Question about Makita Hammering
Install grease pack in makita hm 1810 - Makita Hammering
2 Suggested Answers
  • 885 Answers
SOURCE: I have a makita hm 1810 hammer green light stays on hit switch light goes off
As stated in the manual:
The green power-ON indicator lamp lights up when the tool is plugged to the mains. If the indicator lamp is lit but the tool does not start even if the tool is switched ON, the carbon brushes may be worn out, or the motor or the switch may be defective. If the indicator lamp does not light up, the mains cord or the indicator lamp may be defective.
Posted on Aug 30, 2012
What type of oil shall be used in makita hm1304 demolition hammer?
You require Hammer Grease, All good tool shops should have grease to suit. see link below:-
Hammer Grease 90582 for Makita Power Tool eReplacement Parts
Feb 11, 2016 | Makita Hammering
How to install drive roller on my makita 9401 belt sander
DONT forget to order and replace also allways the sinter bearingbus on the machine because to protect you from a dissapointment because otherwise the belt will turns off and cant be (good) controlled again , replace the drive roller allways and clean the front roller axle if its only dirt on the front roller use a little sillicon grease film on the front behind can use a little bit more sillicon grease between the axle rings and new bearing bus. remove the dry grease in the driving gear space and renew the lubricant in it with a multipurpose grease .
Sep 04, 2014 | Makita 9404 4'' x 24'' Belt Sander
What type of oil
http://www.homedepot.com/p/Makita-Hammer-Bit-Grease-194683-7/205182387
For outside chisels
Inside its depend on the model but most time its a Makita 181490-7 or for the older types Hammer grease Makita P-08361
Feb 19, 2014 | Makita Hammering
What grease do you use for a makita demolition hammer
MAKITA HAMMER DRILL GREASE 30G (181490-7) or for the older HM models Hammer grease Makita P-08361
Nov 05, 2012 | Makita Hammering
Aug 25, 2012 | Makita HM1810 Electric Demolition Hammers
WHAT TYPE OF OIL DO YOU PUT INTO A MAKITA 1810 BREAKER
this tool does not require daily maintenance, but if the grease needs to be refilled it takes 60g/2oz of hammer grease part number A-90582. This is packaged in 1oz tubes. They also show oil and that part number is 181118-7. If you go to their site "makitausa.com" you can download or look at the section on maintenance and it shows you how to fill the reservoir. Good luck.
Jun 24, 2011 | Makita HM1810X 70 lb. Breaker Hammer with...
What type of oil i will luricate to my makita HM demolition breaker
demolition hammers require hydraulic oil in most cases.
Any good tool shop should have hydraulic oil to suit.
Feb 25, 2010 | Makita Hm1500b 42-pound Demolition...
What kind oil use for makita hm 1304bx1
What kind of oil is used in a Makita Demolition Hammer?
Oct 01, 2009 | Makita Hm1304bx1 Demolition Hammer +...
Makita 8406C Gearbox oil
It uses grease to lube the gearbox. makita supply their own grease so you should be able to get a small tube from your local dealer. You don't have to use Makita grease though, just general grease should be fine. Not too thick and heavy, or too oily and light. I know that sounds a bit vague. Do you have other machines that you have grease for? SDS hammer drills, saws, any small power tool like that will use a similar type of grease.
Nov 01, 2008 | Drills
Hammering Logo
148 people viewed this question
Top Makita Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
Andrew Taylor
Andrew Taylor
Are you a Makita Hammering Expert? Answer questions, earn points and help others
