Question about Sony Xplod XM-554ZR Car Audio Amplifier
My 600w power amp XM-554ZR wont turn on.Its an Xplod 4/3 channel, and it was working fine...until yesterday that i checked it. the green light was off.
    Problem Solver:
  • 5 Answers
Open it n there is a red wire look at the end of it n u would see a black celinder with a with a white strip on it change that part if it is burn
Posted on Jul 14, 2009
Xplod XM-554ZR Car Audio Amplifier: powr/protect light comes on red not green...
Hi, disconnect all speakers from unit and try again - if red light still shows then your amp has died.
If the light goes green, then start testing for shorted speaker/wiring. This includes speaker wiring to vehicle shorts - there should be an o/c reading on your meter
May 05, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
I have a Xplod XM-554ZR Car Amp and the green light is blinking it worked just befor and now i have no sound
The amp is in protection. Disconnect any speaker from it, then turn it back on, if it's not flashing, check your speakers with a meter and check speaker wires for shorts. If it's still flashing, you've blown the protection circuit and it needs to be replaced or repaired. Hope this helps
Jun 11, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Xplod amp will not get off of power protection mode
if the protect light stays on the amp is blown or has flawed components and is only repairable by expirenced sony tech
May 18, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Power Protection Light Will Not Switch Back to Green
Disconnect all speakers, then turn the amp on. If there is no internal problem with the amp, it will go green. If it does go green, reconnect your speakers one at a time with the amp off then turn it on. when you connect the speaker that's causing the problem, the amp will go into protection. At this point, it's one of two things, a bad speaker wire (screw thru it or touching another terminal) or a bad speaker(burnt voice coil) to test that wire, disconnect the wire at the speaker and turn on the amp, if it's still green, all's well in the wire department. Meter the speaker with a multimeter on resistance, if it's blown the meter will read 1.... If you don't have a meter, connect the speaker that's having the problem to the other channel and test again, if it goes into protection, you've got your answer. Bad speaker. Hope this helps
Apr 14, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Hi i have a 600 watt sony xplod amp model xm-554zr and it recently stopped working. when i turn my car on the amp turns on but only for a sec then the protection light comes on, on the amp and it wont...
sounds like maybe a speaker short, try unhooking your speakers and then powering up your amp, if it then powers up with the speakers unhooked try hooking up each speaker one by one untill the amp goes back into protection and then you have your bad speaker.
Mar 08, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Cant get amp to work
there are two nobs on the back of the amp they have to be turned inorder to ajust the woffer vol. make sher its not in power safe mode that will be a red light insted of a green one
Sep 16, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Sony xplod xm-554zr amp
try disconecting ur battary for 2 min and try it again
Jan 18, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
My amp works on tuner but switches off when i change it to cd
The remote turn-on wire from your amplifier is connected to a blue wire behind the head unit. That's a power antenna activation wire, so the amp only turns on when the tuner is on. Switch it to a blue/white wire from the head unit instead; that should be the amp remote turn-on output.
Jun 16, 2007 | Sony Xplod XM-554ZR Car Audio Amplifier
Sony Xplod XM-554ZR Car Audio Amplifier Logo
432 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
