Cars & Trucks Logo
jeremy muskin Posted on Dec 26, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to reset the lock codes on the factory radio
Mikey
Level 3:
Top Expert:
  • Cars & Trucks Master 6,904 Answers
  • Posted on Dec 27, 2015
 Mikey
Level 3:
Top Expert:
Answers
6904
Questions
5
Helped
1621492
Points
26106
Anti theft security radio codes can be emailed to you from your radio serial number from this site: Radio Codes United Kingdom Gumtree
paulmacintyre
Level 3:
  • Cars & Trucks Master 3,218 Answers
  • Posted on Dec 26, 2015
paulmacintyre
Level 3:
Answers
3218
Questions
0
Helped
967261
Points
11418
Owners manual will give instructions on how to enter lock code. The lock code is 4-5 digit number usually printed on a card amongst the owners manual/documents
I need system reset codes for 2005 Chevy Equinox. Car is fine, radio fine, just need to reset OS to factory specs so radio will play. Has been checked by three different shops
You need to input the radio code to get it to play. Take it to the dealership parts counter and they can get it for free. It has a theft lock so if the battery is disconnected you need to input the code.
Radio will not come on batterie new what could be the problem
If the radio stopped working when you replaced the battery, there is probably a security code that must be entered into the radio to reset. This is done by the manufacturers to discourage theft of factory radios. If the lose power the lock and must be reset. Check the owners manual packet for an unlock code. If not there, contact a dealer for more help.
3helpful
2005 honda crv the radio is lock and i lost the code serial number 10008179
The reset code for your radio is located in the glove compartment. There should be a small sticker on the inside of the compartment door, usually near the left side. The sticker has two sets of numbers printed on it. The number set with five digits is your reset code. Use the radio preset buttons to input the code. If done correctly, the radio should come on immediately and show the factory default presets.
Positive feedback is greatly appreciated.
God Bless and good luck.
20helpful
2answers
Default code to unlock factory radio in a 2000
How to Reset GM Theft lock Radio's
Article Disclaimer: This article is meant to be used by Delco Radio owners to reset there radios. In no way is it meant to be used for any unethical or unlawful ways.
Purpose
The following instructions will allow you to reset any GM (General Motors), Cadillac, Oldsmobile, Buick, Pontiac theft lock radio.
Requirements
The theft lock radio must be in "LOC" mode.
Procedure:
1. Turn the ignition ON (The radio should display "LOC")
2. Hold down the Radio Presets 2 and 3 buttons for six seconds
3. The radio display changes from LOC to a three-digit number. Write this number down. You now have fifteen seconds to complete the next step.
4. Press the AM/FM button
5. The radio display changes to another three-digit number. Write this number to the right of the first one
6. You now have a six-digit number, the first three digits are from STEP 03 and the last three digits are form STEP 05
7. Call 1-800-537-5140
8. Press 1 then # (pound). You'll hear "Invalid Code, try again"
9. Press 139010 or 106010 or 206010 or 202107 then # (pound). You will be asked to enter your four or six digit code followed by *
10. Enter the number from STEP 6 then *
11. Listen to the four-digit number and write it down. It will be repeated twice
12. Turn the ignition ON (The radio displays LOC)
13. Use the MN and HR buttons to enter the code from STEP 11
14. Press the AM/FM button. The radio display changes to "SEC". Your radio is now "un-locked" and usable.
Dealership Codes
139010
106010
206010
202107
Troubleshooting
If you fail to enter the correct code eight times, the radio goes into INOP mode. You have to wait an hour with the ignition on before the radio returns to LOC mode.
To Read the original article or read similar articles please visit kingbain.com/how-to/unlock-gm-theftlock-radio-s
Good luck (remmeber comment and rated this).
2answers
I have a 99 gmc and i want to take the factory radio out but it has theft lock and i'm not sure how to get it out, got any ideas?
theft lock is an electric code that keeps the radio from working if the power is disconnected you must reprogram your code to work again if theft lock is not programed by the owner it needs no code to work if you are going to replace it with an after market radio it is mute any way
The factory radio has been locked out
the dealer is the only one that can unlock a locked radio, they will need to remove the radio, get a "code" off of the sticker on the back of it, and then call the dealers unlock assistance number to get an unlock code. it cant be done with out the dealer. im sorry :(
2helpful
2answers
I have a 2005 silverado, if i dissconect the battery,will the factory radio lock up?
Yes so I would make sure you have the code from the factory at hand if you remove the power.
If you dont have it then you need to get it otherwise you will need a new radio face a return to factory cost
1helpful
Radio reset/ When alternator replaced on my 1999 Mercedes c230 radio deprogrammed. The original factory code doesn't work. Is there a way to reset? I am locked out.
If the original factory code doesn't work, you need to pull out the radio and get the serial number on the side of it. Then contact the car dealer or the manufacturer and they would give you the code.
The code that you are referring to is also called the anti-theft code. This code is unique for each radio. No body could provide you the exact code except for the dealer or manufacturer.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
