Motorcycles Logo
Robin Benton Posted on Dec 26, 2015
I have a Baja 5 wire stater/rectifier 150cc.Need wiring diagram w)colors!
2000 Subaru outback w type c radio/CD/weather replacement
This often doesn't work because the radio is monitored by the Body Control Module on the 5 volt computer network.
Wiring
Subaru Legacy, Outback, Baja (1993-2008) Car Stereo ...
Pinout Guide https://pinoutguide.com > ... > Subaru pinouts
Oct 22, 2019 - Pin #. Function. Legacy / Outback / Baja Factory Radio Connector Wire Color (wires go to car's Speakers, etc.) Subaru After-market Harness ...
2000 Subaru Impreza Car Stereo Wire Colors and Locations
the12volt.com https://www.the12volt.com > installbay > stereodetail
2000 Subaru Impreza Stereo Wiring ; Left Front (-), Green/Black ; Right Front (+), Red/Yellow ; Right Front (-), White/Black ; Rear Speakers, 6 1/2" Rear Doors.
Installation kits
https://www.google.com/search?q=2000+subaru+outback+stereo+installation+kit
Looking for a Ricardo gy6 complete waiting diagram that's color coded
Most stators use four wires if single phase. Using a DVM it should be easy enough to work out which wires go to the rectifier block and which wire is ground.
I reckon Green is common or ground and the rest don't matter where they go.
Wanting to know which wire and also which colour stripes goes were in 2004 Subaru Impreza car stereo please?
1helpful
How to hotwire a 150cc baja
Here u go. B b.
May 15, 2013 • ATVs
Need ignition wire diagram for a baja 50cc 4 wheeler
I would like to se how to wire up a cdi dc to a 250 water cooled scotter
1helpful
Bench start kv 550
Assuming it's a KZ550, first off, your gonna need the battery, ign module, rectifier/regulator, and ign. coils. There should be a wiring harness (5 wires or so) coming from the alt housing (on left crank end) with 2 yellows one pink(to rectifier),red/blk(ign power to cdi) & (light green is neutral light- not needed). Next, assuming there's no points, there should be a 2 or 3 wire harness (usually blue/brown) from ign triggers (on right crank end) these need to go to CDI module. Then make wires from CDI module to coils. Don't forget to ground everything to motor case. Also if it's electric start only, your gonna need the start solonoid ,too. If you want a detailed wiring diagram, let me know what color wires & how many there is on the rectifier/regulator and CDI and the motor and I can email you a diagram.
5helpful
2answers
Butchered wiring on baja 50 atv
WWW.BAJAMOTORSPORTS.COM
CLICK ON BAJA 50 THEN ON THE RIGHT IS A LINK TO A PDA FILE OF OWNERS MANUAL WITH WIREING DIAGRAM.
GOOD LUCK
Top Motorcycles Experts
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a Motorcycle Expert? Answer questions, earn points and help others
