 Suggested Answers
SOURCE: Sceptre X7g Monitor Flashing Red & Blue Lights. Blank Screen
i fixed this problem by unplugging the monitor, unplugging the video cables. Then hold down the power button while plugging it back in. Release power button and then press power button for on. It worked then. I got the icon for no signal, i plugged back in my monitors. Sceptre X9W
Posted on Mar 10, 2008
  • 22 Answers
SOURCE: sceptre x20wg 1080p monitor
In case you know very well electronics, you must open the cover of your monitor and find a fuse burned. You change this. You must repair power supply which supports voltage to work light on your screen. You must be expert to repair this.
Posted on Nov 01, 2009
SOURCE: EMachines E19T5W Flat Panel Monitor - keeps blinking red, green, blue white lines
On the monitor below the screen has these fine pink and green lines blinking across the screen all the time on my laptop. Can you tell me how to fix it or solve this problem?
Posted on Dec 28, 2009
  • 3 Answers
SOURCE: At start-up, Sceptre X7 monitor flashes on, then
I just found after hooking one of these Sceptres with the exact same problem up to a computer that already had a lcd hooked up and the computers settings were fine that if you go to the MONITORS menue and change the MONITORS time setting from 15 seconds to 30 seconds it stops shutting off ... don't have the slightest idea why that worked, but it worked so that's good enough for me.
Posted on Feb 24, 2010
At start-up, Sceptre X7 monitor flashes on, then goes black. Must turn computer on and off numerous time before monitor will stay on. How can this be fixed?
Hi Friend,
You need to check your display setting in your computer..i mean to say..you need to click on desktop then properties then display then screen saver then change the time.....
Dec 20, 2009 | Sceptre X7G-Naga 17" LCD Monitor
Spectre x7, at startup, screen blinks on and off. blue light at bottom also goes on and off
leos343872, Black screen type of failure. Is anything still displayed even though screen is black when you hold flashlight 1 inch from lower left corner near start button??? Possible "switch-mode-power-supply" in shutdown mode. Tech or you will need to evaluate further!! Read more of my advice to other owners with BLACK screen monitor problems in my profile. or louie12fix profile. 12fixlouie
Dec 14, 2009 | Sceptre X7G-Naga 17" LCD Monitor
Monitor will not turn on blue light flashing bottom right hand of monitor
I'm having the same problem. Had the monitor for almost 2 years and everything was working fine until this week. The blue light would blink, then after an unpredictable period of time, the monitor would turn on. Seems like it needs to warm up or something. I suspect it has something to do with the capacitors not charging inside. Somewhat disappointed with Sceptre. I suppose I should be thankful that I got 2 years out of it.
Oct 09, 2009 | Sceptre x22wg Gamer Monitor
I have a Sceptre x22 gamer that has been serving me well for about two years. A week ago I started having trouble getting the monitor to ''Wake Up'' after the computer goes to sleep or when rebooting. It...
warcryofjuda, One of the guys that I work with brought in a small screen Sceptre DTV/DVI/VGA +audio unit. and it also has a optional TV/tuner module. mod S1701DTV with side mounted speakers. The viewable screen size is 14"w x 8.75"h . Oh! First things first! Turn it OFF and leave it off. Disconnect it and put it in a safe place for now. IT'S BROKE!! It will not work today, and it will not work tomorrow or the next day. Got that? Ok! Now I want to know if you would like to work together with me and explore both of these monitors and possibly come up with a fix for them? Please get back to me via my email with what ever approach you feel is best for you. We have already opened up our unit and I will try to attach some pic's for you to compare your unit with. I'm louie12fix on fixya or lmistyrel@aol.com
Bye for now.
Apr 15, 2009 | Sceptre x22wg Gamer Monitor
I have a sceptre x9g-naga III
Not an expert, but from what Ive read, this is a cfl inverter issue. I had the same problem on my Sceptre. Good luck finding parts. My solution: get another monitor.
Feb 27, 2009 | Sceptre X9G-NagaIV 19" LCD Monitor
My Sceptre X7 LCD computer monitor comes on at startup and goes black after about two seconds. I turn the monitor off and on again and the picture comes on foe about 2 seconds and then goes out again. The...
SORRY MONITORS R MONITORS THEY EITHER WORK OR THEY DON'T. WARRANTIES R THE BEST THINGS FOR MONITORS.HAVE U TRIED THE COMPUTER ON ANOTHER SYSTEM TO MAKE SURE YOUR VIDEO OUTPUT ON THE COMPUTER IS WORKING CORRECTLY
Aug 11, 2008 | Computers & Internet
17 inch flat screen monitor has trouble turning on
Make sure that the PC video output is set at 60 Hz. The LCD often will accept up to 75Hz but will not work correctly.
May 04, 2008 | Sceptre X20G-Naga II 20.1" Flat Panel LCD...
32" Sceptre LCD No POwer
0939a31.jpg This is the same problem I am having with my Speptre X20WG Naga Monitor.
The power LEDS are usually red in standby and blue in opp; but now they just go purple and nothing happens..no sound no picture. I called tech support and no dice they just wanted my money, but I think all we might have to do is change a fuse on the main pcb! As you can see the white arrow isnt really pointing to anything specific! I think the fuse is the lt blue component, but am not sure. This is all I can offer! If you gat any good tips or if anyone else finds a fix please email me pbj0327@yahoo.com.
Thanks! and good luck m007!
Nov 28, 2007 | Sceptre X20g-Naga III 20.1" LCD Monitor
Sep 11, 2007 | Sceptre X7GNAGAV 17" LCD Monitor
Screen goes blank
Yes, its not the bulbs, its the inverters that are build right into the power module and all that is wrong with that is one or more bad capacitors (bulging or burst) so don't waste $100 getting a new module from Sceptre, fix it yourself (if you have the skills and tools - which wasn't much - a new cap, some flux core solder, and iron, maybe some desoldering braid and then basically a little desoldering and then resoldering). I got lucky and only had to replace one 330uF 16V cap that was bulging and mine is all fixed. For more specifics check under the Sceptre 19" monitors where some very detailed repair procedures are posted.
Aug 22, 2007 | Sceptre 17" LCD Monitor
Sceptre X 7 Komodo II 17 in. Flat Panel LCD Monitor Logo
434 people viewed this question
Top Sceptre Computers & Internet Experts
Robert Veldman
Robert Veldman
methjd
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
