Question about Maytag Heating & Cooling
Ac just stop working. we check the outlet and it is fine. help me please, diane
  • 614 Answers
If you have power to your outlet. The problem is inside the unit. Does the fan run? If it does not sounds like a blown fuse or control problem in the unit. Does the power cord have a reset button on it if so push it. It is ground fault surge protector.
Posted on Jul 14, 2009
After I used a new phone charger, immediately ac stopped and charging outlet also went dead. All fuses are fine.
There are these things called fusible links, that may be your problem. What year is your vehicle?
Jul 23, 2015 | Subaru Legacy Cars & Trucks
Hitachi AC stops working after Red Light glows
No model number, no error codes!
check the obvious like is condensate water getting released, is anything blocked including any filters, the inlet, the outlet, or any hoses. Is power OK.
May 19, 2014 | Heating & Cooling
Mr coffee model gbx23 stopped working, it won't turn on.
It might be a problem with your outlet, and not the coffee maker. Your kitchen outlets should be GFCI protected. There is supposed to be a sticker on all outlets that are protected by a Ground Fault Circuit Interrupter, but sometimes they are left off. Look for an outlet in the kitchen that has a rest button between the outlets. You can also take the coffee maker to a known working outlet, or bring something that you know works to the coffee maker outlet, to see if it is the outlet that is not working or if the coffee maker is still not working at a good outlet. If the outlet isn't working, try others in the kitchen to see if they are. If they are not, and you didn't locate a reset button on one of them, then check the breaker box for a tripped breaker.
Coffee makers do have at least 2 safety switches inside them, but they are only to keep them from overheating and catching fire. If one of the switches did go bad it is possible that it might shut down the entire machine. If that is the case, then it's time for a new coffee maker, as the safety switches are not servicable.
dd1bd15d-8ff7-4198-9167-3cc45a5562ef.jpg120v AC GFCI outlets
(220v AC outlets will have the same reset buttons)
Apr 28, 2014 | Mr. Coffee GBX23
My old Kenmore window unit has all of a sudden stopped working. Was working fine then just stopped coming on. The wall outlet checks out fine. Is there a re-set on the unit? What else can I check?
Hello, if the unit is receiving power check the capacitor, this is a round or oval can located inside the control panel of the Ac, it controls the fan and compressor operation.
May 23, 2012 | Kenmore Heating & Cooling
Magnavox hdtv green light
Hello
Unplugging the machine makes it do a reset on itself hence the normal operations after plugging it.This indicates a power problem on the machine or on AC outlet supply.
You may need to check the AC outlet's voltage supply and make sure its in order.Check this by plugging another electrical appliance onto the AC outlet and see its operations.
If the problem persists and the products still on warranty,please let the Magnavox guys have a look at it.
Ken.
Jan 22, 2012 | Televison & Video
My power adapter won't work in a 117 ac volts outlet. It works in a 120 ac volt outlet. And it gets hot. Why? My Lenovo adapter works just fine in the 117 ac volt outlet.
check the amps (A) not just the volts (V) of the computer. The details (A and V) on the adapter should always be less than the details (A and V) on the laptop/notebook (see under it).
hope this helps,
kc
Feb 23, 2011 | Samsung N145-JP01US Netbook
I recently installed a GE Simon XT wireless security system. It worked fine upon initial installation. However, I decided to relocate the panel. At the new location I had to extend the transformer lead to...
Check the outlet to ensure it :1- has power , 2- is not a switched outlet. Check your wire connections to ensure they are secure. If all of the above are good, the transformer may have shorted when disconnecting. Use a voltage meter on the transformer terminals and the AC scale, check the output of the transformer.
Apr 27, 2017 | GE Security Simon 3 Wireless Home Security...
I have a Bosch Power Box PB10-CD, the GFI outlets clicks on/off
Disconnected the GFCI outlets, and everything works just fine. Ridiculous that Bosch manufactures GFCI outlets that does not last for 2 years. The cheepest American made GFCI outlets last practically for ever. Beeing "Bosch", the replacement outlets cost $38 plus shipping.
It is ridiculous.
Sep 16, 2009 | Bosch PB10-CD Radio/CD Boombox
My airconditoner window AC suddenly stopped working.. I had checked the power supply also, with the remote also its not working..plz help
Not much you can do unless you can do. Did you checked the outlet. Was the AC unit powereed up so the remote would work
Aug 20, 2009 | Heating & Cooling
My laptop stop charging.
Batteries get old and wear out. Be use AC outlet is working. Check for power light on AC/DC charger box between laptop and AC.
It is common for Laptop charging/power connectors to get worn and/or loose(intermittent). Try to get charging light on PC by wiggling power connection to PC.
If not, if you have a VoltOhmMeter(VOM). check for 5V on barrel power connector on the charger side, that plugs into PC, Outside conductor is GND and Inner connector is (+5V). VOMs are cheap at RadioShack or AutoParts stores and are a handy tool to have around the house. Book shows you how to measure. PC is 120V AC on Wall side of PC Power Supply from Wall Outlet, and 5V DC on PC side of Charger.
Charger may be defective. Cheap on Ebay.
Feb 23, 2009 | Acer Aspire 3680 Laptop
Heating & Cooling Logo
101 people viewed this question
Top Maytag Heating & Cooling Experts
Bill Long
Donni Steen
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
