Question about Yamaha Mg82cx Stereo Mixer
Where can I purchase a European compatible power adapter for a Yamaha MG82CX mixer?
    Scholar:
  • 85 Answers
What is the voltage/current/wattage of the unit this info should be on the back/underside of the unit, Also what type of power supply plug does it take? Maplin electronics throughout the uk or any good electronics parts supplier should be able to help you? Have you tried ebay etc?
Posted on Jul 14, 2009
Does it have an internal battery?
HQRP AC Adapter / Power Supply for Yamaha PSR ... - Fixya
www.fixya.com/search/...hqrp_ac_adapter_power_supply_yamaha.../60...
HQRP AC Adapter / Power Supply for Yamaha PSR-280 / PSR280 / PSR-290 / PSR290 Keyboards Replacement plus HQRP Coaster, 600 related issues. ... is there an internal battery to protect memory and if so, do i need to replace it? yes there ...HQRP AC Adapter / Power Supply for Yamaha DGX-620 / DGX620 / DGX- ...
www.fixya.com/...hqrp_ac_adapter_power_supply_yamaha_psr/adapter
HQRP AC Adapter / Power Supply for Yamaha PSR-280 / PSR280 / PSR-290 / PSR290 Keyboards Replacement plus HQRP Coaster, adapter related ... need a new one, you could try to get a replacement from casio or try to get an ... It MAY appear to operate on DC BUT it can't generate the +/- voltages internally for sound .
Musical Instruments - Keyboard Accessories on Pinterest ...
https://www.pinterest.com/.../musical-instruments-keyboard-accessories/
HQRP AC Adapter / Power Supply compatible with Fulltone CATALYST / CHORALFLANGE Guitar Effects pedals Replacement plus HQRP Coaster by HQRP. $7.91. ... The MS-90 is a column monitor stand that features three internal channels - .... Yamaha SK88 Survival Kit for 88-Key YPG Series Keyboards by Yamaha.
Dec 25, 2015 | HQRP AC Adapter / Power Supply for Yamaha...
I have no monitor signal
A little vague, there, Chuck...
We have no idea if you even know how to plug the thing in... an no, it's not obvious because some people don't. Describe your connections and a little more about the problem.
May 27, 2014 | Yamaha Mg82cx Stereo Mixer
When i record i can hear me very well but the beat has like a funny bass sound to it what can i do to stop it
If your mic can "hear" the beat, it will record it as well with a reverberation that will NOT be pleasing. Maybe you can use headphones to avoid that.
Jul 13, 2011 | Yamaha Mg82cx Stereo Mixer
Yamaha mg82cx locked up, all led's on, no audio signal
Check the power adapter. It is a 38 volt AC centertapped unit with 0.62 amp rating. Verify that you get 38 volts AC between two of the pins and 19 volts AC between any other pair of pins with an AC voltmeter.
Check that the connector is seated. These can sometimes seem to be seated but not fully in place.
Apr 24, 2010 | Yamaha Mg82cx Stereo Mixer
Hiss
If trim controls or gains are set near maximum, HISS is normal as electronics generates a thermal type noise.
If gains are set in normal operating area, the noise SHOULD be minimal.
Other sources of interference like nearby radio transmitters, welders, arc lights, etc. can create noise.
Start with ALL gains turned down and find which if any cause the noise to be unacceptable.
MAKE SURE all power to this and ALL the other connected equipment come from a single receptacle to avoid ground loops.
Jan 02, 2010 | Yamaha Mg82cx Stereo Mixer
Hooking up Electronic drum kit to mider
sorry ...you haven't enough channels to mix all the kit ... you will have to run a stereo pair from the td8 to mg82 and mix it from the td8
Feb 01, 2009 | Yamaha Mg82cx Stereo Mixer
Confuse about the jack
Both stereo and mono jacks will work fine on the inputs, any guitar or mic lead will work a treat.
You can use stereo jacks for the outputs too, but to keep it simple just use a mono jack in the L out and a mono jack in the R out.
Oct 17, 2008 | Yamaha Mg82cx Stereo Mixer
Yamaha Mg82cx Stereo Mixer Logo
119 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
