Question about Norelco 7610X Electric Shaver
I disassembled to clean and can't put it together again. Please help
    Problem Solver:
  • 14 Answers
I will describe how to re-assemble a 5886xl, it should be similar...but maybe not. If you mean just the shaving head, not the whole shaver, skip to the bottom here.
There are 2 circuit boards within the 5886xl, the bottom one with display snaps into the top board's multi pin connector, but before, there is a nylon spacer that goes between the boards, alignment is simple, note the cutout for the beeper. If replacing the batteries, you can solder new leads onto the old areas, either by poking wires through, or if having broken off the old battery, onto the flat thin areas left. These may break or come loose during soldering however, so the through-way may be better. Now you can reassemble. There are 2 screws holding the head on, the black plastic piece with the motor attached and the 3 rotating driver sections. The bottom circuit board should fit into the display containing side piece fairly easily. Snap the plug connector into the hole. Screw the 2 screws that hold the motor/head assembly to the display side. There is a retaining piece for the battery in this model, which has a snap that goes into the 2nd circuit board, and the v-wedge holds the battery in place.If using a prebound pack, you can leave this out, and use the small piece of neoprene foam that prevents shaking, that will work. Ok, there are 2 more pieces in this model here...you place a piece that has a hole in the middle (to accept a screw) and 2 clasps...this goes right behind the motor, and over the battery posts. Should snap in. There is another piece that goes over the charge connector, it has 2 holes middle, and 2 to the sides, those at the sides get 2 more silver screws. In this model, there are 2 black pieces, slide them into the sides appropriately. Now place the top section into the shaving head assembly, drop it down onto the back with the connector...should line up just right. There is a screw hidden in the popup shaver section, open that, apply a brown/black screw. The last screw goes at bottom. Attach the head, and you are done.
Now if you removed the retaining clip that holds the individual heads on...place the head assembly on a desk, shaving side down, with any cutout for release button at bottom. You will have 3 screen pieces (which apply to your face)...each has a blade inside. So, if re-assembling, place the screens inside the head assembly. Then insert a blade into each. Apply the tri-circular blade retaining clip piece into the assembly, push gently, and rotate the little round gear piece in the middle while doing so, clockwise to set. Pop the head back onto the razor. The heads should auto-seat once you turn it on. Voila? :)
Posted on Aug 05, 2009
Forgot how to put whirlpool washer back together
Go to www.repairclinic.com and enter model. You will be presented with a list of common replacement parts and may be able to view a generic Whirlpool disassembly video. Following the disassembly procedure in reverse should get your machine back together again.
Feb 25, 2017 | Whirlpool Washing Machines
Can I disassemble the loveseat to make it fit through the door.
I think you can disassemble tis, but you never will be able to put it together again. Ask some strong guys to help you to bring it in the room you want it. Sometimes it only needs to be put on its side and make a turn. use some cloth to shield the exterior. Must fit to almost all normal doors.
Jun 10, 2014 | Ashley M Ashley Furniture Wesley - Sienna...
Re-assemble Nikkor 85mm f/1,4 after cleaning iris blades
Oh dear. I take a lot of photos during disassembly to prevent this situation and take copious note during service (never worked on an 85/1.4, can't afford an 85/1.4). There is a Nikon repair group on Yahoo, if you post your issue there some kind soul may have a manual of exploded diagram that will aid in your situation.
Dec 14, 2013 | Nikon Cameras
The lense for my Nexstar 6se was taken apart and I don't know how to put it back together properly. HELP!!
The eyepiece should NEVER BE DISASSEMBLED! Since it has multiple lenses inside no one can tell you how they go back together. This also voids the manufacturer warranty.
Go and buy another eyepiece and NEVER ever disassemble them. Only the OUTSIDE surface ever needs cleaning,
Here is one retailer who sells eyepieces.
http://www.agenaastro.com/
Sep 05, 2010 | Celestron Nexstar 8i Special Edition (480...
Recently bought a tower spy scope and I wanted to clean the diferent lenses now I can't put it back together help please?
Try it with the flat sides together -- if this does not work then try it with the flat sides APART.
Never disassemble a lens. Only the outside surfaces need cleaning.
Aug 27, 2010 | Optics
After changing the alternator 3 or 4 times. the battery 1 time i found that its not charging. each time i changed the alternator i had the charging system checked. they told me it was charging fine. then...
Your alternator can be rebuilt with parts from honda. At this point a new one would have been the way to go. It is possible you are having a problem with the wiring harness( broken wire, bad fuse block,etc.) You may even have a problem with the contact base of your ignition switch (dirty or broken). It snaps on to the bottom of the key switch. Mine stranded me at Mount Rushmore. I was able to take it the ignition switch, put in the on position, remove the contact base, disassemble it,scrape the contacts clean , put it back together, and drive away. Hope this idea helps with the problem.
May 23, 2010 | 1992 Honda GL 1500 Aspencade Gold Wing
I disassembled carburator parts brake down.
www.thevirago.co.uk - give them a try you might even get the owner manual as a free download
May 20, 2010 | 2005 kawasaki KLR 650
Trying to figure out how to put back together an old 1950's Merritt and o'Keffe stove that someone took apart to clean and couldn't put back together again. It worked before they tore it apart but is in...
Good luck. I would myself try to find a general stove schematic and work out how different it is. There may be a few different rated thermostats and elements, but the bulk of the wiring pattern will be similar.
It may have to come a bit of trial and error as well.
(also, they disassembled the wiring to clean it? that's thorough!!)
Hope this helps, let me know.
May 09, 2009 | Kitchen Ranges
PS3 hard drive failure
Hello. You are very welcome. I'm glad to help. Please rate my solution accordingly.
There is a very easy way to clean the laser. You dampen a Q-tip with rubbing alcohol. Blot it with a napkin so that it doesn't look saturated at all. To much will damage the laser beyond repair.With the Q-tip between your fingers lightly touch it to the lens of the laser and slowly spin it on the surface. Repeat 1 more time with the other side of the Q-tip. Let it sit for 10 min, put back together and it should work fine. As long as the laser diode isn't bad already.
Now for disassembly. That is a bit more challenging! I have had MUCH practice and have damaged a few parts as I was teaching myself how to refurbish these units. I am currently working on a disassembly guide to replace the laser assembly. I still recommend calling Sony as they may fix or replace it for free. If you are set on doing it yourself please just hit my ask me button again and I will send you directions.
Good luck to you.
Aug 01, 2008 | Sony PlayStation® 3 (60 GB) Console
Norelco 7610X Electric Shaver Logo
197 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
