Question about Maytag MER5775Q Electric Kitchen Range
Oven cooks 10 degrees cooler. How can I fix it?
    Sergeant:
  • 222 Answers
Select bake
set the oven to 550 degres
hold the bake button until you see the temp go to zero
push the temp select up until it changes in five degree increments to the desired bump up in temp you can raise it or lower it up or down by 35 degrees in five degree increments, once you have the desired adjustment it will revert back to normal on the controls screen readout
check the oven temp and adjust as necessary, this info is available in your users manual as well.
Posted on Jul 14, 2009
Baking in the convection oven, do you set the temperature 25 degrees lower than the recipe calls for?
temperature settings in ovens vary make to make
set around the receipe recommended temp but remember that most on tv cooks always say around the temp ( around 180 or around 250 for about 1hour or about 10 minutes
When cooking , nothing is set in concrete so to speak
Jun 04, 2017 | Ovens
How long to cook 6lb chicken?
Not frozen as mentioned in my last post to you. Take it now, and drop it into HOT water for 10 minutes. That will complete the thaw safely, as it will form part of the reheating to cook process. As I mentioned, I am a trade masterchef.
Regarding cooking, 20 minutes per pound so 3 hours.
Preheat oven to 450 degrees F (230 degrees C) and cook whole (thawed) chicken for 10-15 minutes. Then reduce the temperature to 350 degrees F (175 degrees C) and roast for 20 minutes per pound.
Feb 07, 2016 | Kitchen Appliances - Others
What temp for turkey done ?
Always use an oven bag is used to promote even cooking.
Microwave on MEDIUM (50% power) for 7 to 9 minutes per pound rotating dish every 15 minutes. Not recommended for turkey over 12 pounds
Use an instant-read thermometer after cooking. Turkey is done when thermometer reads 180 degrees to 185 degrees F for whole turkey or 170 degrees to 175 degrees F for turkey breast. Insert thermometer through **** in oven bag into inner thigh for whole turkey or into thickest part of breast for turkey breast.
For easy slicing, let stand 10 minutes after removing from microwave oven. To open, carefully cut or **** top of oven bag. NOTE Microwave directions were tested in 600 to 700-watt microwaves. Higher or lower wattage ovens may need adjustment in cooking times.
Nov 21, 2010 | Microwave Ovens
Temp cycle span from on to off is 32 and 33 degrees respectvly
Obviously the thermostat calibration is out, most manufactures allow a tolerance of + or- 10%, so yours is outside this range.
You can compensate by setting the temperature lower by say 20 degrees, this will then bring it within accepted tolerances.
Hope this helps you.
Dec 16, 2009 | Whirlpool RBS305PDS Electric Single Oven
Translate temp gauge numbers to degrees
I recommend you buy a cheap oven thermometer and check the oven temperature yourself. As a gasfitter I know temperature conversions (numbers to degrees) are approximate and I think may be done on purpose so consumers won't complain if they put a thermometer int he oven and it differs from the thermostat. Check the temperature in the centre of the oven. do not use pans and trays that fill the sheld as gas ovens need room to circulate the hot air. Also do not place items in the oven so the top of it is near the top of the oven - otherwise it will burn. I have found when cooking a chicken it needs to be turned otherwist the bottom of it may not be cooked.
Cheers
John
Nov 30, 2009 | Ovens
OVEN TEMPERATURE TOO HOY
if its maxed you cant just turn it down accordinly to what they tempeture is to cook if its 350dgs use 300 dgs
Feb 22, 2009 | GE JGBS23 Gas Kitchen Range
I need a user manual for a Euro Pro Extra Large Toaster Oven
It shouldn't be a problem. You just use it like a regular oven and like a regular oven, you have to watch what you cook the first few times to be sure how it cooks. A regular gas or electric oven will be off by up to 50 degrees EITHER WAY (100 degree variable) from the factory. Toaster ovens are generally accurate to within about 10 degrees of the setting. Mainly the time it takes to cook something will be the only adjustment you should need.
Feb 05, 2009 | Euro-Pro EP278 Bravetti Platinum 1500...
Jenn-air stove temperature not constant
Sounds like your oven probe sensor has got issues. Pretty easy to fix, just look inside oven for the probe (small round cyclinder, about a pencil width or smaller, mounted usually in the back top corners), remove the two screws, then slide it out. Some models have the probes where you will have to take the back off to get to them. If your probe is ok, then you might possibly have an issue with your main oven control, which may be computer or knob type. These (especially if computer driven) can be very expensive to fix, and some need calibration. Good luck and let me know if you need any other assistance.
Nov 16, 2008 | Kitchen Ranges
When I cook or bake in my electric oven things are never done in the recommended cooking time. The heating element is working fine.
hi. thanks for the question. does the door seal properly. check that..sometimes the calibration will go off. what i tell my customers to do is.buy a small oven thermometer, that you hang from the racks . then try the oven at 350 degrees .then look at the oven thermometer . and see what the difference is. so lf ,the oven temp is a bit low .cook at 375. degrees. that will make up the difference . no parts needed. cheap fix. thanks the appliance doc
Sep 28, 2008 | Kitchen Ranges
Maytag MER5775Q Electric Kitchen Range Logo
142 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
