Question about Celestron Optics
Miod 80s c90---focus is very hard to turn - Celestron Optics
  • 3,186 Answers
There is a small bolt that is used to set the stiffness of the focus tube-- loosen the bolt, then adjust it to the proper setting.
Posted on Jul 16, 2009
Check radiator fluid suzuki c90
Good news! You will never have to check the coolant in your C90 because there isn't any coolant required. Just make sure you check your oil level once a month.
Apr 09, 2012 | 2005 Suzuki Boulevard C90
We have a chronotherm heating system written in dutch and we need to reset it because it turns on during the day and we cant turn the termperature down
Chronotherm was a Honeywell thermostat from the 70s-80s. Better off going to home depot and replacing it. Wiring is not that hard, they give you labels for the wires. It is low voltage and will not sting you, but turn off heating unit first to avoid shorting out transformer.
Sep 08, 2011 | Heating & Cooling
How do you adjust air screws on 05 c90 fuel injected throttle bodies?
they are on the side of your carb, turning it in decreases the air, turning it out increases it :) make sure you get the right screw, the otherone is your idle screw, the iel screw is usually he biggest
Jul 30, 2010 | 2005 Suzuki Boulevard C90
2007 C90 after rideing it for about 45 miutes the Battery goes de
Have your Regulator/rectifier checked , and have your ststor checked also . Both are not hard to fix , regulator about 15 mins and ststor about 45 mins .
Mar 22, 2010 | 2005 Suzuki Boulevard C90
Galileo FS-102CTC is not showing anything even after following instructions and adjusting the focus. I see my eyelashes and anything behind me.
This is a reflector style telescope with a MIRROR in the bottom of the scope tube, and a smaller tilted secondary mirror near the front of the scope tube.. Put the eyepiece with the largest number written on it into the focuser. During the day time take it outside and practice focusing on a distant object. DO NOT USE the 2x barlow if you have one.
The moon should be your first target at night. The eyepiece with the LARGEST number written on it gives the LOWEST magnification.
Be sure the lens CAP is not still on the front of the telescope. The FOCUSER end is the FRONT of the telescope. It should look like this:
http://www.angelfire.com/80s/sixmhz/telescope.html
Dec 20, 2009 | Galileo Optics
Suzuki C90 Won't Start
Check your battery cables, especially the ground cable. Check your ignition switch for loose wires/connections. Check your fuse box. Check your wiring harness for shorts and broken wires. When you say "battery seems to have plenty of power" what does that mean? What test(s) did you perform on it?
Jun 04, 2009 | 2005 Suzuki Boulevard C90
I dont know how...
Unraqr the c90.rar file and copy the extraction to any folder on your hard disk (for future frequent use).
The following only works after refilling the cartridges or using a continuous ink system.
Note: This is for the Epson C90; there are a lot more printer specific resetters. Mine is Indonesian.
Note: This does NOT work if the system date is NOT set at July 15, 2007 !!
1. Set the system date to July 15, 2007.
2. Go to MY COMPUTER, open local disk C: then delete the ADJUSTMENT PROGRAM FOLDER (if present)
3. Close local disk
4. Click START, RUN, type REGEDIT
4. Open HKEY LOCAL MACHINE
5. Open Software folder
6. Open Epson folder
7. Delete PTSG folder (right click, remove=yes)
8. Open Epson C90 Resetter folder and start adjprog
9. Click ACCEPT button
10. Click SELECT button to go to port menu. Selected designated port number (USB ...)
11. Click the "Particular Adjustment Mode" button
12. Double click the "Waste Ink pad Counter"
13. Click the "Check" button
14. Click the "Initialization" button.
15. Turn of the printer and press "OK"
16. Turn on the printer and wait until the maintenance procedure has finished
17. Close the panels of the Adjustment program
18. Reset the date to the current date.
Note: Print these steps for future use.
Note: With a continuous ink system, make sure that the ink filling cable is not to tight; the print head with the attached ink
cabling must be able to freely move all the way to the left inside the printer. Also make sure that none of the ink tubes is squeezed tight by the black plastic clamps that are used to attach the system to the outside (front) of your C90. Place them so that the transparent cover stays slightly open.
Note: With a continuous ink system, be sure to use the "lock roller" on the ink system to close the ink supply when the printer is not in use; otherwise your ink evaporates.
Note: The continuous ink system is quite erratic in its signalling: when one of the colors is about 1/3 full on the Epson monitor, the printer might stop suddenly and display the cartridge X signal. Sometimes, with 2 colors X-ed, you have to do the procedure twice!
I don't know where you got the C90.rar download. You must have the following files:
AdjProg.exe
Apdadrv.dll
EditText.dat
StrGene.dll
If you don't have them all or miss some, pls e-mail me (hanshufkens@yahoo.com) and I'll sent them to you (attachment is about 2 MB)
Last: The C90 is a **** printer. After 4 months of use the paper adjustment goes to hell, so with printing you never know if printing will start before the paper is properly loaded. Might as well buy a new printer (NOT Epson!).
Jul 23, 2008 | Epson AcuLaser C900 Printer
Optics Logo
53 people viewed this question
Top Celestron Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Vernon Taylor
Lawrence Oravetz
Are you a Celestron Optic Expert? Answer questions, earn points and help others
