Question about Maytag Washing Machines
Spin cycle works,but water does not come in. - Maytag Washing Machines
  • 396 Answers
Check if hot and cold both do not work? Do you hear a click when you start the wash cycle? If one temperature works and the other will not it should be the water valve solenoid. If you hear a click that could be the start of the water valve solenoid (good sign). If you do not you will need to remove the back of the unit and check with a volt meter to see if the voltage is applied to the solenoid connector. The water solenoid is back where the water hoses connect or follow the inside hose to where it spliced into the hose inlet. The washer has few sections. The Controller Circuit Board (controls the timing), Drum, Transmission, and three Water Valve solenoids (hot and cold and drain). My bet is on the solenoid, if the cold water works and the hot does not you may be able to swap the connector or solenoid to see if the condition changes. If not you may need to use a volt meter to test if the voltage is present when the wash cycle starts. If so make sure you have water pressure going into the washer. Then replace the valve after turning off the water and draining the hose. If you do not have voltage you will need to use the schematics to trace the voltage back to the control board. It could be the control board but I do not think it is.
Posted on Jul 14, 2009
Spin cycle on washing machine not working
The spin cycle relies on the sensors turning on the sump pump to pump out the water and a solenoid valve to open to allow the water to drain. They are both controlled by a water sensor located in the bottom of the machine. If it does not sense the water it will not let the pump start or the drain valve open. Check it out.
Jan 12, 2013 | Washing Machines
This is for a Whirlpool washer and dryer thin stack. All four of the wash cycles work AND all four of the spin cycles work, but the rinse cycles do not work. I have to manually skip it forward past the...
I would suspect the water inlet valve as being the problem,if it drains the water and spins the lid switch is going to be good.The thing exclusive to rinse cycles is that they only fill with cold water,and that is what i suspect the problem being is that it's not filling with cold water on the rinse cycle because of a bad water inlet valve.
GENE
Sep 12, 2011 | Washing Machines
Will not fill with water but works on spin cycle
If your washer won't fill with water, but works in the spin cycle then the washer is sensing that water is in the tub. If there isn't water in the tub, then it is probably a sensor. If there is water but the spin cycle doesn't get it out, then look at the pump or control board.
Jun 08, 2011 | Maytag Washing Machines
AEG Lavamat 76400 during spin cycle blows a fuse
its not the heat element its the water pump i would say it has gone to ground try disconnecting the water pump if the fuse does not trip then replace the water pump
Jul 03, 2010 | Washing Machines
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Cold water pours in during final spin
No - the timer is the likely suspect.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 15, 2009 | Kenmore 98702 Stacked Washer/Dryer
Washer won't advance from cycle to cycle
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
* It's the timer, if your washing machine fills with water and begins agitating, but the timer never
advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace
the timer.
* It may be a cold-water supply problem, if the washing machine fills with water, agitates,
drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Nov 16, 2008 | Danby DDW1805W Designer Series...
Fixn my GE washer spin cycle
It sounds like it could be the lid switch, check to make sure the lid switch is clicking when you close the lid.
Jun 27, 2008 | GE WHRE5260E Top Load Washer
Washing Machines Logo
51 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
