Question about Olevia LT32HVE 32 in. LCD Television
No picture/sound Olevia 65" LCD TV 265T
What's wrong and how/where can I get it fixed? Scottsdale AZ.
    Scholar:
  • 45 Answers
Since the manuf. of olevia is out of buss.. the only service center that i know that has parts in stock for olevia televisions will be Amergence Technology they are a 3rd party repair center that is located in California and if you will like give them a call at 866-965-3842 and just ask for a price quote and they could explain to you the repair process as well..
Posted on Jul 28, 2009
"Olevia 65 LCD TV"
8e12bdd8-2e36-4e3d-b2c6-b240db1b35af.jpg I have found a solution to the scrambled / freezing picture for the 65" Olevia LCD T11. At the recommendation of 3D electronics in plano TX, I installed a 200mm fan on the back cover with the air blowing directly on the CPU of the main / video card. I had to cut a whole in the back cover to mount the fan and actually left the bottom panel off to let more air flow. There are some spare 12v terminals on the second power board on board furthest from the main board. I cut the whole out with a jigsaw and had to extend the power wire due to the length required.
Jan 07, 2013 | Olevia Televison & Video
Olevia 265TFHD 65
FIGURING OUT YOUR PROBLEM IS ONE THING, BUT FINDING THE PARTS WILL BE THE BIGGEST CHALLENGE. I HAVE A OLEVIA 255TFHD AND IM CATCHING HELL FINDING PARTS. SYNTAX BRILLANT, THE COMPANY THAT MADE OUR SETS HAS GONE OUT OF BUSINESS. PARTS ARE SCARCE
May 11, 2012 | Olevia 237T 37 in. LCD TV
Hi, My Olevia 42 inch, model342-B11, has a problem with its picture. At first I had vertical lines running down the screen, then it turned into small squares. What do you think is wrong with it?
Parts are hard or impossible to find for this brand but it sounds like the "main" board which processes all signal in and out of the display.
Apr 30, 2012 | Olevia 742I 42 in. LCD TV
I have sound but no picture on my Olevia tv, model 323-S11
this sounds like a mainboard issue , a replacement mainboard will solve this problem
Apr 23, 2010 | Olevia Kolin DLT2711M 27 in. LCD...
Need code for my Cox Remote Control for my 26-inch Olevia 226 T12
We had this same problem as well and we finally found the answer, the code for the COX remote (silver on top black on bottom) is 1240.
Feb 21, 2010 | Olevia LT27HVX 27 in. LCD Television
Olevia tv
If an LCD TV has sound but no picture do the following:
Use the source button to ensure that source is not set to the wrong input.
Try unplugging power cord for ten minutes, to ensure it is not a setting problem.
Check all the video cables at the back of TV.
Check Light /Color settings.
If problem persist and does not depend on external receiver or settings, then it is likely an internal fault.
If it has sound but no picture then one of the following parts is faulty, and must be tested and replaced:
The inverter is the high voltage board that provides variable power to the backlight lamp. This is the most common. When inverter is faulty you can get no picture, or a very dim picture that can only be seen by pointing a torch light with a 45 degree angle on the LCD surface from very near distance.
The inverter must be tested by reading voltages with a multimeter.
The LCD ribbon cable/LCD display and connectors.
This is quite uncommon, but happens. If the TV had been hit or moved the LCD cable may have slipped out, or the LCD connector may be damaged.
The LCD controller board.
This is the board that controls the video signal, it is difficult to test, as there is need to read determined values on IC pins. To test this board you need to purchase a service manual and follow the troubleshooting diagrams on service manual.
Input/Output Signal boards.
This are the boards where you connect the video and audio cables, if a signal board is defective, then you may get no picture on particular inputs located on faulty board.
If under warranty contact the manufacturer ringing the number on the user manual.
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
May 25, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Power Supply problem? Olevia 265T FHD 65" LCD
Wow, you have a big TV.
Sadly, there are no aftermarket power supplies for TVs like the PC.
Everything inside the TV is no different than how a PC is put together. No soldered connections.
The problem with your TV sounds like it maybe the power supply. But it most likely the power inverter board that powers up your LCD screen. It maybe all in one board or two separate boards. It's hard to tell what the real problem is without a service manual to test the boards.
Feb 19, 2009 | Televison & Video
Whats wrong
It is possible that your lamp has expired for the "no pix, only sound" problem, but the other symptom could be as simple as "wrong input selected" or another internal problem with your set...accordianman
May 28, 2008 | Olevia LT32HVE 32 in. LCD Television
What is code for Olevia 42" TV, Product # 242-S11?
I have the Olevia 65 inch LCD TV and cannot find the comcast remote code for my TV! Any help?
May 16, 2008 | Olevia LT32HVM 32 in. LCD Television
Lcd tv picture problem
My 3 yr-old 30" Olevia LCD HDTV lost picture after being on for about 1-2 min. Does any one encounters a similar problem or has any suggestion as to how or wherther it can be fixed. Thanks.
Jan 11, 2008 | Olevia LT26HVX 26 in. LCD Television
Olevia LT32HVE 32 in. LCD Television Logo
531 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
