Question about Laguna Garden
I bought a askoll pb 6000 it has a broken impellor were do i get a replacement
I have a spare impeller for this model if you would like to buy it. 07717886083 text.
Posted on Oct 23, 2011
Change the water pump on a 90 hp Johnson outboard
tilt engine and remove all bolts that hold gearbox to leg , put box in vice and remove impellor house and remove impellor , check all holes and seals below housing for damage etc , if impellor has broken up then check water down pipe is clear , you can run engine with box off and put hose to down pipe and turn water on and run engine for 20min and see if engine cools b4 you fit box so you know no blockages etc ! as you fit impellor rotate clockwise as you push down on housing , bolt up and fit box and as you do turn flywheel to engauge driveshaft ! Bobs your uncle ....
Dec 11, 2013 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Yz 250 water pump leak
Hi mate this will be the oil & water seals the leak from weep hole is basically a warning light to tell you it needs replacing asap, you need to remove impellor, carefull not to lose the spacer washer behind it...then remove the water seal clean the surface it came from and replace with new seal. Now to do this 100% I would always replace the impeller shaft as the shaft wearing is usually what caused the seal to fail and I would also replace the oil seal which is the other side of case that you just changed the water seal (oil seal sits behind the small bearing) I would also consider replacing this bearing but maybe not critical? all up the impellor shaft the 2 seals and bearing last time I bought cost about $160... no special tools required just quite a bit of time required as you should really remove the outer engine case to access the impellor to undo it and to get to the oil seal and bearing, how ever I know guys do just open the water pump cover then rattle gun off the impellor only replace the water seal then install the impellor and cover back on then ride away! this will work and will fix the leak but is definitely the incorrect way to repair this and will be temporary fix but thought you may like to know this alternative as is very handy way to do it if your on a race meeting and just need to get through the last race or two.
hope this help cheers... Moto X Parts online.com
Feb 28, 2013 | 2003 Yamaha YZ 250
Pool pump does not turn on it just hums
If it hums and the impellor shaft is not turning, it's jammed and will trip the breaker after it over heats.
If the impellor shaft is turning, may have a broken impellor. After closing the inlet and oulet valves, I would take the pump cover off and check... Good luck...
Aug 07, 2011 | Waterway Pool & Spa
My Bosch dishwasher sounds like it is running but does not clean the dishes.
check bottom of dishwasher screens for any blockages or obstruction preventing water from getting into pump. may need a wet vac to **** water out of pump and use a small mirror to inspect pump openings. if no obstruction, the pump impellor maybe broken. replacing the impellor is fairly difficult. the dishwasher has to be pulled from under the counter. repost if you further questions.
Jan 10, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Will not drain
Check where drainhose connects to waste pipe for blockage. If OK, blockage likely to be in pump impellor.
Disconnect from power.
To access pump:
Open door and remove all bottom filters. Remove all water from inside machine. In the bottom of the sump on the left hand side, you will see a star screw- remove this screw and you can remove the cover it is holding down. Under this cover you will see the drain pump impellor (white fan blade). This impellor should turn relatively easily- check for blockages (careful for broken glass!!). It can be a bit hard to reach, but you need to get your finger right around underneath impellor to ensure nothing is stuck underneath- try flicking the impellor a few times to remove any obstruction from underneath. Once clean and free from obsruction, reassemble and test
Aug 08, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Same as others with Krystal clear model 635 pump.
We too have an Intex pool and opted to not waste money on their pumps which arent adequate enough to properly filter the pool. We bought a nice sand filter system off a great seller on amazon for $305 delivered. (DO NOT BUY "GAME" system for intex pools, my sister bought one and has had nothing but problems and just bought 5 weeks ago).
We are very happy with the results from our Waterway sand filter system. We did not have to buy any adapters to fit it to our pool. And it keeps the water perfect! We have an 18' x 52 metal frame pool. If you intend on using your pool for years, I recommend buying a sand filter system. It is more expensive than replacing the intex pump, but you will be much happier with the sand filter system.
Hope this helps. Good luck!
Jul 19, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Indesit draining problem
Yes, it ought to be fixed on. Best plan is to take the motor off the back of the pump body, then do a web search on "Askoll Pump". Compare the one with the pictures on the other. Askoll pump motors are fitted to most UK machines these days, are easy to buy and fit, and a good deal cheaper than replacing the entire pump. If the motor doesn't look like an Askoll, a complete Indesit replacement Pump is a little under £30 on the net, so all is still not lost. A.
Mar 10, 2007 | Indesit W 123 Front Load Washer
Garden Logo
238 people viewed this question
Top Laguna Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Laguna Garden Expert? Answer questions, earn points and help others
