Question about AT&T 9353 Cordless Phone
The handphone is dead.
The handphone is not working. I thought the battery pack was dead and got a new battery pack. I charged it for 24 hours and still nothing. I checked the connections and they are fine. I brought another phone and plugged it into the wall jack and it worked fine so the wall jack is good. I have no idea what is going on. Thanks,
  • 72 Answers
MAKE SURE YOU HAVE INSERTED THE BATTERIES PROPERLY AND THE RIGHT WAY,
EVEN WITH PHONES THERE SHOULD BE AN ICON SHOWING YOU THAT UNIT(S) ARE CHARGING.
FAILING THAT CHECK WITH ANOTHER SET OF BATTERIES AND REMEMBER TO CHECK THE FUSE IN THE PLUG
Posted on Jul 14, 2009
Just got a 2002I thinkxcaliber electric scooter. 24volt. Wanting to test the motor before getting a battery pack.
24 VOLTS is 24 VOLTS. 12 wont do the job. Also by running a battery not meant for that unit, you could damage it.
Feb 05, 2017 | Drills
My GRE PSR295 scanner wont switch on
first off check your batteries. if you are using a rechargeable battery pack disconnect it and try it off the power supply alone bad battery packs can and generally do keep radios from powering on. If this allows it to come on, try charging it for 24 hours, and then deep cycling it several times ( run the scanner with sound such as on a noaa weather channel) until it goes dead and then recharge, to recondition the battery pack. if this doesn't work the pack will need to be replaced or rebuilt (batteries plus can do this) if the radio just uses discrete rechargeable batteries simply replace them. meanwhile I'll look for a manual for you....
Here you go
http://www.manualslib.com/manual/703072/Gre-Psr-295.html#manual
Feb 16, 2015 | Radio Communications
I accidentally left my EN-EL14 Ultra High Capacity Li-ion battery on the charger for 24 hours at least - is it toast? The manual that came with my Nikon D3200 says leaving a fully-charged battery on the...
Does the battery pack work? Leaving it on the charger for 24 hours shouldn't hurt the pack (too much) since the charger shuts off when the pack is fully charged. The most likely result would be a slight reduction in the capacity, but it should still work.
You shouldn't need to order another battery pack unless it no longer works.
Aug 22, 2013 | Nikon D3200 24.2 MP CMOS Digital SLR with...
N95 nokia i have a new battery it charges within 2 hours and runs out quickly
Try using the phone until battery dead.
Wait 24 hours
Charge for another 24 hours
And your phone's battery now will perform as a really new battery.
Nov 20, 2009 | Televison & Video
Nokia 6300 Switching off
Purchasing a new phone is easy and everyone is always in a hurry to use new phone but never go through the manual properly. You did the same you didn't put the battery on charge for 24 hours. Now to check your phone take another charged battery for nokia put it inside your phone and start it. It will deffinetly work. In order to revive your dead battery keep your battery on charge while the phone is switched off for minimum 24 hours. If it gets revived its ok or else purchase a new one.
Jul 25, 2009 | Nokia 6300 Cellular Phone
Harley davidson 2002 1200cc sportster dead battery
Check the stator and regulator and make sure it is not over charging the battery and therefor burning it up. Should be putting out 12 - 14 volts
Jul 02, 2009 | 2006 Harley Davidson XL 1200 C Sportster...
Dead battery. Brand new computer. Only works with AC connected
If it is new then Is must be under warranty and you can get it replaced
Jun 21, 2009 | Acer Aspire 4315 Notebook
New battries won't charge.
Sounds like the batteries are completely dead, you'll probably need to replace them, sometimes you can only use batteries until they die, and that goes for Wheelchair Batteries too. If they won't charge or keep a charge then they are dead.
Mar 03, 2009 | Jet 3 Ultra Power Chair
AT&T 9353 Cordless Phone Logo
140 people viewed this question
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
